#101
While a production car is fairly level, a race race has more of a wedge shape to it. With a much greater ground clearance in the back than the front. Where do they measure ground clearance and how well will that work with this formula? Stan PS - This thread that I have been spending sometime posting in and maybe of interest to some of you. dynamic compression for the street. http://www.yellowbullet.com/forum/sh...1#post16089354
#102
1) You would like to keep the air out of the underneath of the car. Not having the air bang around on all of the suspension components and drive line stuff. The only way to do that is to minimize the air that gets under the car. 2) Air also can get under the car from the wheel openings. Most good front air dams keep the air from entering the wheel houses from the side. 3) So now if you limit the amount of air coming thru the grill to the minimum required for cooling (more road race vs drag race) you can reduce the air flow under the car quite a bit. 4) Air, by the time it gets to the rear edge of the door is starting to get dirty so having small deflectors at the front of the rear wheel openings might help on a street car or car with a very shallow tire/wheel depth. A Drag car has the tire sunk into the body pretty well so minimal rear tire impact contacting the air from the sides really. 5) Transitions from things like the windshield or doors to the body can make a difference in how smooth the car is going thru the air. So after saying all of that, if the rear of the car has more of a rake vs the front then, yes, so dirty air can eventually get under the car but the big deal is not allowing the air to get under the front of the car. Where does the cooling air from the radiator go, typically under the car, unless you have a Trans Am type side extractor set-up (which actually worked pretty well). Less air getting into the engine compartment, less air banging around on the firewall trying to act like a parachute that slows the car down. So the front of the vehicle is where the measurements need to be taken. Measure at the lowest point of the spoiler to the ground (if it has one). You can document the rake angle, (which we do) but the effect is minimal in normal testing. I built screw jackers to raise and the rear of the vehicle quickly, when it went into the wind tunnel. 4" difference in high rake vs low rake showed an effect but a small one vs the front height change of the vehicle. So a) measure from the spoiler to the ground and that area you subtract from the area calculated in the measurement from the ground to the top of the windshield. Also add the tire frontal area (footprint of the tire when looking at the tire at the spoiler height). Then do the math in the formula. Hope that helps with your question. Tom V.
"Engineers do stuff for reasons" Tom Vaught Despite small distractions, there are those who will go Forward, Learning, Sharing Knowledge, Doing what they can to help others move forward. Last edited by Tom Vaught; 02-23-2014 at 11:55 AM. |
#103
Thanks. As an aside. I see people try to save weight by not running inter front fender wells. How much of a negative effect would this have? Stan
#104
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
#105
I would have addressed you as well in my last post had i noticed this post first.
#106
[/QUOTE] Quote:
Belly Pans, sealed fender wells, etc can cause the underhood temps to skyrocket. Tom V.
"Engineers do stuff for reasons" Tom Vaught Despite small distractions, there are those who will go Forward, Learning, Sharing Knowledge, Doing what they can to help others move forward. Last edited by Tom Vaught; 02-23-2014 at 02:52 PM. |
#107
Ok....since air in engine compartment is brought up I'll ask the Engineers..
My 69 GP sits low to ground and has no inner wheel wells in it. My old 60 would trap air and create some problems...hood pulling/popping up and car moving around from 1,000' on(light in front)...at times.That was at 135-138 MPH... It had full sheet metal inner panels...I closed of grille off with Plexiglas and it relieved the situation. I haven't had any issues with the GP but have not made any full passes yet. Thinking of adding some small plastic sheets at lower rear of front fender opening...ala funny car style to keep air off firewall...possibly add a air damn if needed.. I think(?) this car will be capable of 150-155+ passes..don't want funny things to happen.. Any thoughts.. Sorry if this is off topic..
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
#108
The picture of your 69 GP shows a very small grill opening on the same plane as the headlights. That is good.
Can you post a better picture of the area below the bumpers as the picture is really dark in that area. First guess would be to put a spoiler on the front of the car that would divert air around the front of the car when the car is at normal track acceleration attitude. It might be real close to the ground when sitting but a bit higher when going down the track. Deal is to not make it so low you damage it after a wheels up launch if it comes down hard due to an aborted run. More pics please. Tom V.
#109
Get some tomorrow....Plus I'm not sure of front attitude going down track....just yet.. Want to check and see if Monte spoilers will work...and available?? Thanks
#110
Jack Gaydosh dynoed his Tiger headed IAII (535 I think) before he tore it down to freshen up at seasons end...on 12-30-2006...with many passes on it..I couldn't figure out how to post the D sheet ..it can be searched on here. It made1107 HP @ 7,200 854 ft lb @ 6,600 Seems he was deep in 7's too IIR.. Scott Rex doesn't say much but bet he's got a big number too.... Just saying.... FWIW: that cam is going in my new combo...
#111
#112
