#101
I took the break in the weather today to exercise the wagon a bit. Topped off the fluids and filled up the tank with premium fuel. Ran it for 20 minutes and drove it up the street then put it away. (Not currently licensed and needs a master cylinder) I checked the block code and found it to be a ZE stamped block, matching the code on the window sticker. I believe I will purchase the PHS to confirm the engine unit number matches the car. Anyone have a good ideas for a personalized plate for this thing? I currently have OHC 6 on my 67 FB and would like something unique for this one.
#102
[1 of 47]
This will always have onlookers ask ?
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. ![]() |
#103
STR6WGN Would be cool.
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files |
#104
OHC6WGN. 4BBL6
#105
How about 4bbl6wag
#106
All very good! Keep em coming!
The Following User Says Thank You to sprintbird For This Useful Post: | ||
#107
inline6
econowgn notav8 |
#108
LNGRUF6 ( Long Roof 6)
#109
Saw this today while searching something and thought of this post.
Look forward to seeing more of that little treasure when the weather gets nice ![]() ![]()
The Following User Says Thank You to Jeff Hamlin For This Useful Post: | ||
#110
Cammerwagon UPDATE: Over the last two weekends I did some work on the wagon, got some tags and put 125 miles on it. I did not go with anyone's plate suggestions, as I decided to go with YOM plates. I have a nice driver quality set that was issued to someone in my village, and think they look correct. I replaced the master cylinder with a reman and bled the front brakes. (original one was set aside for future rebuild) Then changed the oil/filter and fuel filter. The tailgate glass was getting scratched, so I decided to take the access cover off to see what was causing the problem. Found the glass tensioner had lost it's felt padding and had metal to glass contact. I replaced the felt, and swept out about 2 inches of pine needles, before putting it back together. Next I replaced the radiator cap and installed a new battery and my Y55 topper. New armrest pads came with the purchase, so I installed those, as well as plugged the door panel "holes" with vintage (1968) door speakers, courtesy of E-Bay. Cleaned the glass, and drove it off and on for two days. I have noticed that this vehicle has a shutter or drive train vibration when shifting from 1 to 2, (30 to 40 mph) or at highway speeds of 60 to 65. I am not sure if this is an engine natural frequency, or driveshaft issue, or something else. Is the ST300 behind the Sprint suppose to have a weight, similar to the manual trans optioned cars? I am going to get this thing on a lift and check it out closer. Any input/comments would be appreciated.
#111
More pix
#112
Man that thing is clean. Very nice
#113
I've never seen the Damper on anything other then the F-Bodies.
If you have a local Drive Shaft Co, I would take the shaft out and have it checked & balanced if needed. I had a similar issue and it did turn out that my shaft was out of balance. Since I had the DS done years ago I figured it can't be that and chased my tail thinking it was everything/something else.
#114
Totally take this personally..
I hate you! I'm just jealous of how clean that wagon is. ![]()
#115
The reason the 1 barrel wagons are rare is because they all got demolished head-on trying to pass someone. You got a nice ride.
#116
Sure glad mine survived! Must be because it has a 4bbl! (ha, ha) The plan is to take a look at the driveshaft and u-joints first. I spoke with a mechanic friend of mine and he has ran into a similar situation and it turned out to be a stiff u-joint. I will have it on a lift in a week.
#117
