#61
I'll have just as much fun sitting in the passenger seat nagging than doing all the driving.
74 GTO Bracket/Street car and another 74 for the wifey to race with! 70 GTO 400, 4 spd, #'s matching and a little to nice for me to own. Friendship is like peeing your pants..everyone can see it but only you can feel the warmth! |
#62
__________________________________________ "How I learned to stop worrying and love the OHC Pontiac L6" The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!) 1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!) |
#63
What diameter pulleys are you guys using on the crank and water pump?
#64
I had underdriven, but switched to overdriven to spin the pump faster. Can measure tonight.
65 Lemans Street Car - 521, T400, 3.70 9". 10.13 @ 135. 3770 lbs. Drag Week ‘14, ‘15, ‘17 63 Lemans Race Car- 8.81 @ 151, 5.60 @ 123(SOLD) 67 Bonneville ragtop 74 Firebird - 455, e heads, TK0600 in process |
#65
Awesome! Text me or post the results here. Vince (Vince_GTO) loaned me an aluminum flow cooler pump with the pretty blue impeller last night! Did you keep your electric fan(s) hooked up or go to a fan off the pump?
#66
I'm running the 6.25 dia. crank and water pump pulleys. I had a larger crank pulley before....don't remember the size. After I switched from the overdrive pulley set-up it cools better but I also changed the fan clutch at the same time so who knows what did what. I don't see any need to overdrive my water pump when most of my crusing rpm is 2500-3500.
Greg Weigart IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/6.21@110.47/9.77@137.08 Hot Rod Drag Week finishing averages: 2014 - 11.12 @ 118.56 2015 - 10.84 @ 124.97 2016 - 10.56 @ 127.88 2017 - 10.29 @ 130.74 2018 - 10.29 @ 130.53 2019 - 10.16 @ 132.34 2021 - 10.09 @ 132.69 2022 - 10.13 @ 133.07 |
#67
Crank pulley 7". Water pump pulley 6".
