Old 08-12-2012, 06:27 PM
Half-Inch Stud's Avatar
See 12.2 Et signature with 89 Octane clear at WOT & Barely trappin 5000 RPM.
12.0 ET signature was trappin 4950 RPm.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
  #122
Old 08-12-2012, 09:34 PM
beemergary's Avatar
63 tempest 421sd 980 heads 859 2x4 intake with edelbrocks street radials 3450 with driver street car 11:39 @ 117 on a hot day. NO ROLL BAR
  #123
Old 08-17-2012, 09:00 AM
grandville455's Avatar
grandville455 grandville455 is offline
1974 Firebird 3580#
461 CI / SDKRE 290 Heads / 1065 Dom/Out of the box EFI Victor intake
TH400/CONTI 4200 stall/3.73 gear
29x10 Hoosier Drag slick/Cal Tracs/Split mono leaf
Street/Strip (Tagged/Insured) Pump gas 91 octane
1 7/8 Header's, 3 1/2" Pypes X to 3" Ultra flows,3"tails
Best time to date,6.79@101.36(1/8th) 10.68@125.49(1/4)
1.52 60 ft.
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
  #124
Old 09-08-2012, 09:27 PM
dammen8's Avatar
dammen8 dammen8 is offline
Best pass to date happened today
1975 Firebird
3300 race weight
496 ci (4.310 X 4.250)
13:1
Single Pro-systems Dominator
STD port E-heads done by SD Performance
Victor intake
nothing fancy just home grown garage junk
1.259 60'
3.805 330'
5.915 @ 116.17 1/8th mile
best mph to date is 116.34
3.89 gear
29 X 10.5W tires
Chad
3500lb 10.5" tire. 5.34@134.4 with a poor 60'
  #125
Old 09-25-2012, 12:28 PM
JOE DEYTON's Avatar
JOE DEYTON JOE DEYTON is offline
Cool PERSONAL BEST RUN
RAN OUR 70 FIREBIRD WITH 478 CU IN 4 INCH STROKE IA2 BLOCK, E- HDS WITH 1 HIT FROM OUR FOGGER IN OUTLAW DRAG RADIAL CLASS At 75-80 SATURDAY ran 5.14 in the 1/8 mile @136 mph and a 60 ft 0f 1.18 weighing 3400 pds DEYTON PONTIAC RACING
  #126
Old 09-28-2012, 12:26 PM
bad69bird's Avatar
bad69bird bad69bird is offline
Very impressive Joe! You guys have come a long way with your program...CONGRATS!
-Brian
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs)
  #127
Old 10-05-2012, 02:26 PM
beargfr beargfr is offline
Ok...
69 GTO 400(461)
Street car (full interior, functioning A/C)
3950 w/driver
93 octane, 10.0:1, round port E-heads
Solid roller, 455-SD Qjet, Torker1
TH400, Moser 9", 3.50:1, Wavetrac
Best to date: 11.86 @ 113, 1.76 60 ft.
  #128
Old 11-16-2012, 07:55 AM
gavin gavin is offline
I have not got my 63 tempest to the track yet so I will have to put up a car my friends and I raced in New Zealand back in the late nineties. It was a FE rail with a very low dollar 455. I got given the engine because it was sitting outside in the weather and was very rusty in the bores and had the side broken off a piston. My friend Gary welded the side back on the piston and we reringed it gave it some new bearings. We got given an isky mega cam and lifters 221/.050 .465" lift 108 degrees mild but free. I built a sump with a kick out scrapper and windage tray .The heads were 6x off a late 400 witch I ported rather badly. We couldn’t afford Pontiac springs so we put the heads on a mill and cut them for swap meet chev small block springs and retainers. We wheeled and dealed a torker 11 manifold and a used 750 dp holley. We adapted a big block chev electric water pump to the front of the Pontiac and that was our race engine. We then built some tri y headers with IR cones on the exhaust ports. It owed us $1200NZ. It was placed in the rail owned and built by Jeff and Gary with a 3000 stall glide and 3.00 diff gears. The rail was on the track racing for under $6000. It would go 9.5 all day long and we all drove it. Best run was 9.3 at 145 mph. I think it would have gone faster with a stock 4bl manifold as it was so mild.Name:  mhjmkfgjk.bmp
The Following User Says Thank You to gavin For This Useful Post:
  #129
Old 09-10-2013, 08:06 AM
SWEETJUDGE's Avatar
SWEETJUDGE SWEETJUDGE is offline
off the trailer... i just ran 8.80s @ 153... all motor 69 GTO 2650 lbs all aluminum 505.
