Old 01-17-2014, 12:08 AM
SD73's Avatar
SD73 SD73 is offline
Thumbs up
EXCELLENT!!!
The Following User Says Thank You to SD73 For This Useful Post:
  #62
Old 01-17-2014, 12:19 AM
transam1972 transam1972 is offline
Default photos
GM console & shifter plate.....original oil pan boltClick image for larger version
Name:	shifter plate.jpg
  #63
Old 01-17-2014, 12:23 AM
SD73's Avatar
Nice stuff! Those spirals are nice. Are they original to the car?
  #64
Old 01-17-2014, 12:41 AM
Default for PAT!
455 H.O.COM.
The Following 2 Users Say Thank You to transam1972 For This Useful Post:
  #65
Old 01-17-2014, 12:45 AM
Default more photos!!
no..repop front and rear original style shocksClick image for larger version
  #66
Old 01-17-2014, 12:52 AM
Default still more photos....
ID:	349613 new DELCO STARTER WITH REPOP HEAT SHIELD,O.E.M.TIPS,REPOP VALANCE..LOOK CLOSE FOR MY 76 T/A TO 72 IN 1980
Name:	rear bushing.jpg
  #67
Old 01-17-2014, 02:15 AM
Default PHOTOS GALORE
RANDOM
Name:	72 QUICK RATIO.jpg
ID:	349619   Click image for larger version
ID:	349620   Click image for larger version
Name:	HEAT SHIELD.jpg
ID:	349621   Click image for larger version
Name:	L & R DUCT.jpg
ID:	349622   Click image for larger version
Name:	OIL PAN BOLT & REPO.jpg
  #68
Old 01-17-2014, 02:19 AM
Default ORIGINAL RALLY II
Name:	ORIGINAL & REPOP FRONT BRKT  REPO BUSHING.jpg
Name:	ORIGINAL RALLY 2 & TIRE.jpg
  #69
Old 01-17-2014, 02:23 AM
Default DISTRIBUTER FEST
Name:	N.O.S. 455 AUTO DIST..jpg
Name:	TENSION PULLY.jpg
Name:	UNI. DIST..jpg
Name:	UNI. DIST. 2.jpg
Name:	UNI. & POINTS DIST..jpg
  #70
Old 01-17-2014, 02:47 AM
Default RANDOM
Name:	POWER STEERING HARDWARE.jpg
Name:	SUB FRAME BUSHING.jpg
Name:	L.I.S SPACE POD.jpg
Name:	UPPER DROP LINK.jpg
  #71
Old 01-17-2014, 03:56 PM
Default SHOCK TO THE SYSTEM
Name:	repop spiral.jpg
Name:	drum & shock.jpg
Name:	upper shock mount.jpg
Name:	repop spiral shock.jpg
The Following User Says Thank You to transam1972 For This Useful Post:
  #72
Old 01-17-2014, 04:19 PM
Default BELLY OF THE BEAST
Name:	Camaro drop off.jpg
Name:	drop off 1.jpg
Name:	inner quarter.jpg
  #73
Old 01-17-2014, 05:36 PM
Bentwheelbob's Avatar
Glenn - your pictures look great. Congratulations on your re-entry to the 21st century. We're looking forward to seeing your progress.
The Following User Says Thank You to Bentwheelbob For This Useful Post:
  #74
Old 01-17-2014, 07:32 PM
SD73's Avatar
What the??? Who's your pal?
  #75
Old 01-17-2014, 07:40 PM
Default in the 21st Century
nice to be a part of it too...why it seems like only yesterday when Tunas73TA said, and I quote, ''if any where this was true a picture is truly worth a thousand words''....and bird72 was able to help me out with posting his hand drawn Formula steering wheel picture for me
  #76
Old 01-17-2014, 07:45 PM
Default SUPERSIZE ME!!!!!!
right SD73...just when I look good, you make me look bad....No as a matter a fact I do not know how to SUPERSIZE, although I like that trick...not to worry ...I will contact you to let you know what pix need SUPERSIZING, thankyou very much
  #77
Old 01-17-2014, 09:13 PM
Default a minimun of a 1,000 words
Name:	leaf spring.jpg
  #78
Old 01-17-2014, 09:32 PM
Default variety pack
Name:	anchor plate bolt.jpg
Name:	modified dropoff.jpg
Name:	factory paint.jpg
  #79
Old 01-18-2014, 01:14 AM
Default THE LAST DETAIL
Name:	72 CHOKE AND DIST CLAMP.jpg
Name:	72 IDLE STOP SOLONOID.jpg
Name:	CHOKE & MOUNTING SCREW.jpg
Name:	NORWOOD STOVE.jpg
Name:	ORIGINAL STOVE SCREW.jpg
  #80
Old 01-18-2014, 01:35 AM
Default MOTORING
[ATTACH]Click image for larger version
Name:	BATTERY CABLE CLIP.jpg
Name:	support decal.jpg
Name:	72 ORIG. FAN CLUTCH.jpg
Name:	radiator support bushing.jpg
