#61
#62
For interest only in my post number 43 above I linked the cooling improvements to the ’66 Tempest owned by Floyd Hand. This morning I finally found part 2 with the testing results.
Surprise, note this comment: "Surprisingly, after upgrading the cooling system, its performance was surprisingly slightly inferior to that of the OEM-style system (see Test Results). This didn’t make sense, especially considering that the OEM-style system was getting long in the tooth and the quality of the new components are top-notch." And this: "..although the PRC custom shroud was very attractive, it limited the volume of air passing through the radiator so the Tempest ultimately ran cooler on the highway without it. " But there was a good reason, read on with this link to part 2..... https://www.hotrod.com/articles/hppp...ystem-upgrade/ .
#63
Sent from my SM-T817V using Tapatalk |
#64
Ive also wondered if a front air dam for my Firebird would significantly alter cooling at highway speed. I know I had overheating issues on my 3rd gen back in the day. Fiddled with fans and all. Finally someone asked me what the condition of my front air dam was. I checked and it was basically broken into non existence. Replaced that piece of plastic and my car ran cool again.
1967 Firebird 462 580hp/590ftlbs 1962 Pontiac Catalina Safari Swapped in Turd of an Olds 455 Owner/Creator Catfish Motorsports https://www.youtube.com/@CatfishMotorsports Last edited by RocktimusPryme; 06-27-2019 at 03:00 PM. |
#65
I do know that in my car on very cold (<20 deg) winter days as long as the heater is full blast, the coolant takes forever to come up to temp until I turn it to low Sent from my SM-T817V using Tapatalk |
#66
I would imagine on a later model cars (68 and later) heavily accessorized with AC, PS, PB that a 7 blade clutch fan can probably move more air than can escape from the engine compartment. It's basically got to push all that hot air down pass the engine and accessories and out the bottom of the engine compartment.
Opening the hood probably creates a definite improvement in air through the radiator. At highway speeds the draft created under the car probably evacuates the engine compartment pretty well. I thought the vents on a TA were brake cooling vents .... if they led to the engine compartment then ... yes I'd guess they thought under hood air pressure was an issue. |
#67
From the HotRod article..."Coolant that flows too fast through the system will not allow sufficient time for cooling by the air that passes through the radiator core. Conversely, coolant that flows too slowly spends more time in the engine block where more heat transfers through the water jackets into it."
Physics reinvented again. I guess if it's in a national magazine it must be true. Interestingly, later on in the article, after the results, the author backs out of that statement. George
#68
The fender vents on a TA have nothing to do with the brakes. They are to the rear of the inner fender wells, open to the engine compartment. So, engine compartment air exits out of them.
Steve F. |
#69
On the LeMans, when the fans came on and went full, if you stand next to the car, you can feel a ton of heat coming from under the car. With the Flex-a-lite fans, I would sit in bumper to bumper DC traffic, on 100+ degree days, A/C on, and it stayed 5 degrees over the stat rating (180). Sometimes would sit for more than an hour, slinky-ing maybe 3 car lengths at a time. It worked. Very doubtful an engine driven fan could do as well in those conditions, with a similar built engine. When you bypass the heater core, it's not really that the heater core provides much cooling capacity, it's more the coolant capacity that helps I would think. .
#70
Whether you cool 1 gallon by 10 degrees, or 2 gallons by 5 degrees, you still remove the same amount of heat from the coolant. Although, an often over looked aspect of heat transfer is the "Delta T" in the formula. The higher the differential between air temp and coolant temp the faster heat will be removed at a fixed flow rate. People understand it very well when it comes to high air temps .... 100 degree air doesn't cool as well as 50 degree air. But it applies to coolant temps also, 160 degree coolant doesn't transfer heat to 100 degree air as quickly as 180 degree coolant does. It's all about the difference in temps between the coolant and air, the greater the difference, the greater the heat transfer (assuming fixed flow rate of coolant and air). However the problem with most cars when it comes to the cooling system is insufficient coolant flow, or insufficient air flow (assuming parts adequate to the task are installed). The system should have enough overhead to handle less than optimum Delta T. |
#71
TV
#72
Went for another ride today. Temps outside are 95 degrees.
Could not get the car over 165 degrees. Slowed down on the back roads and it cooled to 160 pretty quick and after a few minutes actually dropped to 152 degrees and stayed there. Sitting still idling for about 10 minutes and it only crept to 160. Runs super cool for a big motor. I think I have it licked. Not worried about the 100+ temps we'll have here in a couple weeks. |
#73
Seems the stock stuff works if everything is in good working order. People start to monkey around with things and problems arise. |
#75
(2) 12" fans and shroud for sale fits 69 GTO ! ! !
#76
Formula .... if it's cooling that good now ... actually might want to consider going to a 180 thermostat. Probably gain some engine efficiency ... and I bet with the increased heat transfer of 180 degree coolant it would be rock steady at 175-180 in the worst of conditions.
I see the secret to that SCJ cooling system right away. That no clutch mechanical fan looks like it's about 1/2" away from the radiator core, that's going to create a seriously powerful draw through the radiator. |
#77
Larry,
It would very interesting to know how it would of worked with the same radiator but with a better designed fan shroud with dual Spal electric fans. .
#78
Hilarious!!!
#79
I may at some point but for now I'll stay with the stock shroud and clutch fan, it cools way to good to mess with. I will say the cold case radiator with 1 1/4" tubes does a hell of a job keeping the 571 cool. Shout out to cold case.
#80
I have no doubt a better designed Spal setup would also do the trick, but the stock stuff right now is kicking butt. |
