#121
I think Ernies current gear is 3.73:1...
#122
So much technology and knowledge has been available in the last 20 years has helped a bunch. Think about all the knowledge that's on just this site? A 10 second true street car, is a real hoot!!!
#123
I think he said his best time was with a 3.08 gear and Conti converter? I may be wrong.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
#124
#125
Yes current best is with the 308's..but the 373's should out run it this year..
#126
#127
Andy is currently using a Holley 950hp carb on a Torker 2 intake..he is pretty pleased.
#128
Well my Engine is the typical stroker 463 / E Heads done at SD back in 09 with some further work. Run a Roller /400 lobe 1:65 on intake 1;5 exhaust .Compression is 10:3. I Run a self ported T2 1 : carb spacer. The HP 950 I picked up last fall , is one of the best carbs I’ve ever run . 76/84. 1 7/8 headers with full 3 exhaust. TH 400 with Continental 3200 but flashes at 36. 3;42 10 bolt. Front Suspension has tubular arms and i have Viking coil overs. I did weigh it at Norwalk couple yrs back, race weight me in it 3909. |
The Following User Says Thank You to Torquewar For This Useful Post: | ||
#129
Jeff your earlier post #122 very much sums up what’s achievable, but its not everyone’s path.. To have a turn key drivable 10 sec car was never the goal but….stuff happens. TA man keeps me on my toes so the endeavour happened. Pushing the Pontiac name has become at least to me kinda important.
Another note , its a street car , runs cool in traffic on-hot muggy days and has acceptable street manners. I do go to various cruise nights and car shows and think nothing of driving it.. It takes a ton of research to pick the right selection of parts to make the whole package enjoyable. Last edited by Torquewar; 08-25-2022 at 10:09 PM. |
#130
I can add about running Pontiacs at the track, most times if not all times we are the fastest real N/A cars at the dragstrip. Makes us feel pretty good when people come over looking for poweradders under the hood and just realize they are all engine.
That Friday was hot and humid..Andy and I would literally come back after a run soaked..yet the cars didn't skip a beat...great day!
The Following User Says Thank You to ta man For This Useful Post: | ||
#131
Thereis a lot of fast street cars in my area.nothing to see lots of 10 or even 9 second street cars on a test and tune night. That being said, MOST have a power adder of some sort. Turbo, superchargers and even NOS cars. I typically drive my car to the track and usually line up with the “slick” cars. I’m typically a slower car in the “slick” lanes but I look around and I’m also the only one that drove it to the track! When people see me pulling out to hit the street I often get crazy looks!
#132
I installed my new Progression distributor today..so it will be the first time in years with no MSD and no external coil for now.
#133
I wasn't sure I was up to speed on your combi, was pretty sure you were running the Quadrajet, anymore. Now if you and Ernie can get Chris up to speed, that would be cool!!! Thanks Jeff
#134
Update on the distributor, easy install and easy to set and adjust the tune. I doubt I will find any power with it but if I was off a degree or two for total power it's so easy to adjust to find.
For an overall tune some minor adjustments have already made the car smoother and more responsive, the ability to tune the vacuum advance while driving is great. I've also made a cold start tune that is basically just more timing at idle to help the engine idle. The track testing will be fun, I plan on running 28 30 and 32 for totals and then narrow down exactly what the engine wants at full throttle.
The Following 3 Users Say Thank You to ta man For This Useful Post: | ||
#135
Hey TA-man did you use the small cap unit from the Progression distributor? it sounds like a neat addition
Jim
Jim Moshier 1971 Grand Prix 462ci SD Performance 6x heads 1962 Catalina 389 1968 Firebird 400-455 I haven't decided "If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan |
#136
Big cap HEI..
#137
Any updates??
#138
Update, the new distributor is working out well. The quick adjustments on the spot are great for the track and street. I'm still fine tuning for the street with it but the car has never ran smoother.
As far as the dragstrip it is easier, lock out the timing and hold on. The car just loves the locked out timing. I ran it at 28 degrees and 30 degrees for all passes with the 30 degrees showing the best et and mph. ( bit of tuner error I thought I was at 30 and 32 degrees at the track but distributor was off 2 degrees for sync) Every pass I went quicker then my previous 60 foot times into the 1.4's Every run I had the Prosystems carb on with no adjustments made. But I still have not out run my 308 times...even with the quicker 60 foot times. So I am currently trying to tune the combination for more upper rpm power. I also did a compression test all cylinders show 195 plus or minus 2 so the engine is healthy.
#139
Here are the three better slips, I hit the rev limiter on the other 2 but the slowest 60 foot was a 1.5028.
#140
Thanks for the update!
Any chance you have the best slip with 3.08 gears handy that you can post, just to compare to? |
