Old 01-06-2020, 03:14 PM
Half-Inch Stud's Avatar
ROOTS blowers are bad like Domed Pistons, 2-speed trans, and spools; the worst on paper., yet the best in the right hands.
Procharger; 0.7 Sec ET imporved for running an intercooler is stunning at 8.2 to 7.50 level applied horsepressure.
Im Half-Wit enought to try the compressed air with a blow-thru carb.
  #102
Old 01-06-2020, 03:22 PM
GTOGEORGE's Avatar
Yea, my money says he made more improvements then a inter cooler to pick up all that ET.......kinda common sense!
People make comments without giving ALL the info.
GTO George
  #103
Old 01-06-2020, 05:12 PM
Tom Vaught's Avatar
Boost Engineer
Brian H would have to give you the Dyno Measured Compressor Discharge Temps when he ran the thing at Steve Morris Dyno. I do know it was over 300 degrees discharge temp going into the Carb Bonnet.
Now he has an intercooler with Water and Ice, a LARGE ONE.
Typical temps at the starting line with that type of set-up is 40-45 degrees.
You do the math HIS. There were other changes for airflow (Tony Bischoff changes) but the charge temps into the engine were a major problem for Brian for several years. F-2 Superchargers make a LOT of heat.
Course you should already know that.
Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post:
  #104
Old 01-07-2020, 09:44 AM
Tom, yea i have done the calcs for the superchager thermal rise; WE all get mighty concerned with thermal rise of beaten & compressed air!
There is a Fackebook joke of a Van with a roof-mounted Turbo; well the discharge pipe is sooo long that it may be a good intercooler ( several RT-turn elbows will harm momentum&velocity, but compare what an intercooler does to momentum & velocity.
IF our people would avoid momentum loss upon Compressor exit-to-Intake opening...goodness!
  #105
Old 01-07-2020, 03:51 PM
Tom Vaught's Avatar
Boost Engineer
As you know HIS, there is a thing called Charge Density and Charge Density when affected by Thermal increases IS affected. More lbs per min or Kg/sec and the HP goes upward. Simple Physics.
I could care less what some guy who put a turbo on the roof of his vehicle did
I do have a 351 Ford Van story for you though. He had a Ford Pantera style (engine between the seats vs just behind the seats Van). Engine was designed for boost and he put a large diesel Turbo on the engine. One day he came in with a piece of the driveshaft with 7 "spiral wound" turns on the tube.
Rev Limiter saved the engine when the yoke/driveshaft exited the vehicle on the dyno.
RW dyno, it made 570 hp and over 600 lbs/ft of torque, so easily over 600 hp at less than 14 psi of boost. That ended the dyno session.
Tom V.
