#121
Just to let you know, I will not be able to work on the car this weekend. Family is coming in tomorrow and leaving Monday. I will update next Sunday. Y'all have a good one.
Remember no one is perfect. Everyone's butt has a crack in it! |
#122
Company didn't come this weekend. I got the proportioning valve installed, painted and installed the torque converter cover and took the core support apart for powder coating.
I also got the drive shaft blasted, wire wheeled and clear coated. Going to have new U-joints pressed in tomorrow. I received my order from inline tube. New proportioning valve, front brake hose brackets and brake hose clips. $89.44 with shipping. I worked eight hours so that brings labor to 190 hours. Labor= $3,800 Parts= $5,273.37 Total= $9,073.37
#123
Keep up the good record keeping and reports. Very interesting to see it tracked this way. Taking pics along the way to match up with your records?
Mitch Kunath |
#124
I take digital shots of everything I take apart, then tag it and bag it. Even if I don't reuse the original I know what it looks like and where it goes.
Sometimes I do slip up and forget to take pictures. And, I have been known to misplace a part or two.That's why I like this forum, I can get all the help I need.
#125
When you removed the windshield pillar piece and the channel was visable, is the pillar piece available repo? There is some rot on mine and I have not seen this in the catalogs, any help is appreciated.
Scott |
#126
I am not sure if the pillar is repo-ed or not. You are refering to the painted piece aren't you? If so, post it in the parts wanted section. Someone here probably has them.
#127
I've been looking for info on those items as well. Haven't had any luck whatsoever as of yet.
#128
![]() Quote:
#129
I am posting my weekly update tonight. I may take tomorrow off. Anyway, I had new U-joints installed this week and got the drive shaft put back in.
I also cleaned some of the parts for the core support in preparation to have them powder coated. Drive shaft work cost $89.00 and I worked 7 hours so that brings me to 197 hours labor. Labor= $3,940.00 Parts= $5,352.37 Total= $9,292.37 ![]() ![]() ![]()
#130
I'm enjoying this thread. You're a few steps in front of me but I'm going down a very similar path. I may have a question or two in a little while.
#131
Pics look great!
#132
I have a 1967 Lemans. I have all the documentation from Pontiac Historical and everything matches. Today someone told me that part of the serial number should be on the firewall data plate. I have attached photo. Can someone tell me what's correct.
#133
![]() Quote:
#134
Don't listen to what everyone tells you. The only #'s that will match from the Data Plate to the VIN are the first 5 or so. Example-- 23737? for a Lemans hardtop. This would be the first 5 on the VIN and would also be listed on your Data plate. Any other numbers DO NOT match.
LEAD, FOLLOW, OR GET THE HE!! OUT OF THE WAY!!! HONEST JERRY'S SPEED AND EQUIPMENT
#135
That's them, what is the correct name for the panel? Thanks for your help.
Scott |
#136
That's exactly what I was talking about myself. I've looked on eBay and have never seen them whatsoever.
#137
I'm not sure but I think they are called windshield pillar trim panels.
#138
Frame,windshield outer-side. From the GTO Restoration Guide.
#139
Did not work on the car this week. I did take the parts to the powder coater's. And I ordered some more stuff from our host.
I took time to get my bike back on the road. Put new tires, rims and a chain on it. I talked to my body man and am looking at taking the body to him in two weeks.
#140
Still waiting on the parts to come back from the powder coaters. Got my stuff from our host. Also bought two bottles of rear end oil. I found a 67 body that still has good quarters on it. Picking it up next saturday. I painted my shocks and tightened up the tie rod ends and spindle nuts.
I returned a part to our host that I didn't need. Parts came to $161.78 - $71.00 for the return =$90.78. Four hours labor brings that total to 201 hrs. Labor= $4020.00 Parts= $5443.15 Total= $9463.15 Here are some pics. The first one is what I saw when the owner told me where the parts car was located.
