Old 10-25-2022, 08:14 PM
are you talking about straight alcohol or e85? I went 30 percent ...
I think it's around 39%. (not much difference between E85 and E100 I think)
Straight methanol is about double.
  #102
Old 10-25-2022, 08:38 PM
73 TRANSAM 73 TRANSAM is offline
Smile
I messed up on terminology. What I meant to say is the pins that locks the booster in place.
  #103
Old 10-26-2022, 12:34 PM
charlie66's Avatar
https://www.summitracing.com/parts/qft-14-218qft
These are called booster pins..
My Half AN Injun.....
  #104
Old 10-26-2022, 02:09 PM
grandville455's Avatar
grandville455 grandville455 is offline
Yes, wow u are using some big pins, mine are only drilled to about .183 on my 1200
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
  #105
Old 10-26-2022, 02:48 PM
charlie66's Avatar
Those are just what i found . They have .170's that i can drill .
Ive been looking for a set being mine aren't in good shape.
Are you using E85 or gas? I don't remember you saying .
  #106
Old 10-26-2022, 02:53 PM
They get sketchy to drill after about .185 real thin, unless u go to that bigger pin and the drill out the banjo for it, Are you drilling it out after installed in body? They shrink back down a tad if u drill them beforehand and need to ream them back out some after installed i have found, .180 Is fine for you no need to go bigger on pin. I'm on E85 now
Darby
  #107
Old 10-26-2022, 04:38 PM
charlie66's Avatar
Ok i figured you were .
What it was , was i converted over to E85, so i drilled them in place to see if that worked out first . When i saw one was loose i took it apart and found the pin was like you said very thin and fell apart at the end . So for now i just put it back together with some loc-tight . The pins before i drilled them were 160's.
So now i will probably get the .170's and drill them .
I was thinking a bout getting the big ones and try them .. Not sure yet on what i will do. If having the bigger ones in there wont hurt maybe ill just get them . At least ill have growing room for the future.
For now i want to test the car and see if the changes i made make any difference. So far i got the car running and it sounds and idles real good. Today is a wet one so i have to wait.
On a positive note, The holes i drilled in the metering blocks and main body for the pump-shot feed seem to have made things better on the bog i was having ...
  #108
Old 10-26-2022, 05:10 PM
.160 is fine on gas, not for E85. Get the .170’s and loctite them in and then drill to .180 and you’ll be fine , better to use a reamer as it won’t leave drill marks , just step up the drill bits til u get to .180 so not taking big chunks!
Darby
  #109
Old 10-26-2022, 06:36 PM
charlie66's Avatar
I know .160 is too small for e85 thats why i drilled them to.182 then to .192
What hp is your engine making ?
  #110
Old 10-26-2022, 08:07 PM
775+?
Darby
  #111
Old 10-26-2022, 10:02 PM
charlie66's Avatar
775+?
Ok , You have me by 100 and .180's work you so that's good to know..
What size are your pump shots/squirter's? Do you or did you have any issues with bogging or hesitation?
  #112
Old 10-27-2022, 06:39 AM
50 cc and .042 front and back, no hesitation or bogging, floats set good?
Darby
  #113
Old 10-27-2022, 07:15 AM
What ignition timing do you run?
  #114
Old 10-27-2022, 08:05 AM
slowbird's Avatar
slowbird slowbird is offline
But you leave on a transbrake, have you left on the footbrake since converting to E85?
  #115
Old 10-27-2022, 08:52 AM
charlie66's Avatar
Yeah thats where i thought i should be at .
What ratio is your linkage? Mine Is 1:1. Im hearing thats making the problem for me ..
Te bowl levels are at where a light tap on the fender it dribbles out ..
  #116
Old 10-27-2022, 08:53 AM
charlie66's Avatar
34 locked . with a 6AL ..
  #117
Old 10-27-2022, 01:31 PM
I put the external linkage kit on mine from blp, its in the 3rd hole so close to to 1-1 but not quite, its money well spent!
Darby
  #118
Old 10-28-2022, 01:19 PM
charlie66's Avatar
Tested the car today and its still the same at WOT. At this point im not sure on what else to try. Anyone have any suggestions ? I just want to say that i really appreciate everyone's input so far ..
One good thing is that the bog is 90% gone now . So i have to work on that a bit more . But the lack of fuel problem at WOT really has me stumped .. I guess ill try a different carburetor because i feel like ive tried everything with this one ..
  #119
Old 10-28-2022, 02:21 PM
Scott65's Avatar
Scott65 Scott65 is offline
Have you tried decreasing the high speed air bleeds? I have no idea how much (or little) can be gained there or if it's super relative... Maybe get some comparable data from those that have one that's working well. Or convert it to EFI and be done with it
  #120
Old 10-28-2022, 03:49 PM
Do u have a pressure gauge where u can see it? That pump is probably to small or right on the edge! I never liked that pump, tried it years ago in my Grandville!
Darby
