#81
Report #49?
That line you quoted, line (4), wasn't about Holley IFR's. It was in reference to main jets needing to stay submerged on an airplane engine. It does tell us that Holley carbs wont perform properly when ran inverted. Holley high mount IFR's stops the amount of fuel weep, out of baseplate, with engine off and float bowls full. Race type engines, with extremely low vacuum at idle, have a tough time pulling fuel up and over through high mount IFR's. Low mount IFR's helps with idle and transition on those engines. The trade off of added fuel weep is worth it to them. Street cars with hot cams and extremely low vacuum can have the same problems with idle and transition. That's when you need high powered ignition systems to keep from fouling plugs on start up with low mount IFR's. Was Report #49 really from 1920? Good read all the same. A bunch of that main circuit running flow tech does apply to automotive carburetors. The kind of stuff that can't be improved on much if any. Like the test carbs you mentioned in the other post. Clay |
#82
YOU ACT LIKE I MADE UP THE DATE (ACTUALLY published on JAN 01, 1919 SEE BELOW. Publication Date: Jan 01, 1919 Document ID: 19930091078 (Acquired Sep 01, 1996) Accession Number: 93R20368 Report/Patent Number: NACA-TR-49 Document Type: Technical Report Publisher Information: United States Organization Source: National Advisory Committee for Aeronautics; Washington, DC, United States Tom V. You will always have one "Expert" in every classroom, LOL! Most have little knowledge of history and the "Why".
"Engineers do stuff for reasons" Tom Vaught Despite small distractions, there are those who will go Forward, Learning, Sharing Knowledge, Doing what they can to help others move forward. Last edited by Tom Vaught; 05-18-2019 at 01:37 PM. |
#83
Even with all of that QUICK SILVER, no question is a bad question.
Tom V.
#84
So how old were you in 1975-1976 Quick Silver?
Tom V.
#85
I think the thread poster mentioned a concern he had as he went applied moderate acceleration the AFR would head in a lean direction and then on a heavier WOT the AFR would drop into mid 12’s.
Isn’t that exactly how a carb should function? Progressively curve towards the lean side up to approx. 60-70% throttle then swing back richer from 70-100% throttle? Again this was how I understood it from several carb experts years ago. |
#86
I personally think you are right on the money on your thoughts.
In my mind a moderate acceleration could very well not drop the manifold vacuum to say 6.5" of vacuum where the Power Valve would start to open and provide more fuel to the air/fuel mixture. So you get the leaner mixture on the moderate acceleration on the Air/fuel meter. If he was at mid 12s on the heavier WOT that is very close to, the assumed ideal 12.7 to 1 air/fuel mixture, for performance. The Government requires that the Air/Fuel Mixture on modern vehicles stays right at "Stoich". And the engines run fine on the road. The stoichiometric mixture for a gasoline engine is the ideal ratio of air to fuel that burns all fuel with no excess air. For gasoline fuel, the stoichiometric air–fuel mixture is about 14.7:1 i.e. for every one gram of fuel, 14.7 grams of air are required. So he has a lot of "Wiggle Room" on being "lean" with his carburetor without it being an issue. Tom V.
#87
Time to post a follow-up after returning from my work travel....
After confirming my initial timing and very little additional tuning, it is running absolutely fantastic. For the first time, even the choke works like it should too! The hesitation is 100% gone with the larger squirters and getting the 4 corners dialed in how the engine wants it after setting the front transfer slot and using the rears to set the idle. Actually, when I took off the carb, the front slots were just about perfect already from my previous tuning, but it was nice to get eyes on them to confirm they are square and that none of the slots front and rear are overexposed. I want to thanks everyone again for their information and suggestions. It feels great to have this dialed in finally and never needed to change any of the jets. I do have 2 remaining issues: 1) On a cold start (keep in mind it's low 80s here in CA now) the engine starts, then over the first 30 seconds the RPM slowly increases. I think I'm going to lower the cold start idle just another 100 RPMs so the exhaust doesn't drone in the garage. But what is causing it to fire up at a lower RPM then increase? Is that the choke closed too much? Do I just need to rotate the choke housing a bit looser? 2) After about an hour and a half of driving around town, my AFR gets leaner, especially at lower RPMs. Is that from the fuel lines heat soaking and the fuel being hotter? Or from the base of the carb heat soaking and causing the fuel in the bowls to be hotter? Any suggestions on what can mitigate that? Thanks!
1969 Pontiac Firebird |
#88
All of this is precisely why I am going EFI
