#81
yes that is the 883 engine. I hope what im doing won't slow it down. The car should be able to be in the mix, but likely can't win without a gift from the other guy.
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
#82
"The proof of the pudding is in the eating" and emanates from when documents were hidden in pies [fruit pies can be referred to as a pudding in the UK]. Today it means your cooking is only as good as it tastes or, in this case, your combination is only as good as it performs...
'68 GTO 4-spd Hardtop (11) '68 GTO Convertible AT (1) '70 LeMans Sport Land of Lakes Muscle Car Classic Facebook Event Facebook Wall (Kurt Smith,Minneapolis) |
#83
Has anyone built a 455 block/factory cast 4.210 crank 6.625 rod cv-1 combo yet and run it on the Dyno na?
1969 GTO, 3370 lbs, 10.5” tire... 07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads |
#85
ET can vary so much, example on my 3550 lb slow car. Dyno results showed 603HP. 10.72 ET to the ground shows 569HP 127 MPH to weight shows 598HP It's often said, good combinations can "cheat" the ruler. NHRA D/S record is 10.45 @ 126MPH. If we assume weight is around 3200 lbs for this combination. ET shows 552HP MPH shows 526HP Calvin Hill Hill Performance / Mondello Tech Center 708-250-7420 |
#86
My 400 CI KRE HP engine made just about the same, 1.50 HP to CI, compression on my motor is 12 to 1. Calvin Hill Hill Performance / Mondello Tech Center 708-250-7420 |
#87
Bruce; seems we're in agree then.
I've pondered & (had Ultradyne grind several cams that open Exhaust just after Slug went past 90Deg, well before BDC. Corresponded to 104 104 as-cut, and 100 108Lobe Centers installed. Wow what a chopper at idle. Still think there is performance there. Ha!: 30 Deg Split @ .050 Overlap should yield Exhaust driven Boost at RPM. |
#88
In comparison I built a 462 out of a 455 block and factory cast crank and put a set of standard port eheads with$600 worth of port work onthem and made 709 hp at 6100 rpm and 683 torque... In my mind I can either make 705 hp at 7300 or 709 at 6100... Which one would you rather have in a stock block?
#89
Just curious, is that the same 455 engine that the mains split? (Under 6100RPM) Calvin Hill Hill Performance / Mondello Tech Center 708-250-7420 |
#91
#92
So he has ran about 154mph?
#93
10-71 blower cam!
68 Firebird Are you running with the wind or breaking it? |
#94
#95
540 c.i. Ultra Street Combo Tiger Heads with Tiger Intake Induction Solutions fogger with .046 jet First ultra street/ultimate street NOS car to get into the 4's! 1.079 4.559 153.23. 3100 lbs 7.77 @ 169 1/4 Mile (2015) with EHTTFMF!! T2TTFMF! Special Thanks to: Ron at Rhodes Custom Auto Butler Peformance Jim Hostler's Transmissions (HOSGTO) on here Induction Solutions BES Racing Engines. Cheeseburger VP Racing Fuels Calvert Racing |
#96
Just think you could pick up 20hp by taking some exhaust duration out according to Bruce.
#97
his motor does not make more than 50 hp than mine. between my converter not being right for norwalk and his clutchless trans is where the e.t and mph came from. one of the best engine builders in the country said its 4 mph over a turbo 400 with a clutchless trans. Seans engine is badass and I think was build by one of the best in the country wasnt it?
#98
Bruce, can you please spec me a cam that will give me 22 more hp please? I will even give you a healthy tip.
#99
My pump gas deal is near the same split as what Jeff has and it isn't a "nitrous" cam by any stretch.
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
#100
The one thats in it now has 10°
