Old 07-03-2017, 01:25 AM
TransAmRIP's Avatar
TransAmRIP TransAmRIP is offline
Originally Posted by dpoltzer View Post
Looks awesome RIP, Now you just have to get some paint on the car!!
Hopefully next couple weeks.
  #82
Old 07-09-2017, 05:25 PM
TransAmRIP's Avatar
New fire wall padding installed along with the heater box and restored pedal assembly.
ID:	458410   Click image for larger version
Name:	pedal assem.jpg
ID:	458411   Click image for larger version
Name:	pedal install.jpg
  #83
Old 07-10-2017, 11:35 PM
TransAmRIP's Avatar
Progress update:
Installed the power brake booster assembly and the heater box fan motor. The fire wall was left untouched from original. It cleaned up very nicely and I wanted to leave as much originality on the car as possible. It has some faint grease pencil markings and some runs from some sort of sealant. Hopefully by the end of the week I can mount the sub frame to the body.
Bub
ID:	458519   Click image for larger version
  #84
Old 07-11-2017, 11:37 AM
77 Canamman's Avatar
Is that a reproduction booster sold through Inline Tube?
If so, did you have to massage the mounting holes to make it fit?
I'm dreading this procedure on my car.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
  #85
Old 07-11-2017, 11:48 AM
TransAmRIP's Avatar
It is and it went right in with no problems.
  #86
Old 07-11-2017, 12:16 PM
Bub,
Thanks for the feedback.
  #87
Old 07-11-2017, 04:01 PM
TransAmRIP's Avatar
I was wondering how long it would take me to get past "Post 666" I don't anymore fire breathing down on me!
  #88
Old 07-11-2017, 05:57 PM
TransAmRIP's Avatar
White wire loom? There seems to be a 3' section of what appears to be white wire loom on the wire harness. As you can see by under one of the labels it's white. Is this correct? If so the inside diameter is 5/8" which I cannot find anywhere and would like to use the same diameter and color. Anyone know where I can get some from?
Bub
ID:	458591   Click image for larger version
  #89
Old 07-13-2017, 11:30 PM
TransAmRIP's Avatar
Progress
ID:	458737   Click image for larger version
ID:	458738   Click image for larger version
  #90
Old 07-14-2017, 07:57 AM
pontiacstogo's Avatar
pontiacstogo pontiacstogo is offline
Looking good!
Peter
1974 Trans Am, 400 4-speed, 3.42 rear.
  #91
Old 07-15-2017, 11:09 PM
TransAmRIP's Avatar
Originally Posted by pontiacstogo View Post
Looking good!
Thanks Peter
  #92
Old 07-15-2017, 11:13 PM
TransAmRIP's Avatar
Wasn't happy the way the dash/cowl paint came out so I resprayed it. Now I'm happy with the outcome.
ID:	458814   Click image for larger version
  #93
Old 07-16-2017, 08:56 AM
Held for Ransom's Avatar
Bub
http://www.forums.maxperformanceinc....d.php?t=510372
  #94
Old 07-16-2017, 11:23 AM
dpoltzer's Avatar
dpoltzer dpoltzer is offline
RIP, your cowl area paint looks great! Nice work. Just one thing to consider: the paint appears to be a bit on the glossy side which could cause a bad glare on the windshield when you are driving. This can be annoying and a bit dangerous at times.
1970 T/A
  #95
Old 07-16-2017, 11:38 AM
TransAmRIP's Avatar
Thanks HFR
  #96
Old 07-16-2017, 11:44 AM
TransAmRIP's Avatar
I painted it with a satin sheen unless the camera gives off as real glossy. It looks pretty low lustre in person.
  #97
Old 07-16-2017, 03:27 PM
77 TRASHCAN's Avatar
Progress update:
Bub
Wow, I'm installing a new heater core in my car (in the process, it's a big job). My heater hoses come out way over on the passenger side, under the fender. A major ordeal, if you are just changing out the heater hoses. I can see your car would be quite a bit easier!!!
Look' good!
Shut it off
Shut it off
  #98
Old 07-16-2017, 05:41 PM
dpoltzer's Avatar
Probably was just the camera then, which is great! Carry on RIP!
1970 T/A
  #99
Old 07-16-2017, 07:41 PM
TransAmRIP's Avatar
In process of restoring my steering column and was able to high lite the letters "LOCK" portion where the key goes in with a Krylon silver leafing pen.
ID:	458868   Click image for larger version
ID:	458869   Click image for larger version
ID:	458870   Click image for larger version
  #100
Old 07-17-2017, 08:53 PM
dpoltzer's Avatar
Nice touch using the silver leaf on the "LOCK". Great work.
1970 T/A
