Old 06-19-2014, 08:46 PM
Mine, the one in the thread , had the original glue on it. It wasn't overdone but I dreaded trying to get it off for years while it sat in my parts stash..
Turned out to be not nearly the problem I had built it up to be in my mind. Dampened it with various solvents like urethane reducer and later, regular Goof Off that you can get at the hardware store. It became soft rather quickly and I was able to scratch it off with a stiff parts cleaning brush and a fingernail.
Be a good winter project for you since the car is kind of out of commission without the dash.
Old 06-20-2014, 07:25 AM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
A friend of mine told me about the spaz stix. He used it on his 1970 charger and it came out great. I used mrgs when i did mine and it wasn't cheap.
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
  #63
Old 06-20-2014, 08:33 AM
If the manufacturer knew the potential in the full size car hobby, they'd probably quadruple the price.
Sorry for the hijack John....
Ok,
Old 06-20-2014, 02:36 PM
PurplePackFan's Avatar
PurplePackFan PurplePackFan is offline
No problem, Greg, all good information. Actually now I wish I would have went that route, yours looks really good. I did use the original instrument panel and used Bare Metal Foil, also from the model car hobby, to brighten up the chrome areas. It was easy and cheap, not sure how durable it will be. The wood/vinyl insert is from Performance Retsorations. The knobs and bezels are either originals that I had or obtained that were in good shape, just cleaned them up.
Hotrodrx-Right now I haven't added any protection to the starter cable, but after re-thinking I ordered some foil heat insulation tape and I will go back in and wrap the cable and possibly the solenoid. I have a heat shield for the solenoid, but for the life of me I couldn't get it to fit right and get it installed so I left it out. The starter is awful close to those exhaust manifolds.
Another update-A friend noticed that I previously wrote about trying to hide or disguise the switch for the exhaust cutouts. He pointed out that QTP make a wireless controller for this system on a key fob. Way cool! So it is on order.
Check it out here: http://www.ebay.com/itm/Quick-Time-P...-/310887974014
John
'67 Corvette Coupe 327, Tremec 5 Spd-SOLD
2010 Camaro 2SS-Traded
2015 Z51/3LT Corvette Stingray, Laguna Blue
'67 GTO, 428, tripower, RS 600, finally done
  #65
Old 06-20-2014, 05:09 PM
I had a hell of a time with heat and the stock starter. Cant remember which starter you said you went with. I went with a mini starter. And I havent even put on the hear wrap on it yet. Problem solved.
  #66
Old 06-20-2014, 06:19 PM
I'm using a stock GM starter. We'll see what happens...
John
  #67
Old 06-20-2014, 10:56 PM
I'd put a heat wrap around it just to be safe. It may help keep it a bit cooler. The minni starter just sounds so cool when the car cranks. And it starts instantly.
  #68
Old 06-21-2014, 08:34 PM
hotrodrx's Avatar
hotrodrx hotrodrx is offline
Default mini
I put a mini starter on a 67 hardtop with dougs headers and had no issues with it. The stock starter as you know can be a handful.
67 gto conv. cover car on gto buyers guide, numbers matching,
62 catalina siverleaf green
67 gto conv. M22 , stroker, roller 400, carlisle blue, parchment interior
65 stingray original condition numbers matching 327 365 hp
  #69
Old 07-05-2014, 06:22 PM
6 Grrrs's Avatar
Agreed. I wish there would have been a nose available for the OEM GM Mini starters to use on a Pontiac. I tried the 3.8 V6 nose, but it wouldn't mount properly.
I use an OEM mini on my 454SS, a Chevelle I did a bunch of work on , and it is standard on my 2500. Never had an issue with any of them. Plus they are cheap.
Tod Hoffmann
2002 Honda VTX1800C
  #70
Old 07-14-2014, 10:03 PM
Default Moving Under Its Own Power!
Well today was a big day. My last report described installing the instrument panel which was a big step to get further work done. I haven't had a lot of time to work on the GTO as of late, but I did get some done this week. I got the clutch linkage in last week and Friday I got the steering column in. So yesterday and today I was determined to spin the engine and then hopefully get it started in the car. I know it will run as I have already dynoed it, but I wanted to verify the wiring harnesses and connections to make sure it will run in the car. I installed the PS pump, alternator, fan, fan clutch, core support and radiator along with a battery. I checked for power at the coil with key "on" and that was good so I tried cranking it and it turned over. So the next logical step was to try and start it. I filled the center carb float bowl with fuel and cranked it over. Started right away. Then I filled the radiator and put some fuel in the tank and she started up and ran like a charm. I put it in gear and let out clutch, rear axle spun, all is good so far. Next I installed tires and put it on the ground. It moved for the first time in however many years(probably 20+) under its own power. Drove it back and forth in front of house a couple times and felt really good. I have a LONG way to go, but reaching this milestone felt really good knowing how far I have come.
Looked good out in the sunlight for the first time since its trailer ride home.
Fan, alternator, PS pump, hydroboost, radiator installed.
Looks mean and sounds great with Pypes exhaust system and Stump Puller cam.
Temporary interior.
I was also able to confirm rear tail lights, brake lights, backup lights, oil presure, water temp, speedo and tach all work. A very good day overall.
John
  #71
Old 07-15-2014, 06:11 AM
Old Goat 67's Avatar
Looking pretty good PPF.
Charles
  #72
Old 07-15-2014, 10:09 AM
Excellent. To avoid going back through the entire thread, I'll ask....What color is that? Looks like Plum Mist.
Old 07-15-2014, 10:21 AM
Greg
The color is a "tribute" to Plum Mist. I like the dark purple but wanted more "pop" so I went with Ford's Medium Aubergine Metallic which is a dark metallic purple found on mid-90's Rangers which stands out a little more than Plum Mist. Going with contrasting Parchment interior.
John
  #74
Old 07-15-2014, 10:42 AM
Stunning combo.
Old 07-15-2014, 12:10 PM
Great build. Love this thread.
  #76
Old 07-16-2014, 10:30 PM
67gtospud's Avatar
67gtospud 67gtospud is offline
Looks awesome! I'm going to have to stop by to check it out again!
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears
  #77
Old 07-18-2014, 09:16 AM
nodwyer's Avatar
nodwyer nodwyer is offline
Love the color and the hurst wheels and the seats. BAM
  #78
Old 07-18-2014, 09:31 AM
Gator67's Avatar
Gator67 Gator67 is offline
Car looks fantastic. I'm impressed with how you've stayed on track with the original vision.
  #79
Old 07-19-2014, 01:56 PM
6 Grrrs's Avatar
Car looks great. I know the feeling of your accomplishments as I was there about 5-6 years ago. You'd be surprised how quick it goes from here on out.
Tod Hoffmann
2002 Honda VTX1800C
  #80
Old 07-19-2014, 04:52 PM
Nicks67GTO Nicks67GTO is offline
NICE!!! Iv'e always been on the fence with the repop big diameter hurst wheels but those look great! A couple questions for you if you don't mind.....
-Any chance you can get some detailed pics during the vintage air install? I'll be doing one myself and it would be nice to see what i'm up against.
-What size are your rear tires? In the thread it says 255/35/17's but the sidewall looks tall. Was that a typo?
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies
- Build Thread
http://forums.maxperformanceinc.com/...615847&page=23
