#121
Nice work Calvin!!! It appears though that my fears are confirmed with the roof of the port being to thin. It looks like in the one picture of the port, I see were the spring seat poked through. I left the port I'm playing with a little on the conservative side for that reason. I think if Edelbrock would have moved that spring pocket up just another .100 we porters would be allot happier. If Edelbrock is concerned with valve weight, they shouldn't be. With titanium 8 mm valve stem valves. The valve should be plenty light enough for rpm's up to 9,000 +.
Bruce your spark plug location worries are indeed a major concern. The plug location is not optimum and can lead to detonation. As Tom V. stated as well, there is probably going to be an issue with cracking in this area. It is thin there and with the heat build up in this area may end up being a major issue. I guess we won't know that until someone gets a set on an engine and beats on them. So with this all being said, to make these heads work without issues. It looks like welding will be necessary as well as additional machining before welding and after. I hope all of our hypothesis are unfounded!!! Don Johnston DCI MOTORSPORTS INC. 330-628-3354 cell 330-850-5050 shop Designer of the DCI Tiger Heads and the NEW DCI Ram Air V Heads !!!! |
#122
Strictly technical and somwhat managerial....
??? is the 11 deg head mold simply an angle milled version of the 12.6 casting mold??? Have there been casting changes since the early castings??? Perhaps now that you porters have found things that maybe Edelbrock should have noticed, and done a better job with, maybe you should collectively consider having them correct the castings before trying to move further. After all, you guys are eating their R+D costs till someone buys. JMO If they come back and say "we built it exactly as you asked", then who gave the specs? I think you guys arent at fault here! Potentially great product here if refined. |
#124
Isnt it better to get things corrected before proceeding further? Dont care who designed this head, ports it or whatever, if you can avoid a risk why take it??? View it in another way... what benefit is having the plug and tip so close to the exhaust valve seat??? If there is a benefit, does it outweigh the risk? Knowlegible people have concerns. Including people involved in cylinder head design. Yes some concerned have competing product to sell. Would you rather have them sit back and chuckle when someone nukes a motor to a preignition event? This aint detonation your playing with. Diesels detonate all day long, they arent likely to live through a preignition event let alone a race motor. I think most of us in the Pontiac community care far more about fellow Pontiac'rs and Pontiacs first more so than Edelbrock or products from Edelbrocks competitors within our own community. The problem finders arent calling our newborn ugly. They're telling us it has a few birth defects! Quit with the political view crap. If theres a technical issue that can be addressed BEFORE a product gets released lets get it resolved or other means to move forward. This shouldnt be a "whip it out" contest! And as far as something has been done and gotten away with successfully goes, it doesnt gaurantee you will the next time. Last edited by BruceWilkie; 11-17-2011 at 06:44 PM. |
#126
Jim and Calvin could you both measure from the deck to the valve cover rail. Wondering if the 11° is taller than the 12° and by how much.
#127
Why should our porters and builders stick their neck out for Edelbrock? Do it better and its a win/win for all involved.
#129
Even better - deck to top of port opening
#130
You are right Bruce no one should work with this casting until the issue you believe are there are resolved.
#131
Would not be the first time the engine builders and head porters did the final R&D on a product.Bill C.
Checkered Flag Machine & Ceralli Competition Engines Racing engines and induction development http://www.checkeredflagmachine.net/ |
#132
Production equipment often gets that way. Sales types tend to push things out the door before engineering feels its ready. Once released the techs own it.
#133
No company that I know of does its own r&d. The cv1 r&d is being done by others, Bill is doing a lot of it for AllPontiac I believe. KRE might be the only one that r&d their stuff first since they make a billet head first and run it then they cast it.
Do you expect edelbrock to built a Pontiac to test this head on? Do you think Edelbrock has built an engine for all the other makes to test their proports on? |
#134
R&D
Edelbrock didnt do the R&D on their performers either they work some deals with racers and builders and took data from them to make some changes from the original castings. Hoping they will do the same with the pro ports if there are any proven problems. As of right now, Since I dont know of anyone that is running a set on an Engine its speculation. Just hope that the issues mentioned previously dont come back and bite someone. Really sucks to loose a motor for any racer.
#135
Just to add more technical data to this thread, Edelbrock says a 2.35in 1.72ex valve can be used. Will thats not happening with the 2.040 valve spacing that it comes with unless you only want .005 clearance between the valves. You could probably run a 2.330in 1.700ex with the supplied valve spacing.
#136
One other tech note, it appears there is about .200 clearance between the intake valve and the cylinder wall with a 2.300 valve and 4.350 bore. The intake valve appears to be in a pretty good location for producing good flow numbers, which is backed up by Calvin getting 440+cfm at .700 lift out of his head.
#137
Some progress...
Left mold is a BBC Brodix CNC flowing 525 cfm; Right mold is a 18degree Small block by Weldtech that flowed 365. |
#138
Offset bore the guide holes. CV products sells blank guides with the ID and guide top done but not the OD. Move that stuff were you need it. |
#139
Has anyone confirmed the fact that the 11 degree and 12.6 are the same -- or different castings ???
#140
x2..
