#801
Should have some numbers tomorrow.
2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
#802
Hope things go better for you this time around, Ed!
TQ |
#803
Very cool deal. Best of luck to you and the crew. Have a great day with even greater numbers.
#804
Good luck Ed
68 Firebird Are you running with the wind or breaking it? |
#805
After chasing some ignition/timing issues, we managed to get a partial pull before we had to call it a night.
#806
Looks like good numbers.
I'll call you tomorrow. |
#807
Now that's a nice torque curve.
Judging by the 5500 peak tq there is more power above 6100. Good luck tomorrow! |
#808
About 20 HP more than the original dyno pull.
(a lot bigger cam though) Was the numbers on this latest dyno pull corrected numbers? (doesn't say on it) Now we need some turbo power numbers!
#809
I would really like it if the CFM column on the new dyno sheet had data. A/F and VE like the original dyno sheet would be nice but a person could calculate these if there was CFM data. I do like the improvement in BSFC.
Stan
#810
Great power n/a.
The exhaust heads pipes aren't doing you any favors with that non mandrel bend. Are you going to dyno with the turbos? |
#811
The dyno is always helpful for the initial tune, controlled break in and to confirm everything is functioning properly...
Now... Put on the hair dryers and let it eat. Good luck and wishing you success, you have earned it. |
#812
Air Temperature:82 Temperature Correction Factor:1.021 Barometric Pressure:30.06 in Hg Barometric Correction Factor : 0.995 Relative Humidity:97% Humidity Correction Factor: 1.038 Vapor Pressure:1.083 in Hg Final Correction Factor: 0.055 Relative Air Density: 94.84 Correction Method: Standard Correction Source: Weather Station We will not be seeing boosted numbers here
#813
I'll see if we have those numbers.
#814
It's all I could get on short notice, we're running 3" up to the mufflers. That pull was with 35* total and 93 octane.
#815
716.8hp@6600rpm
Made some good progress this evening, starting early tomorrow.
Seeing gains advancing the timing "total to 40*" and retarding the cam 2*. Also tried advancing the cam 2*, but power was down.
#816
#817
Nice job Ed and crew.
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
#818
The valve cover fastener at the lower right corner needs some extra holy water! LOL
#819
Funny thing is you could take Ed's RA-V Head 535 engine naturally aspirated and with that 3500-6500 rpm 600 lb/ft torque curve (basically FLAT from those two rpm points) and have a killer street engine.
Tom Vaught
#820
Ed,
Finally headded in the right direction and I see you got Good old Engine master Mr. Lenny Caverly helping! way to go! I like the video...watch you valve cover T-handle loosen! HaHa!
Carburetor building & modification services Servicing the Pontiac community over 25 years |
