Old 02-02-2011, 11:03 PM
cgeise's Avatar
cgeise cgeise is offline
Originally Posted by BruceWilkie View Post
Hey I got firsts on that idea (like it matters)
Post 36
While I'm here... If EFI... throttle body doesnt HAVE to be on top of plenum or even a four barrel design. Keep an open mind to other options.
Well **** -- you did - I guess I just yelled louder -- but it is a great great idea worthy of a Nobel prize -- we can split the dough
  #82
Old 02-02-2011, 11:06 PM
JOE DEYTON's Avatar
JOE DEYTON JOE DEYTON is offline
You can get elbows to use the 5.0 and LS1 type throttle bodies as well. I thought about the soft plug also lol. I might check the size, I have a 5.0 Gt40 and LT1 intakes collecting dust.
  #83
Old 02-02-2011, 11:46 PM
Karch Karch is offline
Sure, use an elbow, LS throttle body that comes with GM's EFI conversion package (ECU, throttle by wire gas pedal, etc), and, tune it and you are off and running.
I think the GM package (elbow sold elsewhere) is under $900.
How many of you have driven over 340?
  #84
Old 02-03-2011, 12:40 AM
Think we can make enough for a few cups of coffee??
  #85
Old 02-03-2011, 08:33 PM
cgeise's Avatar
no no - a nobel prize is 1Million bucks - heeeere we go
  #86
Old 02-05-2011, 09:32 AM
Fast 82 Fast 82 is offline
Send a message via Yahoo to Fast 82
Tom i'm in for the plugs for the EFI intake. Also the only thing I have found with the Victor intakes is they require some trimming of the intake to allow for a wrench to fit on two of the bolts, I think they are #'s 2 and 4 on the torque sequence or unless you use bolts with allen heads in them. The alignment is on but when bolts screwed down you cant get a wrench on them.
Fast 82
G & G Perfromance Parts
(937)307-6586
  #87
Old 02-05-2011, 10:55 AM
69Goat1's Avatar
69Goat1 69Goat1 is offline
Valve cover figment will also be an issue if you use any kind of stamped and some fabricated covers on the victor intake. I have used 3/8 and 7/16 head header bolts for the intake.
1969 GTO, 3370 lbs, 10.5” tire...
07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads
  #88
Old 02-05-2011, 01:01 PM
marks73ta's Avatar
marks73ta marks73ta is offline
I have KRE D-Ports. I bought a set of old M/T cast valve covers from a member. I bought a set of 1 inch spacers form Paul spots so I will see no interference at all. My old TA had 6X heads and stamped metal covers. I had to cut and bend the flanges to clear the regular Victor runners. Mark L
My Gasser '63 Catalina build. Oh sorry, it's a Street freak. Either way it's a fun build.
  #89
Old 02-05-2011, 02:24 PM
JOE DEYTON's Avatar
We just use arp bolts with the smaller heads on the intake. And like said before the valve covers hit easy to fix though.
  #90
Old 02-05-2011, 02:39 PM
Tom Vaught's Avatar
Boost Engineer
When you spend $165.00 plus shipping you can do a lot of extra messing with the intake to make everything work. When you spend $500, then it gets to be more irritation spending the same amount of money to make it work. In both cases the same mods are required usually.
Tom Vaught
  #91
Old 02-07-2011, 09:04 PM
73 TRANSAM 73 TRANSAM is offline
Default Victor
Tom, any news for the plugs for the holes? No rush as I was only wondering as I just received my new intake. This is what a Pontiac part should cost, just like a SBC. Let us know, thanks.
  #92
Old 02-09-2011, 01:10 AM
Johnny406's Avatar
Johnny406 Johnny406 is offline
Looks like they sold out now, hope everyone who wanted one got one...
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1980 Formula 350 Pontiac back burner project
1972 LeMans 350 Pontiac
  #93
Old 02-09-2011, 01:42 AM
Default Victor
Good thing I didn't wait too long to order one. Got mine two yesterday.
  #94
Old 02-09-2011, 08:55 AM
amcmike's Avatar
amcmike amcmike is offline
Now we just need an EFI section.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
  #95
Old 02-09-2011, 09:31 AM
Ollie's Avatar
Ollie Ollie is offline
YES,YES,YES!!!!!!!!,
Its ok to giggle and snicker, Dont laugh and point
  #96
Old 02-09-2011, 11:21 AM
65gto69's Avatar
65gto69 65gto69 is offline
Maybe Edelbrock can do a deal an EFI system for this intake. That would be most awesome but probably asking too much
Mark
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, TCI Flex plate, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi.
  #97
Old 02-11-2011, 04:17 PM
Tom Vaught's Avatar
Boost Engineer
Have a lead on a screw machine shop who can cut the plugs. Have a shop who can water jet the covers. Next step will be final design drawings and a trial fit in my intakes.
Tom Vaught
  #98
Old 02-11-2011, 05:40 PM
quick67bird's Avatar
quick67bird quick67bird is offline
Tom Vaught
Thanks for doing this Tom. Let me know what you come up with.
Robert
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4.
  #99
Old 02-11-2011, 07:33 PM
Johnny406's Avatar
Tom Vaught
Thank you Tom!!
  #100
Old 02-11-2011, 07:34 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Thanks Tom keep us posted. I got mine end of last week.
Skip Fix
