#81
I thought Glenn said above that he's already bought stuff to mount the SuperMag in front of the cam?
#82
He was talking about the fuel pump. He could put a plug in the distributor hole and run a dual drive out front for the pump and mag, but given his tinwork is already done and painted, he may not have the room for it.
#83
So Glenn said...
#84
I stand corrected. No matter, now all of you know about another Pontiac speed part that is available that you didn't know about before.
#85
Ok, Question
What lift and duration on a solid roller cam that the lifter valley can survive Duration at .050 .278 to 284????????????????? lift 640 with a 1.5 ratio rocker ..680 with a 1.6 rocker Engle EX-4 grind on the intake, EX-5 on the exhaust????????? For a Pontiac stock block (1970 Ram Air III) ,blower engine, with lifter bore brace Blower is an 8-71, high helix, stripped, retro Stock main bearing size (3.00), GM (2.20) rod bearing size, Light weight Nitrided Crank (70 Lbs) Deck height 10.239 bore 4.155 Compression ratio of 10 to 10.5 to 1 Custom built Venolia pistons and aluminum rods. Kauffman High Port heads, 64 CC, 2.200 intake, 1.750 exhaust, titanium retainers, 10 degree locks, h-11 springs. (Solid roller cam) 380 CFM port work, 1200 series Ferrrea valves. ARP High Port head stud kit. ARP Rocker arm studs and a girdle. Looking to be able to produce 1000 HP but tune to 850. I'm taking the dragster out tomorrow night and again this Sat. It has been running great although have had an idle problem, but believe that has been fixed (user error) Best run is 8.810 at 152.790 reaction time of .502 Starting tomorrow we will be working on slowing it down to a 9.000 index for NDRL racing http://www.nostalgiadragleague.com/Home.html Looking to be able to produce 1000 HP but tune to 850
Glenn R. Lever Rochester, New York 14617-2012 Web Site http://www.leverfamilysite.com/ Front Engine Dragsters http://www.frontenginedragsters.org/forum/ |
#86
Someone will correct me if I am wrong, but I think the rule of thumb on a roller cam and a stock block is up to 200 degrees duration at .200" lift before you'll need a lifter valley brace.
#87
I have found that the grind profiles for Engle cams are not well known, below is pulled from their grind profile list. NEW SOLID ROLLER PROFILES FOR RACING ONLY GRIND LIFT LIFT LIFT LIFT DURATION DURATION DURATION NUMBER 1.7 Rocker 1.6 Rocker 1.5 Rocker @ Cam @ Lash .020" @ .050" @.200" EX-4 .731" .688" .645" .430" 316 278 190 EX-5 .731" .688" .645" ,430" 323 284 196 here is the whole list NEW SOLID ROLLER PROFILES FOR RACING ONLY GRIND LIFT LIFT LIFT LIFT DURATION DURATION DURATION NUMBER 1.7 Rocker 1.6 Rocker 1.5 Rocker @ Cam @ Lash .020" @ .050" @.200" JR-69 .674" .632" .421" 287 252 173 JR-70 .677" .635" .423" 293 259 179 JR-71 .678" .636" .424" 296 260 JR-72 .682" .639" .426" 302 268 186 DG-256 .686" .644" .429" 292 256 175 DG-262 .688" .645" .430" 300 262 180 DG-266 .686" .644" .429" 302 266 182 DG-272 .710" .666" .444" 306 272 192 HTR-272 .722" .677" .451" 305 272 188 HTR-280 .723" .678" .452" 312 280 195 HTR-288 .723" .678" .452" 316 283 197 L-760 .680" .640" .600" .400" 298 260 174 L-764 .680" .640" .600" .400" 300 264 177 L-768 .697" .656" .615" .410" 302 268 178 L-772 .697" .656" .615" .410" 310 272 183 EX-1 .695" .654" .614" .409" 301 260 175 EX-2 .712" .670" .629" .419" 305 269 180 EX-3 .729" .686" .644" .429" 312 272 184 EX-4 .731" .688" .645" .430" 316 278 190 EX-5 .731" .688" .645" ,430" 323 284 196 EX-6 .726" .683" .641" .427" 328 290 197 HO-290 .782" .736" .690" .460" 329 290 205 HO-294 .782" .736" .690" .460" 334" 297 206 HO-304 .789" .742" .696" .464" 340 304 210 HO-310 .789" .742" .696" .464" 310 216 GA-280 .800" .750" .500" 280 GA-286 .800" .750" .500" 318 286 199
#88
That's 200Ί duration at .200" lift.
That 1st cam listed is 190Ί at .200" lift. (all of them except for the last 4 or so are less than 200Ί duration.
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." Socrates |
#89
What does that mean?
#90
If you already have the lifter bore brace, dont sweat much over the duration at .200" cam lift.
