Old 02-01-2015, 12:10 AM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Originally Posted by dci View Post
Parts are finally starting to come in for your heads Ed. Here are the custom order valves.These are from Victory in North Carolina and look like jewelry. Intakes are stainless 2.28", 11/32" stems, 6.450" long, exhaust are a super alloy 1.68", 11/32" stems, 6.450" long. The custom made exhaust guides should be here any day. I'm hoping today!!!
Excellent new Don, looks like we're making great progress on all fronts.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1022
Old 02-02-2015, 11:08 AM
dci dci is offline
Here are the guides I had made for the exhaust side of your DCI RA 5 turbo heads Ed. These are made of 4140 steel and I am going to install a bronze liner. I had the guides made with a little step or retainer at the bottom to trap the liner in case it should come loose. It's not really visible in the pic's. The bronze guide is what I normally install in my heads and is what I will install on the intake side for your heads. The car is looking AWESOME!!!!
ID:	389163   Click image for larger version
ID:	389164   Click image for larger version
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
Designer if the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!
  #1023
Old 02-06-2015, 10:09 PM
67'7F6'Bird's Avatar
The 69 Firebird is coming along Nicely.
Differential is almost compete with axles and brakes being installed, too.
Chromoly Drive-shaft Tunnel being Fabricated.
Steve
ID:	389542   Click image for larger version
  #1024
Old 02-19-2015, 03:03 PM
Hi Don,
Any Pictures and Updates on Eds DCI Ram Air V Heads?
Steve
  #1025
Old 03-17-2015, 12:34 PM
dci dci is offline
I don't have a lot of pic's of Ed's heads right now, but here are a few. I am starting to build his headers hopefully next week and I will post pic's of them as we progress.
ID:	392993   Click image for larger version
ID:	392994   Click image for larger version
ID:	392995   Click image for larger version
ID:	392996   Click image for larger version
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #1026
Old 03-19-2015, 01:01 PM
paris pugliese paris pugliese is offline
Default Turbo soft chamber
Softened up the chamber a little .
  #1027
Old 03-19-2015, 01:03 PM
Softened chamber
  #1028
Old 03-19-2015, 10:25 PM
RAMAIR RICK RAMAIR RICK is offline
Paris, the porting and combustion chambers are looking very nice!
Ed, I bet you are getting excited about your heads are coming together for you as well as the rest of your car!!
  #1029
Old 03-20-2015, 09:13 PM
Header Location has been determined. Its looking Sweet.
Is anyone else thinking a good nickname for this "69 Bird" would be "RAVEN" because in the Wild it attacks "THE CROW."
ID:	393326   Click image for larger version
ID:	393327   Click image for larger version
  #1030
Old 03-21-2015, 07:39 AM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
That's a lot to bite off right there.
First Pontiac powered street car in the 7's
7.940@170.84. 3460#s
  #1031
Old 03-21-2015, 07:48 AM
Hooter's Avatar
Hooter Hooter is offline
I'm a novice on all this stuff, but any concerns with the front plate acting as a big heat sink with the exhaust running that close around it since it will be street driven?
67 Bonneville ragtop
  #1032
Old 03-21-2015, 02:33 PM
See below.
  #1033
Old 03-21-2015, 04:13 PM
Steve and Ed, I really like that name, RAV'en.
That is a cool way of thinking outside the box!
  #1034
Old 03-21-2015, 04:36 PM
LiL Jack's Avatar
Talking
See below.
That's cute.
I'm a big Baltimore Raven fan.
  #1035
Old 03-21-2015, 04:42 PM
That's cute.
Or we Call it "The Beat Jack"
  #1036
Old 03-21-2015, 07:14 PM
LiL Jack's Avatar
I'm pretty sure that's going to be a lotto chew on too.
  #1037
Old 03-21-2015, 09:35 PM
RAIV-Z's Avatar
Alright, let’s get the car and upgraded engine finished and down the track a few times before making any wild claims. We all know how these threads turn out when individuals get a little too over confident before any actual track time.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1038
Old 03-22-2015, 01:05 PM
Tom Vaught's Avatar
Boost Engineer
I assume that they made the header collectors fit tight to the front plate to help with the turbo exhaust fabrication. Easy enough later to open up the 'pass-thru' holes to .250" larger vs the collector at that spot (to take care of vibration and heat expansion changes) and also add cooling slots to the plate to get some airflow behind the plate for street driving.
It will be a "iterative process". Interative Design is an approach of incrementally developing and refining a design based learning over time.
Tom V.
  #1039
Old 03-22-2015, 02:17 PM
cgeise's Avatar
cgeise cgeise is offline
Watch that area carefully Under boost those headers will be glowing red -- be ready and plan ahead
  #1040
Old 03-23-2015, 09:32 AM
dci dci is offline
Well said Ed !!!! I don't want anything to do with anyone pounding their chest especially before we have any data to back it up. This combo has the potential to lay down some impressive numbers when all sorted out, but it is going to take some time. I know Ed and his team are going to do whatever it takes to get it done, but I also know he has a long hard road in front of him. Turbo cars by far have the advantage when it comes to making big HP and Ed is doing it right. Although he has had a couple of bumps in the road already. I talked with Ed's chassis guy and he is no back yard builder. So I'm confident he knows that the headers passing through the front plate will need clearanced. He just made the holes in the plate to locate the collectors where he wants them end up for everything to fit properly. We are building the headers and he doesn't want to have any fitment problems when he does the final assembly. Ed's already been down that road !!!!
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
