#121
Still waiting for the block!
#122
Not to steal your thread, but my intake and heads are going out in a few weeks for creation.
;o)
great build tom. you can think up some crazy builds.
you call yourself HARDCORE but are you truely hardcore |
#124
still waiting for the block!Has been about a month for dowels and a short fill!WTF?Tom
#125
Tom, could be due to the holidays.(?) The shop I deal with is a bit slower to finish work this time of year with employees taking/using up vacation days etc. Just a thought.
___________________________________ "Objects in mirror are closer than they appear" |
#126
Tom,
Standard Pontiac dowel pins? I think a month to install dowel pins and partial fill of the block IS a bit long.
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
#127
Yeah, it might be even longer, tomorrow is the King's birthday (Elvis)...
#128
[QUOTE=twinturrbo406;4802893]
Jeff Ianitello |
#129
A small chamber aluminum head with its parallel cast edges would work on a stock 301 block with 301 gaskets. The Pontiac D-port heads leave considerable area uncovered on a 301 block.
I have had this build in my mind since old discussion over on CP years ago, "301->500HP?" My build was/is a 4.060, 3.75, SBC 6 rod, SBC piston, hydraulic roller in the 230 range, KRE 76cc D-ports, and a custom T2 just like you made, but with a 180deg divider added to the plenum. My target was 450hp. Cheap build using off the shelf SBC parts. Only custom work would be the crank. And the aluminum heads.
Jeff Ianitello |
#130
No brace,have not addressed the head gasket -head water yet.Tom
#131
Tom, I was asking "77 Trashcan" about his lifter valley reinforcements on the 301T block pictured on page 5 or 6. Looks like he welded up the block holes, but even with that, the D-Port head water holes wil be uncovered at the top of the block and, IIRC, below the 4,6 and 3,5 exh ports. Chek it out b4 going any furthur!
Jeff Ianitello |
#132
Jeff drop a 301 head gasket on or a 400 gasket and see what it looks like. Mopar mid - late 70's 440's water holes were way different than early blocks yet early head and gasket work fine. BTW dont underestimate what can be done with the standard slow drying JB Weld if need be. (the adhesion, strength, heat, and oil/fuel/coolant resistance are well within needed capabilities here with proper prep and mix.) BTW pics on page 5 are Bills (twinturrbo406) "frankenstein" motor. Pics DO NOT really show just how well this particular block is done. The welding and other details are amazing.You need to see it in person to fully appreciate it. |
#133
Or what about a 400 short deck? 4.030 bore, 4.00 stroke (408)
Jeff Ianitello |
#134
Bill had enough room for 434 ci with the 4" crank get your block sono'd. (or $$$leeve to 4.25 bore for 454 ci with 4" stroke)
#135
I had a 350 gasket on the block and cant remember a issue.Need to get it back to check it out again.Tom
#136
Block is at Joes,neither he or the machine shop saw a issue with the larger water holes in the block.The gasket has the holes that line up with part of them and match the head.Not sure why the factory made them larger unless added cooling for the turbo engines?Joe will now work on the crank fit with the bearing spacer,once done we order rods and pistons.Tom
#137
what heads are you intending to use
Jeff Ianitello |
#138
15s
#139
Geno |
#140
Well,thats been done a hundred times!Its a std deck block instead of the short deck.Same old same old.Tom