With any roller cam its the actual ramp rise rate that affects the amount of side loading on the lifter bores. All rollers will impart side loading. Flat tappet cams do not impart side loads on the lifter bores. To do so would require the edge of lifter to "dig" into the cam. A blower motor, especially one with high flow rate heads does not need a radical duration camshaft. It will like a lift range that compliments the flow curve. IMO a good flat tappet with hi ratio rockers and good valvesprings should be able meet/exceed your HP goals. Its also my opinion that if you can eliminate a high stress in a stock block and still meet your HP goals, then eliminate that stress. A flat tappet may be a wise choice for that reason alone. Hydraulic rollers have modest ramp rates and could work with your plan if you really dont think you can live with a flat tappet. I have a flat tappet cam(max lift rate type) in a road race Pontiac that has lived just fine for 2 seasons and is now in a back up motor. (It was replaced with a bigger version of same series lobes to compliment other changes) I would have no worries about these lobe designs "living" in your application. These lobe types combined with hi ratio rockers can give near roller action at the valve. Your lifter bore brace, if its the full valley brace, is still useful for block stiffness. Feel free to contact me if I can be of assistance. |
#91
I will use the valley brace however I go. It is a full valley brace from Kaufman racing
#92
To remove all doubt, when you degree the cam, measure how much duration is there from .200" lift opening to .200" lift closing...if it's 200 degrees or more, the lifter bore brace is needed.
#93
Thanks a ton.
#94
Good choice...installing a roller cam for me would be an automatic decision to install the brace, regardless of the cam specs.
I suer would like to see you bring that car to Norwalk in August.
#95
I'm just starting to get it dialed in. What kind of racing is it Index, ET, Heads up (no fast enough for that).
#96
Norwalk is all bracket racing, save for the class set aside for the fastest 4 door cars on the property and the heads up class for door cars. Your FED might make a good candidate for the quick 16 class.
#97
if you've got the fed dialed in and running consistently in the high 8's then i'd say enter the q-16. that would give you a chance to see how good you are on the tree against some very experienced and fast bracket racers.
#98
Progress has been slow but there has been progress.
I'm currently looking for the crankshaft hub and pulley and am only finding kits. Any help? I do not want a kit at the moment as the blower is a retro blower and will have to be moved back with an adapter plate yet to be built. Becuase of that I do not know the length of the snout for the blower. Below is a list of parts bought and on hand Engine: 400 Pontiac ram air III block 1970 Deck 10.240 Stroke 4.000 Head Gasket 4.200 Bore/ .043 Thick Forged four bolt main caps Moon Front Timing Chain Cover for dual drive for Mag and Pump Scraper Kauffman lifter valley brace Enderle front Offset dual drive Intake Modified BDS Blower Intake Ignition Mallory Super III Magneto Crankshaft RPM-455A400C 4340 light weight (70 pounds) Forged Nitrided Pontiac 400 3.00 Main 4.00 stroke GM Rod Journals Blower Littlefield 8-71 high helix stripped retro Bird Catcher injector hat Proposed Engle Roller cam SOLID ROLLER PROFILE GRIND LIFT LIFT LIFT LIFT DURATION DURATION DURATION NUMBER 1.7 Rocker 1.6 Rocker 1.5 Rocker @ Cam @ Lash .020" @ .050" @.200" EX-4 .731" .688" .645" .430" 316 278 190 EX-5 .731" .688" .645" ,430" 323 284 196 Custom built Venolia pistons and aluminum rods. Pistons: 4.155 Bore .990 Pin/Supply Pins & Spiro Locks 2.200 intake notch/ 1.750 Exhaust notch 15cc Dish Includes Valve Notches 10.5 Comp. for Blown Alcohal 1.605 Compression Distance Aluminum Rods: Big Block Chevy Big End and Pin Bore 2.200/2.325 Bore .990 6.635 Center – Center -.010 Aluminum Kauffman heads High Port 64 CC, 2.200 intake, 1.750 exhaust, titanium retainers, 10 degree locks, h-11 springs. (Solid roller cam) 380 CFM port work, 1200 series Ferrrea valves. ARP High Port head stud kit. ARP Rocker arm studs and a girdle.
Glenn R. Lever Rochester, New York 14617-2012 Web Site http://www.leverfamilysite.com/ Front Engine Dragsters http://www.frontenginedragsters.org/forum/ Last edited by Glenn Lever; 08-25-2011 at 11:49 PM. |
#99
Steve Barcak will sell you a crank hub. Pulley should be available by scrounging.
#100
Thanks, I will e-mail him.
Glenn R. Lever Rochester, New York 14617-2012 Web Site http://www.leverfamilysite.com/ Front Engine Dragsters http://www.frontenginedragsters.org/forum/ Last edited by Glenn Lever; 08-26-2011 at 02:46 AM. |
