#101
Sorry to all about the side track
Back to topic Congratulations to Big Chief breaking into the three second zone! Awesome achievement! I'm glad your basic, standard pushrod location E-heads got the job done. Also quite the achievement dragging those Hemi and 481X (LOL) heads down the track... Not easily done. It sucks you can't keep up with all the better Pontiac heads that are out there...like the Tigers, the Hi-ports, etc. Disappointing you already went a bunch slower with all those other more expensive heads... I'm sure it was a suspension issue from all the extra power. PS....if you need to up your game I would suggest reaching out to a guy on the West Coast named Dragncar. He is incredibly smart and knows all the ways to make big power...he even ran 10.80 once. PPTFMF!!!..... 481XLOL |
#102
Post of the year.
The Following User Says Thank You to Mike Davis For This Useful Post: | ||
#103
Also if he doesn't have a clue he'll just make something up and pass it off as fact. That's what makes him so smart
The Following User Says Thank You to slowbird For This Useful Post: | ||
#104
It was my understanding that's the head stud in between the two exhaust ports would crush after repeated torquing's. Has the newer casting from Edelbrock been fixed? And if its still a problem how many sets has Chief gone through? He has more passes in one year than over half this board combined, me included Ha
What about his head gasket life?? I believe he was dry decked, copper gasket and double O rings at one point. |
#105
Head gasket sealing is easily resolved by using the AP sealing rings which I believe were designed by Marty Pablikin (sp) and his team. Last edited by PAUL K; 12-10-2019 at 12:44 PM. |
The Following User Says Thank You to PAUL K For This Useful Post: | ||
#106
Fastest Pontiac
A lot of discussion and disagreement on the fastest Pontiac-powered door slammer. Not a door slammer, but here's the fastest Pontiac-powered car so far. ET 5.87 @ 250 mph. I was lucky to be there for this run.
https://www.youtube.com/watch?v=qC1zgMhSHcM
#107
IMO your know how came off the backs of others, one click away from dishonesty. Not sure how you get anything done, you must monitor PY Race 24/7. No one is a bigger fan of Justin and what he has done with little E heads that I. Yet you want to make it like I am ripping on him. Remember that "gasslighting" term ? High Ports and Tigers are not great Nitrous heads, everyone knows that. Twin turbos do very well with smaller heads. There are guys putting out 900-1000HP with single turbos on stock blocks, 400 cranks with as cast D ports and log manifolds. Your turn. |
#109
Stan
The Following User Says Thank You to Stan Weiss For This Useful Post: | ||
#110
You shouldn't question him. He knows everything.
But it does make you wonder why BES choose Tigers to use on nitrous engines if they're such a bad head for it. |
#111
Leave me out of the p*ssing match, but our experience with the Grocery Getter was that switching from e-heads to off-the-shelf Tigers was worth 150 hp NA on the dyno and time slips suggested that same gain carried over to the nitrous use.
We're lucky to have so many choices for Pontiacs and I wouldn't hesitate to use e-heads for many applications.......but not every build. Eric
#112
It's a great time to be into Pontiacs. We have several choices of good heads and each one shines in a different arena. Sometimes I wonder where our hobby would be if it wasn't for the aftermarket offerings. Had everything stopped with the Wenzler heads and no aftermarket blocks.... |
#114
You dare question the "Great Dragncar" ? You do know he went 10.80 once?....I'm sure he waisted at least an hour of an unsuspecting vendors time to get that opinion and the fellow on the other end just agreed to agree to get him off the phone.
He also has a chit ton of experience with Tiger heads and power adder combinations....at least he owns a set of Hi-ports and his best friend Gach bought a nitrous system once...just never used it. Last edited by PAUL K; 12-11-2019 at 09:55 AM. |
#115
Ray Cox also ran good with Tiger heads on spray.
#116
Eric
#117
#118
Since this thread is about The Crow, he isn't running nitrous anymore (as far as I know?), how much better would the Tiger head be than the Ehead for turbochargers?
I would think a bigger port and possibly a bigger chamber would be able to cram more of that power making mixture in there for each combustion event? Instead of a boom you could get a BOOM? (about like nitro)
#119
GTO George |
#120
I have no idea if Chief uses nitrous. Sometimes turbo combination use nitrous to make up for turbo lag. |
