#101
Mike not yet, but we are going to make them.
George, yours are simple just make your own LOL !!!!
Don Johnston DCI MOTORSPORTS LLC 330-850-5050 shop 330-628-3354 cell Designer if the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!! |
#102
![]() Quote:
I've made 2 sets of Zoomies For me! ![]() GTO George |
#103
Any updates on the engine? Great post btw.
Oz
463 Stroker Kit. ross pistons. h beam rods. eagle crank. 62 heads 72cc, port matched Performer RPM-850DP Auburn- 3.55 gear CC HR custom grind |
#104
Should have an update soon. All Parts are in.
Steve |
#105
It's been a little while since I have posted an update on Steve's build, but Norwalk has really set us back. We just finished up Steve's heads and flowed one of his intake ports. Let me state that as we work with these heads we keep learning more and more about what they like. With that being said I think Steve is going to be real happy with the results. Steve is building a low compression deal for a future blower upgrade. So we decided on a street port for this build. My street port basically consist of blending the pushrod wing, opening the valve bowl up to .92 % of the valve and blending the bowls accordingly. I originally was going to use a 2.25" intake valve, but didn't realize that my cutter was loose and messed up the first seat I cut. So instead of replacing that seat I used a bigger valve. SO now Steve has a 2.32" intake valve. Here are the flow numbers for the intake ports.
Lift CFM .100 84 .200 155 .300 202 .400 258 .500 314 .600 367 .700 400 .800 418 .900 427 1.00 436 I will post the exhaust side once we get them flowed.
#106
Don, have you posted your all out race numbers anywhere?
#107
I have not because we haven't found the limit yet. I know sounds bold, but we are still finding more and more flow all through the range every time we play with them. So far we have seen almost 530 cfm with a 2.32" valve. To be honest though I don't think our little community is ready for that much flow. I'm not saying that sarcastically so please don't take it that way. It's just 90% of the guy's here are bracket racers and don't need a head of that caliber. For the all out guy's and class racers it fits, but they are far and few.
#108
Got the exhaust finished up and flowed and as promised here are the flow numbers. The exhaust is roughly 65 % of the intake flow which is what we shoot for. This is with a 1.70" valve and 93% throat. We have actually got over 310+ with more porting and bigger throat.
lift/cfm .100 67 .200 117 .300 146 .400 176 .500 201 .600 238 .700 256 .800 265 .900 273 1.00 280
#109
![]() Quote:
If so I may be changing my plans. SD |
#110
![]() Quote:
Thanks,
#111
![]() Quote:
Email is sspeedie@hotmail.com |
#112
Yes it does. I see your email in this post. So disregard my PM. Thanks
#113
Great looking build going on there. Thanks for sharing and best of luck.
Don Do you know what the turn around time is for say a 2" set of headers?
Jim www.raceV8s.com 1972 Trans Am drag car, 3300lbs, 468 ci, Iron D ports, 428 block, 9799103 crank, 9.48 @ 143mph, 6.0 @ 114mph in the 1/8th. |
#114
Coming Soon.
#115
RAV
#116
OK............STOP that, I'm JEALOUS!!
![]() GTO George |
#117
Don,
Whats the cam look like for Steve's build? How much lift is it using?
Carburetor building & modification services Servicing the Pontiac community over 25 years |
#118
![]() Quote:
It took one person to lift it. |
#119
LOL.
If it's not under the Christmas tree...It must be in the car and running?
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
#120
I don't like you!
