#101
A few people mentioned this besides Bruce so at least we know he isn't the only person who knows how to spot potential problems. Not saying there is one yet but testing will find out. That port looks good Calvin!
Car Craft Garage. Automotive Restoration |
#102
Ps I call Bruce a knuckle dragger with love! lol
Car Craft Garage. Automotive Restoration Last edited by GREATGTO; 11-15-2011 at 08:29 PM. |
#103
Calvin, did you keep the port kinda square so it can be used with an existing intake rather than going oval which may need a whole new intake or one with heavy welding to work?
#104
If I was a smart guy, I would change direction of this head by moving the valves, the rocker placement and design a port to bolt on to current E-heads owners. Calvin Hill Hill Performance / Mondello Tech Center 708-250-7420 |
#105
#106
We have that head, its called the High Port
#107
Great....gto... I appreciate positive acknowledgement but it does none of us any good when we do so by knocking down others. Dont let passion or emotion for things put you in a place you dont belong. Not much you can do about past arguments and such. Put those away best you can and move forward. Nothing wrong with taking a stand for what you believe in but try to do it in a more constructive way that reflects the good in you.
Too many things in life far more important. Aint none of us perfect. We all slip once in awhile. There's an old old book that tells us that. Its worth reviewing from time to time. I'm looking out for you brother. |
#109
Ceralli or Johnny or anyone watching this thread, do you have the beginning runner area of the as cast Tiger intake? Even though my roughed in port is designed/sized within the casting of the Victor, I believe that manifold is fairly small for a +400 cfm port.
#110
Jim ,will post tomorrow from the shop,got CRS ,watching from home.Bill C.
Checkered Flag Machine & Ceralli Competition Engines Racing engines and induction development http://www.checkeredflagmachine.net/ |
#111
Jim, If you mean port opening, it is 2.600 X 1.300 as cast. The port is tall and narrow at the opening and gets wider down stream.
Don Johnston DCI MOTORSPORTS INC. 330-628-3354 cell 330-850-5050 shop Designer of the DCI Tiger Heads and the NEW DCI Ram Air V heads !!!! |
#112
Forgot to mention the 12.6 degree port I am playing with that I got 428 cfm out of is 2.300 X 1.300, and the 390 cfm port is 2.300 X 1.100. I think that with what you and Calvin have will easily surpass the port I have. It looks like in the photos anyway, that your port openings are around 2.650 X 1.400. My csa at the opening is only 2.99 and that would make yours if I'm close around 3.700. The Tigers are 3.38 csa at the opening. Looking good!!!! I think I might open up my 428 cfm port and see what it can do. I need to pull a mold from it first though.
#113
Its kind of interesting to watch the transformation from " I can't, it will not happen, not possable- ect, ect" that the thread started with ,to HERE IT IS in such a short time, it just proves that when some one is willing to "invest" a little time and effort stuff can happen very quickly. To those that are contributing - thank you.
#114
I like the shared info too. NOW is the time to find things to address and prevent things that might come back later to hurt the program.. |
#115
Don thanks for posting...I'll take your port opening dimensions of 2.600 x 1.300 as the head flange numbers. Sorry for the confusion but I did mean the beginning runner area at the plenum of the Tiger intake. Not sure if the as cast intake has +7 sq inches.
At this point these are quite a bit less than 3.38 sq in. at the flange. Avg Velocity of 420cfm through a 3.38sq in opening would be right at 300ft/sec...From all indications we have that number would work real good. |
#116
Jim ,the Tiger manifold is .050 smaller all around than the cast head port entry,but has lots of material to open crossection,Manifold runner crosssection is 4.5 sq-in at the plenum.Bill C.
#117
Tom Vaught
#118
Yeah Tom that number still works good after all these years. To some its like an old classic.
#119
adequate plug cooling requires careful consideration of surrounding liquid and solid thermal conductivity coefficients for proper cooling. per suggestion, arbitrary plug placement wont cut it in most castings, although SOME latitude of placement can be gained from proper thin wall design around said areas for air cooling. at best, it is a compromise. jim |
#120
We should be able to post final flow data and final pricing by the end of next week, at this point we have a head flowing: 216 cfm @.300 347 cfm @.500 441 cfm @.700 Thanks. Calvin Hill Hill Performance / Mondello Tech Center 708-250-7420 |