with some tuning & adjusting i should be 8.50s -8.60s..
1969 Early 01D JUDGE #s MATCH RA III 4 Spd (Concours Restored)
1969 PRO STREET GTO 2500 lbs. ALL ALUMINUM 505
1969 RARE All Glass GTO (FOR SALE) YOU NEED THIS
AC Cobra Kit Car 521 670 HP/715 Trq
LOOKING FOR V PARTS !!!!!!!!!!!!
  #130
Old 11-18-2013, 08:02 PM
pontiac6269's Avatar
pontiac6269 pontiac6269 is offline
1969 GTO
461, 670 heads, Comp Cams 292AH-10, cast iron intake and Q-jet
Turbo 400, 13" Continental
O- style 12 bolt w/3.08 gears BFG 235/60-15 drag radials
3860w/driver
50/50 89 octane and E85
Best so far 12.59 @ 108.43, 1.898 60' Left trans in drive, shifted at 5200 rpm which ended up be to low and dropped out of power band. Car driven 3 hours each way to track.
Eric
1969 GTO - 461, turbo 400, Continental 13", 3.08 gears. - 12.59 e.t. @ 108.43 mph, 1.898 60'
1978 Oldsmobile Cutlass Supreme- 461, turbo 350, PTC 3500 converter, 9" 3:50 gears. = 11.39 e.t. @ 117.55 mph, 1.599 60' on E85
  #131
Old 02-20-2014, 06:31 PM
CraigG.'s Avatar
CraigG. CraigG. is offline
1/8 = 6.67 with a 1.41 at 101
Combination:
72 GTO - Race weight 3400 with me
Elevation 980 Feet
465 and 12 1/2 to 1
455 bored .040 over
Bore … Stroke…
Hand Ported E-heads - '1999 - '2000
Heads Flowed 331 int. and 235 ext.
72 CC milled .060
Zero Decked
Flat Top Ross Pistons
Solid Roller at 276 / 279 at .050 and .635 lift
Installed at 104
Comp Cams - Grind# P8 4028B / 4049B R 108.0
Intake Exhaust
Valve Adjustment .020 .022
Gross Valve Lift .631 .630
Duration @ .020 Tappet Lift 312 316
Valve timing Open Close
@ .050 INT: 30 BTDC 66 ABDC
EXH: 67 BBDC 31 ATDC
108.0 Intake Center Line
Intake Exhaust
Duration @ .050 276 279
Lobe Lift .4210 .4200
Lobe Separation 108
MSD 6AL 2
MSD Billet Dist.
Advance Locked at 34 degrees
SD Performance Modified Tomahawk for a Holley 1050 Dominator
Relatively SMALL Plenum
Relatively SHORT Runners
“1 Cloverleaf Spacer
"3 1/2 x 16 air filter
"2 Hookers Headers
Turbo 400 with a brake
"8 4500 stall on the brake
3.73 gears with MT 10.5w x 28 slicks
  #132
Old 09-01-2014, 07:37 PM
7dgoat 7dgoat is offline
1970 GTO Street car, 4,120lbs with me in it, 467 stroker ,auto trans, 11.88 at 114mph.
  #133
Old 10-11-2014, 05:43 PM
wreckmastr's Avatar
69 GTO 3620lbs 511" w/F-3 139 Procharger
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
  #134
Old 10-28-2014, 06:39 PM
CraigG.'s Avatar
Hey Everybody,
After fixing the driveshaft, last year we ran a 6.67 at 100.9 mile-per-hour and made it to the semifinals with winning six rounds. This year we had issues with the track as well as the transmission brake and the line lock. However we did our best ET of 6.58 at 101.8!
