#101
The way I deduced the one HP per Cubic Inch Theory:
1) I Have 376 HP to start. 2) Cold Air Induction, according to my poor memory gave an extra 28-30 HP by a Formula process, I wish I could find that Formula. 3) 376 HP is a 1967 428 ci Engine on top of the Quadra- jet Carb. 4) I give the 428 ci a HP rating 390 on top of the up-jetted Tri-Power Carb. set-up! 5) With MSD Multi-spark Ignition, Dual Headers and Exhaust, upgraded to "041" Cam and Electronic Distibutor is the best it can run, all adds to 8 HP. 390+30=420+8= 428 HP About? As I said, I would think this Motor could develop 428 HP (NOW) with the New Internal parts I have installed because it runs like it is New. Also, since I bought this Engine second hand, I have" not" had the Heads off yet. It runs too good to mess with. This Engine was said to be Stock, but then again why did it contain a Tri-Power Cam and Intake Manifold and 1966 Tri-Power Carbs off a GTO? Yes, according to my research these Carbs. numbers they were used on the GTOs. Let's figure That the Tri-Power Intake Manifold is not Ported or polished at all, what is the CFM Flow then? Last edited by TRADERMIKE 2012; 11-07-2021 at 01:42 PM. |
#102
Got around to taking a pic of my engineering 303 std deck 1970 4 bolt block.No EUN,vin or code.
#103
wonder where the other 5 went?Have never seen another.Tom
#104
Mike,your way off on your thinking!Grasping at straws.JMHO,Tom
#105
Mike wants to know: "Is that one of those rare Ram Air five that, I think Pontiac Decked the 389 or 400 ci Blocks to make"? Used in Trans AM. https://www.flickr.com/photos/thehen...57632984338619 Here are some fun videos to watch the old Trans Am cars. |
#107
#108
Ram Air V - yes Decked 389/400 - no. The 303 was made in short deck and standard deck versions. This is a standard deck meaning the deck height is the same as 389/400, but it’s reinforced and special. Used in Trans Am series - it was intended for it, but program was killed before they could meet production requirements for homologation.
Hoping to finish a project while I'm still able to push the clutch in.... 1963 Tempest Convertible (195-1bbl, 3-speed transaxle. 428 RAIV, 5-speed, IRS planned) Pictures |
#109
303 = 303 ci DS = code 06= 1966, as you say it is a replacement Block for 1966 cast in 1970 Sideways "J" = Place Cast or assembled. I will have to visit my Archives that I saved from John Wallaces site on the subject of the Ram Air 5, 6, 7. Above is the way I think it reads; I could be close with all the research on the topic. If I look at the 1961 service manual, I might find the sideways "J" actual Plant. That is where I found my sideways "P". Last edited by TRADERMIKE 2012; 11-07-2021 at 07:48 PM. |
#110
I think with a true 10.0 static compression ratio with your 670 heads, headers, a dialed in '66 Tri-power, and the 041 cam installed at 109 degrees would make 1 hp per cu. in. easily. That cam needs compression to work well and I wouldn't go any less than 10.0 to 1. Dennis |
#111
Guys,std deck 303s used RAIV heads and a warrior intake.Its a 70 4 bolt block with 9799914 casting numbers!A DS block is a developmental block.Its a 70 block!Tom
#112
366 block,also used RAIV heads and Warrior intake.
#113
Alu 1961 Developmental block
The Following User Says Thank You to tom s For This Useful Post: | ||
#115
303 SCCA short deck true RA V block,#18
#116
Factory 1970 alu RAV block
#117
400 RAV block #5.
#118
That is the next block up then there is the 428 ci version. 303,366,428, 455?
#119
I have others around somewhere.Tom
#120
Tom, thanks for the pictures of all the ultra cool blocks and other parts you have. It has always amazed me the rare stuff you have collected! I'm even more impressed that you're not just a parts collector. You actually build engines using the rarest of the rare, and then share the results. You da man!
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
