#101
![]() Quote:
Not sure about that. The d-ports have a stuffy exhaust port and the Speedmasters seem to have limitations when it comes to making big power... But again as you said "with money" maybe. I'm waiting for the " better options" part of this thread. |
#102
![]() Quote:
GTO George |
#103
Paul what are your thoughts on the Speedmaster heads ?
#104
![]() Quote:
GTO george |
#105
Thing is about Pontiac's and 1000NA horsepower. You can buy a set of used E heads capable for 3600-3800$. But to get to 1200HP NA its just stupid expensive so very few can actually do it. Have to check valve springs every other pass. Its nuts. Put a 1.1" lift cam, 8500+RPM and you are in for it. Whole thing is cubic dollars. Who packs 3-4 sets of valve springs just for one race ?
We are almost a small block folks. And for the most part inline valves. If we are not at our limit we are not far off. Biggest head gasket wins. Real question should be is how much NA Pontiac power can we get and not be super high maintenance. And get there without taking a second mortgage. Since that is where 98% of us live its more realistic. |
#106
Who uses 1.1 lift cams in a Pontiac?
Leech was limited to .950 ish and made good power. All of our big power Chevy engines using more than an inch lift get at least 15 runs on the springs...although they are checked every pass. |
#107
Customer service is about as bad as I've ever come in contact with.
Heads are okay but not near the head the comparable Edelbrock's are for making big power. They should be great for a strong street engine or mild race build. |
#108
![]() Quote:
Jack changed his head gaskets every 25 passes with my heads. They were well taken care of. You can buy a 1200+HP Shmidt for 29K, free shipping and guaranteed for one year in a racing environment. |
#109
![]() Quote:
It is more about RPM. and how aggressive the lobe profile is than lift. Stan
The Following User Says Thank You to Stan Weiss For This Useful Post: | ||
#110
I had a feeling they were a better street head . The customer service is a killer .
The Following User Says Thank You to dragracerx2813 For This Useful Post: | ||
#111
![]() Quote:
The Following User Says Thank You to slowbird For This Useful Post: | ||
#112
Mine will. Bailey's heads were for sale for the same price made 1000+HP. Mikes heads were 3800$ also. The heads I have made 965 with 13.5 to 1 and a N2O make. You don't think another 35 HP could be added with 16-1 and big NA cam ?
Pretty much the same head KK made 1000+ with. And mine were the most reliable of the 3 Gabby ECM heads. I am not going to try but I have most of what would be needed to do it for less money than most spend to go after it. Its all right there. |
#113
That is correct lift before lash. .018 on exhaust and .022 on intake... you can’t put a bigger cam then that in a Pontiac unless you go 50mm can core and steel rods but a) the 50mm cam will flex too much and b) I would never ever ever ever run a steel rod in an na Pontiac.
The Following User Says Thank You to John Langer For This Useful Post: | ||
#114
![]() Quote:
#115
![]() Quote:
However if that is the case it gives the E-head another advantage...it can make around 1200 with a LOT less lift! Head gaskets every 25 passes on a nitrous motor isn't that far out of the ordinary. Schmidt has a generous dyno and the warrenty is never as expected...fwiw Last edited by PAUL K; 02-07-2020 at 10:54 PM. |
#116
![]() Quote:
#117
![]() Quote:
#118
![]() Quote:
Get a ROOM! And Mike showed 1160HP. No E head has been to a true 1200NA HP and never will. No one is ever going to try and do what Mike did again. One shot deal. BTW, Mike was going to a High Port because he could make more power with them, plain and simple. |
#119
Marcella has the intake, it will make what it makes.
#120
![]() Quote:
I'm glad you are now the person in charge of dyno corrections.... You are one very intelligent person...no wonder you were able to run a 10.8 once! |
