#101
A couple of side by side shots of the old and new.........
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
#102
Keisler's video's show them feeding the bench bled hyd's through the bellhousing and when they finish the video they leave you with the slave cylinder hanging in the transmission end of the mounted bellhousing, unattached to anything. My question is HOW at that point would you attach it to the transmission since the bolts would then have to be started from INSIDE the bellhousing...which is mounted to their block.
#103
not sure why they'd show it like that? becareful screwing the line into the slave cylinder, real easy to cross thread it!
#104
Question...........
I'm nearly to the point of checking the alignment of the bellhousing to the crankshaft. Never having done this before I'm going by what I've read. Is it OK to check it right off the end of the crank or do I have to install the flywheel 1st? Most everything I read mentions taking a couple of bolts out of the flywheel so the base of the magnet sits flat.
#105
found the answer...........crank is fine.
#106
Another question.........
I have the clutch pictured. The picture shows both sides of the clutch disc. Which side faces what? The disc has no labeling and since your supposed to know what you're doing, no instructions.
#107
Pretty sure the spring side goes into the pressure plate. Buddy install one for me in my old Impala the other way and they rubbed on the flywheel bolts.
#108
the flywheel side should be pretty close to flat
www.fquick.com/Captainofiron 68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4 97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil 14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires |
#109
If you are using a magnetic base for the dial indicator, you might have a problem of trying to get a sufficient grip for the magnet on the end of the crank. We even had a slight problem with the flywheel on and getting the base where it wouldn't move as we turned the crank. I was thinking that a simple L bracket welded to a rod with a hole through it for the dial indicator might be a good solution. You cold bolt the bracket to the crank using one of the flywheel bolt holes. Then you would just drill and tap the rod for the set screw to hold the indicator in place. Either that, or bolt a flat plate across the end of the crank so the dial indicator would have a nice flat surface to mount on.
#110
Here's a picture of my dual friction disk mounted to the flywheel...
#111
Much appreciated, all of you. Thanks for the pic MrWrestlingII. I think I've got it now.
I got my OEM eBay pedals in today. I hope to get some paint on them tomorrow after work. The bushings feel great so I think paint is all they need, and the new rubber that came with the Keisler pedals. Performance Years has new chrome pedal surrounds headed to me also.
#112
David,if that is a plastic spline,try to borrow a input shaft from a trans.WAY more accurate.Tom
#113
I thought that motor was staying in the car? This one must be for another car?
1969 GTO 4spd. Antique Gold/black, gold int. 1969 GTO RAIII 4spd. Verdoro Green/black, black int. 1969 GTO 4spd. Crystal Turquoise, black int. 1970 GTO 4spd VOE Pepper Green, green int. 1967 LeMans 428 Auto. Blue, black int. |
#114
on the newer transmissions its pretty easy to pop out, like on the T56 its just a matter of taking some bolts out
#115
I am interested in how this turns out. I have a pre-production RS600 in my GTO for about a year. No cutting compared to the TKO and smoother. It is a little balky going into reverse but that was common to the Borg-Warner T5 it's based on. I knew Shafi had many delays from component suppliers on the RS parts but I didn't know the wait was still that long. From what I remember about the TKO, you will need to change to the manual trans tunnel as noted but you may not have to modify much from there if your body bushings are good enough to provide clearance.
Good luck with the install and IM me if you need more support from Keisler.
1970 GTO 400 Atoll Blue, PS, PDB, A/C Was M20 4 speed, now has Keisler RS600 5 speed. |
#116
My motor is in the car. I just posted MrWrestlingII's picture, full size. Easier to see.
#117
Thank you Mark.
I plan on being as gentle with the cut-off wheel/jig saw as I can. The plan is to lift the trans into the tunnel as close as possible and then I'll mark where I need to cut versus just whacking the trans tunnel wide open and then covering it back up. My cut may indeed end up being huge, I'm OK with that. But. I have some ideas.......... My body bushings are basically brand new. I replaced them about 6-8 years ago but the car has only seen 10-15,000 miles since then and hasn't spent the night outside.
#118
Latest progress is the used OEM pedals I bought arrived and I took them apart, cleaned, painted, chased bolts threads and lubed them.
I also discovered that the passenger side block dowel pin was in way to far. The block plate would sit on it but there was nothing for the bell to sit on. I've posted a thread looking for idea on that dowels removal. It will move some with vice grips attached.
#119
Nice. Did you paint or plate the bracket?
#120
Rust dictated that I paint it. Rustoleum silver metallic. I really hated to do that since the originals were not painted. I was amazed at how nice the bushings/pivots were considering how worn the pedals and pedal surrounds were. Can't wait to try to work all that metal back up under the dash.
