#101
I really do appreciate being humoured. so was there nothing remaining of the section from the top of the water pump to the carb? this seems to be the point where I get confused - because some say the line should be on one side of the thermostat housing, while other sources cite the other side... Man I really got to see that black '70 at the museum some day! (too bad it's so stinking far from me!!)
#102
You should post your jack info in this thread. Quote:
So long, farewell. |
#103
Can somebody get Ransom another glass of milk -
think his got spilled |
The Following User Says Thank You to Baron Von Zeppelin For This Useful Post: | ||
#104
The door locks wouldn't operate with either the key or using the pull knobs, so Dan removed the panels and discovered the lock mechanisms were liberally coated with Ziebart rust-causing. So, a little PB Blaster on a rag with judicious elbow grease got them working properly again...maybe the first time in their lives, or when the Ziebart hardened.
The passenger side door handle still had the Deluxe Interior Trim color applique in the recess, albeit a little faded, but still there. The driver side was MIA. Dennis |
#105
Black is the new Orange
Dan got around to changing the air cleaner base color to semi gloss black. He didn't find the date stamp in the area you indicated HFR unfortunately. The paint came off easily with light bead blasting and a couple of coats of black semi gloss and its looking a bit more factory.
Today is checking the compression and cylinder pressure to see how healthy the motor is. Dennis |
#106
I just noticed that this has non-recessed wipers.
Nice work thus far.
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
#107
Dennis,
Just out of curiosity since the car has a lot of original finishes under the hood (air cleaner notwithstanding ), can you tell whether the hood hinges were originally painted black, or were they plated?
keith k 70 Trans Am RA III / T400 / Lucerne Blue / Bright Blue 70 Trans Am RA III / M20 / Lucerne Blue / Sandalwood 70 Formula RA III / M21 / Lucerne Blue / Bright Blue |
#108
Keith, were any ever painted? I always thought they were phosphate plated.
Better looking under the hood. Only decal for it is the Osborn piece, that I know of. Is the vent pipe curved like the repros? Master needs updating or at least painted black.
#109
Yes, I've seen many that were painted black (could have been an e-coat as well, but black nonetheless) -- not phosphated. That's an observation that's very specific to '70 model year Firebirds, however. In general, GM's practice seemed to have been grey phosphate.
#110
Dennis |
#111
Dan & I did a leak down test and static compression ratio checks cold and warm to see if there were any differences. The leak down was done cold, so will be 5-10 psi low...:
#1 - 175 #2 - 185 #3 - 175 #4 - 170 #5 - 170 #6 - 175 #7 - 180 #8 - 165 They all read steady and held pressure just fine. We think #8 in an anomaly. The compression test was done on the Katech Whistler both cold and warm (50 and 180 degrees motor iron temp). It appears this 400 has never been apart and at 47,000 miles had 10.0 to 1 cold and 10.5 to 1 warm compression...very interesting. The distributor still has its original advance weights and springs and has a very slow curve helping keep detonation at bay on 93 octane fuel. it hasn't been run on the street yet, but we are sure when at running temperature, it will need to be closely monitored for ping and detonation. It was also a nice day (50 degrees!) to take a couple of outdoor pics in the sun. Dennis |
#112
Does that passenger hinge have the '524' stamped on it?
Very nice to see a good 70 Formula.
#113
Dennis |
#114
Stamped.
On forward arm of hinge. Right above the pivot point on engine side of hinge. (about an inch above?) Same for driver side except has '525' stamped.
#115
Wow. Following!
#116
Here you go
#117
Thanks HWYSTR455! Following your new thread on your Firebird too!
Dennis |
#118
Thanks Craig! I just sent those pics to Dan to see he can find them on the hinges. Pictures are worth a 1000 words.
Dennis |
#119
Found the '525' stamp on the driver side hinge, but no stamp on the passenger side, though the hinge looks original.
Dennis |
#120
Dennis, all 70 hinges have this welded in brace
