Old 02-18-2016, 01:45 PM
Uncle Judge's Avatar
Uncle Judge Uncle Judge is offline
Correct fan and pulley?
The whole unit certainly looks original and correct. I just do not recall seeing those numbers stamped on a fan or the circular openings between blades. I have seen more uniform slots between the blades. Who knows? Multiple vendors for the same parts. I will look at a couple of 927's that I have and attempt to post photos.
I guess I had 3 of them. All appear to have the same fan.
ID:	421235   Click image for larger version
ID:	421236   Click image for larger version
ID:	421237   Click image for larger version
ID:	421238   Click image for larger version
  #82
Old 02-18-2016, 02:17 PM
Here is an NOS fan that I have that has the round openings like your fan Mike.
  #83
Old 02-18-2016, 02:54 PM
Judge273's Avatar
Judge273 Judge273 is offline
Thanks Jeff, that's a good analogy.
Mike/Illinois
  #84
Old 02-19-2016, 02:43 PM
Judge273's Avatar
Seats complete...
Mike/Illinois
  #85
Old 02-19-2016, 05:18 PM
OVERULD's Avatar
OVERULD OVERULD is offline
Wow! Those look great Mike!
BJ
  #86
Old 02-19-2016, 06:23 PM
Mike Kasparian,Sr.'s Avatar
Mike Kasparian,Sr. Mike Kasparian,Sr. is offline
That look great Mike , makes me want to put factory seats back in mine .
505 CID, 3560 lbs,Tiger heads, NA.
8.99@149.8 mph, 1.29 60', stock suspension
  #87
Old 02-19-2016, 06:41 PM
Judge273's Avatar
Thanks Mike and BJ,
I bought those seat covers when I bought the Judge about 15 years ago. Not sure how long Jeff had them.
Bought Mike's 71 Saddle seats out of his Avery first car, and he still races it. Took the seats out long time ago and decided to sell. I had new covers done professionally over the frames. Put new foam, and added more padding..etc..
As usual more work than thought. But, the results are awesome.
Plus, I still have my original Judge seats with the roach burns in the rear seats and all...
Mike/Illinois
  #88
Old 02-19-2016, 06:45 PM
Bentwheelbob's Avatar
Mike - I would try degreasing it, gentle buffing on a soft wire wheel, and then satin clear coat. Won't hurt to try before sending it off.
  #89
Old 02-19-2016, 07:12 PM
blue71ta's Avatar
blue71ta blue71ta is online now
Talking Good one
LOL, just about spit my beer out on that one! Reminds me of some things found under the rear seat of the '70 Monte I had in high school...guess that's why the windows were tinted by the previous owner.
Black Comfortweave always looks so rich; very nice.
  #90
Old 02-23-2016, 05:07 PM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
I'm guessing this Alt was buffed out and then sprayed with a satin clear? Any particular brand soft wire wheel you used to buff with? Where did you purchase it? Nice job, very well done!
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
  #91
Old 02-23-2016, 10:43 PM
Just the fan, pulley, shaft, bolts and nut. It's a Weiler wheel with .006" crimped wire. Most wire wheels are .014". I have a pedestal grinder set up with both and use the fine face wheel on more delicate things where a better finish is wanted, or when I'm trying to preserve original plating.
  #92
Old 03-04-2016, 07:54 AM
Judge273's Avatar
More primer pieces...
Mike/Illinois
  #93
Old 03-04-2016, 11:35 AM
1beautifuldaughter 1beautifuldaughter is offline
Looks good,,,,,,,Wheres your respirator?
  #94
Old 03-04-2016, 01:18 PM
SD455DJ SD455DJ is offline
Mike...looking good! Are you shooting for any particular date of event to have it done?
Dennis
  #95
Old 03-04-2016, 03:23 PM
77~T/A 77~T/A is offline
So you just blocked the original color down and then put primer on it and blocked that down?
Sent from my SM-G920P using Tapatalk
  #96
Old 03-05-2016, 08:12 AM
Judge273's Avatar
Needed a new quarter and wanted to match the paint all over. That's the best way to get that result. Plus new stripes...
Mike/Illinois
  #97
Old 03-05-2016, 10:14 AM
6TEE8GTO's Avatar
6TEE8GTO 6TEE8GTO is offline
Awesome Mike...! Missed this topic somehow...
GREG'S GOATS:
1970 GTO Judge
RA-III, 4-SPD & A/C. Power Windows, Power Seat, Power Brakes, Steering, AM/FM, 8-Track, Formula Wheel, Rallye Gauges, Remote Mirror, Numbers Matching. Assembled at Pontiac, MI Plant 5/26/1970.
1968 GTO
461 CI, RA-III heads, Hotchkis springs, UMI suspension, Bilstein shocks, 12-bolt 3.73's.
1966 GTO Ragtop
4-Speed, AM/FM, Original driveline.
  #98
Old 03-17-2016, 05:45 PM
Judge273's Avatar
This is big...
Mike/Illinois
  #99
Old 03-17-2016, 05:52 PM
The Boss's Avatar
The Boss The Boss is offline
Not hanging the hood for the natural overspray effect?
And go racin' in the street.
  #100
Old 03-17-2016, 06:05 PM
The Boss's Avatar
This is the original paint 72 Lemans Sport Convertible I checked out for Doug that he picked up for his Dad.
You're going this far.....
