#101
I will look and see if I still have the vid of my car doing a 600 ft burnout with 2:73 gears and a mild 455 with no brake stand. I always figured it was because there was so much tq once the tires were spinnin they were goin 150mph with the tall gears and the car never had a chance to catch up. Mine did have skinny tires on it though? I loved lighting the tires up at 30mph and scaring the **** out of ricers!
#102
That's strange...
As I recall, all base auto with a/c '68 GTOs came with 2.93 or something close to it and they'll certainly spin the tires with ease from a dead stop or a slow roll and no power braking. Maybe your experience is with Chevies that have to rev to make power?
Greg Reid Palmetto, Georgia |
#103
#104
Not to gang up on you 67ramair4, but the mostly stock 76 350 that was in the car prior would spin the tires. A dyno run right now would only tell me how much power I wasn't making and piss me off.
67 Firebird Convertible - SOLD 80 Firebird Formula Turbo |
#105
There must be something wrong with me, I'm considering using a 3.08 with a 200-4R for a street/strip combo.
It sounds like guys whose cars with long gears aren't quick, should be checking them out to see why not.
Rich The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance. Henry Ward Beecher "The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher |
#106
A 2.93 gear, 2200 stall converter of unknown origin and a cam with plenty of duration- seems to me this might not be a combination with enough bottom end grunt to spin the tires. But if not, that engine still ought to be making plenty of power up the curve somewhere!
I (like many others) keep on checking on this thread to see if the results of the cam degree check are in yet...
1969 Lemans vert, matador red, 462 CI, 3.07 12-bolt posi 1974 455 TA, admiralty blue/red interior HPP "cover car" - sold "The best way to show a car is to drive it" |
#107
my tired ole 400 with a lil better than stock cam cast pistons 6x8 heads with years of abuse with 273s would not only breakem loose a bit at 20mph roll but from a stand still i could do a 100mph burn out once those tall gears break the tires with lil effort after words you can boil them pretty good. i dont see a dyno doing any good......in fact i could see how that would piss the owner off to see what amount of power he is not making...lol that comment was funny when i read it
http://performerrpm.myphotoalbum.com/view_album.php? |
#108
i certainly don't think your rude to ask! we have multiple people familiar with pontiac power noticing a power loss. i've got 2.78 gears and will 'boil' the (one!) tire right off the rim if i kept my foot in it. if you lack torque in a poncho, something is amiss.
John J. |
#109
The accessories are off the front and of the engine and out of the way. I'll be degreeing it this a.m. I had to make a run to Dallas all day yesterday to get transmission cores/parts.
I'll post the cam results later today. Unless I've missed something pretty big I'm 95% certain the cam timing is off.
www.jakesperformance.com Racing Automatics and LSx Engine components |
#110
Pictures of cam off
I have installed a couple of cams in a Pontiac, and once we had a timing chain that had a imperfection that looked like a dot. Car didn't run. SO I would like to see one that might be wrong. Thanks
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files |
#111
I have a 2.73 posi rear out of a 71 cutlass or other Olds.. in my 67 GTO, TH400 original 400 mildly built 25 years ago, 65 tripower.. I can smoke my tires from a standstill and get some scratch going into second.
-- James Work '67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake." '75 Formula 400 - Daily Driver - Running with my Home Built 455 and TH400 Details here: http://forums.maxperformanceinc.com/...d.php?t=588372 |
#112
On the subject of burnouts, my old 400, with 6X-8 heads, small Crower 210/221/112 cam, stock converter and 2.73 gears would do a burnout all the way thru first gear.
It ran as quick as 13.78 @ 101mph in that configuration. One would think a mild 455 with a roller cam and some compression would melt the tires down with a blip of the throttle?.....Cliff
#113
I recall somewhere on the internet was a link about how power productions change when a camshaft was installed 20 degrees off. They dyno'd the engine before and after.
Wish I had that link, that would be great to see in this thread. It had dyno chart pictures, I believe it was a buick engine.
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane |
#114
I'm referring back to the thread to get the cam so I can look up the specs.
Current status is that the timing mark on the balancer is within 1* of correct.
#115
We have 2* BTDC for .050" opening, 38* ABDC for .050" closing.
This tells me the cam is 4* short on the intake side but it's pretty close on the cam install. We could be off 1* on the wheel easily since it's relatively small diameter. We're going to check the exhaust side so we can confirm.
#116
Jake,
Here is the link to the cam specs if needed http://www.compcams.com/Cam_Specs/Ca...csid=1216&sb=0
#117
Intake center line
I think it would be more helpful to measure the intake center line over the initial timing events. The ICL is what is usually looked at for cam timing. Your cam probably had this information with it for installation. If not, someone familiar with your cam can probably tell you where to degree it in off the CL information over the initial events.
Make sure you have TDC and zero degrees set accurately using a piston stop. You can rotate motor back an forth and move pointer until the two values when hitting the stop average zero. Check it a couple of times to make sure. Set pointer on Zero. Now, remove stop and by only rotating in clockwise direction (keeps the chain tight) rotate the motor and zero the gauge (rod nearly fully compressed) on the peak lift of the #1 intake lifter or lobe (4th lobe back). Now rotate again and record the 0.05 degree before peak and 0.05 after peak. Add togeter and divide by 2. This is the intake certerline. Usually at or about 108. |
#118
whoops
Your cam should be at 106. With the initial even 4 degree off, if the CL is 4 degress off, you have your problem.
#119
I've degree'd a cam or two Although I mostly build performance transmissions these days I'm a Master Auto Tech, Master Engine Machinist, with other certs (L1). I determine ICL by where the .050"events happen. There are other methods but because of the assymetrical cam lobes you get into, you can't assume it's exactly centered on the events. Exhaust events are 3* retarded. 46* BBDC and 4* BTDC. The cam timing is not the issue. 3* is not "staight up" but it's also not a deal breaker. Timing chain may have stretched since initial build as well.
#120
I doubt it...
