Old 01-14-2018, 12:15 PM
Old Goat 67's Avatar
Yepper.
Just provides continuity thru it anyway.
I'm kinda guessing it may be a pinched wire between there and the compressor coil???
  #62
Old 01-14-2018, 12:52 PM
Pepi's Avatar
Pepi Pepi is offline
X-2
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
  #63
Old 01-14-2018, 02:40 PM
BN's Avatar
BN BN is offline
Ok, unplugged the sensor and jumpered the wires, turned on blower and fuse instantly blew. So that shows sensor is not the problem if I understand...
  #64
Old 01-14-2018, 02:53 PM
Pepi's Avatar
Correct, so it is something in the wire from the sensor to compressor clutch. Pinched wire somewhere or a bad termination inside a connector.
Do you have a test light?
  #65
Old 01-14-2018, 02:56 PM
Well, you could disc the compressor and try it again, or you could read that wire with a VOM to make sure it doesn't have continuity to ground while it's disconnected on both ends. That would be better than wasting another fuse.
  #66
Old 01-14-2018, 02:59 PM
Pepi's Avatar
I thought he has had the compressor disconnected this whole time. If not you are correct. I thought before that he didn't have a VOM, so a test light he could have lit up and wiggle the wire and see when or if it goes out.
  #67
Old 01-14-2018, 03:03 PM
Ooops... I was still going by the older schematic...:0
Very clear now that the short is along that span...
Old 01-14-2018, 06:13 PM
BN's Avatar
BN BN is offline
With sensor jumpered and compressor disconnected the fuse still blows.
I do have a test light and will have a meter tomorrow.
  #69
Old 01-14-2018, 06:43 PM
Pepi's Avatar
So like Old Goat showed and mentioned, there has to be a short in the wire going from the sensor to the compressor.
Take your test light and connect it to your positive and the other end in the sensor connector going to the compressor. Your test light should light up because of short to ground. start wiggling wire harness going from sensor to compressor and see if light goes out. If and once it does, check harness right at that point.
Once you have a meter, you an ohm out the wire.
  #70
Old 01-14-2018, 06:46 PM
Ah ha.
Break it open at that engine line connector shown in the drawing, where ever that is.
That will narrow down your search.
  #71
Old 01-15-2018, 03:21 PM
dataway's Avatar
dataway dataway is offline
Been trying to tell you guys for pages now that the short to ground is down stream of the ambient switch
  #72
Old 01-15-2018, 03:59 PM
Like I always said, "It's hard to humble when you're right!"
  #73
Old 01-15-2018, 04:25 PM
dataway's Avatar
I have highly developed hind-sight.
  #74
Old 01-16-2018, 05:19 PM
BN's Avatar
BN BN is offline
Ok, if I’m doing this right I disconnect a small harness called the a/c compressor extension harness from the main under hood heat/ac harness. When pressed to the connector that goes to compressor the test light lights. The only thing this harness consists of is a 16 inch wire that goes to compressor, a very short ground, and a wire with inline fuse that goes to alternator. Wiggling the wire doesn’t change anything. This harness is brand new btw.
  #75
Old 01-16-2018, 05:21 PM
BN's Avatar
BN BN is offline
  #76
Old 01-16-2018, 05:22 PM
BN's Avatar
BN BN is offline
Attachment 472734
  #77
Old 01-16-2018, 05:23 PM
Is the sensor AND compressor disconnected ?
  #78
Old 01-16-2018, 05:25 PM
You must have the compressor disconnected also, if you do not the light will light due to the fact that the coil goes to ground on the other side of it.
  #79
Old 01-16-2018, 05:49 PM
BN's Avatar
BN BN is offline
With compressor unhooked. Nothing happens on the small harness. Connector at ambient switch lights with compressor hooked or unhooked.
  #80
Old 01-16-2018, 05:51 PM
Pepi's Avatar
Look at the end that plugs onto the compressor. Make sure there is nothing on the front side or the back side that is inside of it causing the two terminals to connect. I have seen strands of wire that haven't been completely crimped into the terminal and make contact between the 2 terminals.
Do this on both ends of the wire.