Thanks, Craig
  #135
Old 03-30-2015, 09:17 AM
Macho78's Avatar
Macho78 Macho78 is offline
1978 Macho T/A #123
462
10.25 comp,
Solid roller 110lsa
E-Heads 320 cfm
SRP pistons
Eagle rods
N-crank
Torker-2
Holley 850
190 shot
TH400, 3500 stall,3:23 gear
See sig.
78 Macho T/A #123 11.78@115.5 on motor 10.66@127.9 w/190 shot.
  #136
Old 10-10-2015, 08:53 PM
cphilgto's Avatar
cphilgto cphilgto is offline
Default Classical Gas 1964 GTO
2850 lbs w/Driver
All tube chassis built in 1990 by owner
Strut Front and 4-link rear
400ci Pontiac block 2 bolt
Built by Guy Orr @ Mother's Machine
Stock 455 Nodular Crank
Bored to 483 ci
Aluminum CV-1 Heads / Early design
14:1 Compression
Cam II fuel 110 NO Power Adder
Single DaVinci 1050 Dominator
Coan Turbo 400 Reverse Shift
Coan 4500 Stall Converter
9" Rear with 4:56 gears
New combo / best to date
1.24 60ft
5.88 1/8th @ 116
9.25 1/4 @ 146
Clay Phillips
Owner of Performance Paint & Chassis
Springfield, MO 417-886-8557
1964 Classical Gas GTO
468ci Pontiac on Gas with CV-1 Heads
Turbo 400
Outside video
https://youtu.be/UZ51NBAubdg
Inside view
https://youtu.be/ioMxnXMKUk4
  #137
Old 10-11-2015, 07:32 PM
1974 Firebird 3640#
468 CI /11.1 comp, KRE D Port Heads, 325 cfm, SR 265/270 with 1.65 rockers / 1050 Dom/Ported EFI Victor intake
TH400/UCC 4800 stall/4.10 gear
28.5x9 Phoenix Drag slicks/Cal Tracs/Split mono leaf
Best time to date
Darby
  #138
Old 10-17-2015, 09:41 PM
cphilgto's Avatar
Default Gotta post new numbers
Originally Posted by cphilgto View Post
2850 lbs w/Driver
Bored to 483 ci
1.24 60ft
5.88 1/8th @ 116
9.25 1/4 @ 146
After running the car last night and more tuning, we've gotten some more out of the CV-1 heads.
Best to date now is...
9.18 @ 148
Still no power adders like NOS and still on gas
Correction on the weight too because of the aluminum heads. It's 2800 lbs with the old man driving. My son ran the 9.25 and he's about 50 lbs lighter. Time to put the wheelie bars back on!
Clay Phillips
Turbo 400
Outside video
Inside view
  #139
Old 10-18-2015, 11:19 AM
cphilgto's Avatar
9.18 @ 148
i
Ride along on the pass....
Clay Phillips
Turbo 400
Outside video
Inside view
  #140
Old 06-08-2017, 05:56 PM
slgenge's Avatar
slgenge slgenge is offline
Default 10;38
After lots of Gremlins in ****ty air , finally deep in the 10s
Name:	time slip,#1.jpg
ID:	456485   Click image for larger version
ID:	456486   Click image for larger version
1964 Catalina 2+2, 389 Tri-Power , 4 Gear , 8 Lugs
1966 GTO, 467 Stroker Mid 11s
2002 Firehawk Vert, SOM , 6 speed, all the SLP Goodies
1968 Firebird Race Car,525 CU IAll looking for low 10 second passes!
1970 442, # Matching 455, 4 Speed W-25 hood
