#61
True DAT
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
#62
Get ready to change that sig....
Its only 1 line in a whole page of BS....LOL
#63
1169 @8200
John Marcella Marcella Manifolds Inc. john@marcellamanifolds.net ph. 248-259-6696 |
#64
Yea I'm going to have to change my 8.15 to 7 sec. something or other. GTO George Last edited by GTOGEORGE; 02-09-2015 at 03:38 PM. |
#65
Probably a bit closer than my number but do not really know what a True 1/2 point of Compression Ratio does on a engine with that high of compression ratio.
1137 times 1.5% = 17 HP just from that mod. (lower HP assumption is 3% per point. 1154 HP right there and he has a 567 inch engine now. 1137 / 554 = 2.05 per cid. 13 cid more so 13 times 2.05 = ~26 HP. 1154 plus 26 HP = 1180 HP. And I would hope that the "bigger carb" and Marcella Manifold tweaks would get him 10 HP. so now we are at 1190 HP before we even get to the Vacuum Pump vacuum increase. All of my stuff is typically based off of historical data. If the numbers are valid. Tom V.
#66
#67
I think I've already seen that movie a couple times. Never really panned out like it was supposed to
#68
#69
Since I had just been on a British forum and got confused where I was passing this to. That is 1160 HP.
Stan
#70
Yes I know....had some conversation Mr. Gaydosh.. Almost went steel in my build. His call.....might have been different if I went with a billet..
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
#71
Yep, .100 more stroke with no mods to the heads or any part of the induction system or cam timing. Rpm will come down from before or should. But hard to say what the other stuff will do to rpm??????
#72
It's 15 CID...
If it drops 300 rpm from 15 CID then it's a pooch!! |
#73
I see, so the intake is some top secret hush hush piece...I'll stick with my 1171@8100ish
68 Firebird "Indian Giver" 540 MR1, HP's, Wenzler -- For Sale $12,500 rolling Best of 5.12@134 on 175 shot 72 LeMans "POS" - Next US beast |
#74
I'm looking for 84-500 peak hp. Just sayin
#75
Thought it peeked at 8300 before ?
#76
Oh... Sorry thought it was 8500
#77
#78
I could have made it peak at 8500. 1 small change.
#80
You are the Buick Gary. Gary h is doing a ehead pontiac
You are mess up the Buick crowd!
