#121
The pic of the '59 being pulled is cool, in widescreen CinemaScope! I just noticed after rereading your last post that it is tied down without front wheels. Must be hard to get on and off the trailer that way.
Most new dolley manufacturers say they are for towing front wheel drive cars only, probably for driveline liability issues. I have used one before on a rear wheel drive pontiac, 100 miles, no issues. New ones come with brakes now, there is even one model out now with hydraulic disks. Is it still a good idea to remove the driveshaft when towing an auto trans pontiac. Last edited by elefantrider; 12-15-2012 at 11:51 PM. |
#122
It is best to remove the shaft, and plug the tailshaft. That way you are not spinning any parts at the rear of the transmission without lubrication- remember, the front pump isnt turning.
#123
I agree Steve, Day Two cars are few and far between, what with the value of numbers matching restorations in the past 20 of so years. Like yourself, I have been a second hand GTO owner since the days they were a couple of hundred bucks, and always a bit "used". I would clean up the exterior, install some Ansen slots, Highjacker shocks, put a Sun Super Tach on the column, apply the "WFO" sticker to the back window, and be all set to go! Performance upgrades came before cosmetics, though. I took my GTO camping, 4-wheeling, exploring, etc, as it was the only transportation I had. Cleaning out my late father's estate a few years ago, I found my old chrome barefoot gas pedal, dimmer pedal, Sun Tach, and "the 500" cal custom steering wheel. Great memories. Speaking of cars towing trailers, back in the '60's and '70's, that's how it was. The only people with pickups were folks with cab-over campers, and gardeners or contractors. Everybody towed with a car or a wagon. My neighbors towed their Piper Cub with a '62 Plymouth wagon. The '65 GTO I've had since '82 had a trailer hitch on it when I bought it. As did a '66 Coronet 440 4 speed I used to have. And, recently, I was driving from Fresno to the coast on Highway 41 and came across a mint '60 Bonneville 4-door vista-top (burgundy with a silver top) towing a mint Airstream trailer. Pretty cool.
Jeff |
#124
Getting the car loaded and unloaded is not that bad. I use 2 of the lightwieght alum floor jacks from Harbor Freight and some 2 by 4s. Jack up the car below the cowl then roll the dolley in or out. At this time in my life, am trying to keep expenses as low as possible to pay off the acreage for the Pontiac museum so, using the GTO to tow cars is a temporary thing but, other towing, like one of my boats, etc is a lifelong thing.
Hundreds of Pontiacs in Az "Real Pontiacs only..no corporate nonsense!" Facebook- Pontiac Heaven Hosting- 23rd annual Pontiac Heaven weekend- Phoenix pending due to covid Pontiac Heaven Museum in process Phil 2:11 |
#125
What is the sweet spot of Compression Ratios for an iron head 455 or 428 that needs to tow and be reliable in a hot climate with hills? 9 to 9.25:1 is too high?
Does the heavier load increase the chances for detonation at that low a CR level? |
#126
I personally am a fan of 8.5:1. Run on pretty much any cat pee gas and not have to worry too much about detonation provided the rest of the cooling and ignition system is in good shape. You can get decent performance from that range too with the proper cam choice. Other guys have their preferences higher, so I'm sure you'll get opinions varying. My main concern is being out and about on the backroads and having to trust the gas that goes in the tank from any station out there.
#127
For how little I will tow with the car, I am open to paying 20cents more per gallon for 91 if it gets me a little more pulling power by allowing a higher CR, say 9:1. At the current price in So. California, there is only a 5% difference in price per gallon, 91 vs 87.
#128
outside temps when towing engine temp ign timing to name a few. So, there are ways to get around running a little more compression in the winter and keeping the engine running cooler in the summer, perhaps set the timing back a bit to the point of detonation. It is easy enough to do on the side of the road if you have to.
#129
Today I finally saw $2.99/gallon for 87 octane here in Phoenix. That means 91 should cost a mere $0.20 more/gallon, or $3.19. That's roughly 6%, more per gallon, or when filling a 20 gallon tank, $4.00 more total cost per fillup ($63.80 vs $59.80 per tankful). And once the cost of fuel begins rising again (as we know it will), the difference as a percentage begins to drop. In other words, 6% or less is not much when viewed this way. And if you're gaining 6% more power by running another point of compression, sounds like you're real close to break even. I too run 91 octane for other reasons than towing, but your math is still exactly right. Of course you have to watch as many stations will jump as much as $0.15/gallon per grade, so you must look at the cost of premium, not base 87 when shopping for gas. I watch this regularly myself. Quote:
Just more of the 'tricks' we use when dealing with the current fuel situation, eh? Keep driving 'em guys...
Eric "Todd" Mitten '74 Bonneville 4dr Sedan (455/TH400/2.93 open) '72 LeMans GT (455/M-13/3.23 [8.5"] posi) '71 GTO Hardtop (400/TH400/3.07 12 bolt posi) ‘71 GTO Convertible (455HO/TH400/3.23 posi) '67 GTO Coupe (455/ST-10/2.93 posi) '67 Tempest Wagon (428/TH400/2.56 posi) Deuteronomy 8:3 |
#130
That is the beauty of using flat tops instead of dished pistons, you can chase a specific CR by swapping relatively inexpensive heads until you find a sweet spot that works. Looks like with the 114cc heads i have available, I will build it for 8.5-8.75:1 and see how that does. 98cc heads would put me at 9.25:1 which might be a tad much for towing carefree around here.
I like the idea of an in-cab dial timing control unit for towing. MSD has one but I'm not sure if it will work with a stock points-type ignition. |
#131
Anyone know if an original 455 2bbl Rochester 2gc carb would be better for fuel economy, towing and low rpm torque than a quadrajet? These were offered on 455s from the factory in 71-72, as a towing option i believe? My thought is they offer greater throttle opening without getting into the big secondaries of the quadrajet. Any thoughts on this?
#132
#135
I use standard bearings and a reg 60 pound pump. The 1,200-1,800 rpm is on level ground. I use 3rd gear in the mountains going uphill so, it is over that range at that time.
#136
Any improvements made to the steering? 12:1 ratio? I just replaced my centerlink....amazed at the difference it made, but the box is at full adjustment and could use a rebuild.
#137
What about control arms? Those 30+ yr. old, stock stamped units, can you rely on them?
Apparently, b-body arms are the exact same as a-body which opens up lots of aftermarket options. |
#138
I used some knock-off tubular control arms on the clone that I got from ebay, look exactly like the GW arms, and the set was under $300 shipped for all 4. Just be sure you pick the right ones. I believe Right Stuff also has them, with a little mark up. I looked them over carefully, welds and all were good and they fit well. No problem with alignment or tracking, car drives well.
Like these for $230: http://www.ebay.com/itm/64-72-Chevel...9a44f8&vxp=mtr Or these for $250: http://www.ebay.com/itm/Heavy-Duty-C...fdc01f&vxp=mtr .
#139
I got 19.5 MPG @ 60 MPH on a Florida trip with the above carb on a big head 455. It did great burn outs but did run out about 4K rpm's. I only picked up 3 tenths when i switched to a factory stock Q jet. That was a 75 lemans with the A/C on.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk |
#140
