Old 08-06-2012, 07:24 PM
Jay Lightning's Avatar
Jay Lightning Jay Lightning is offline
Originally Posted by rohrt View Post
LOL apparently not if he is on his 3rd
yeah thats true lol, ima try getting pix of the tranny
  #62
Old 08-06-2012, 09:05 PM
242177P's Avatar
242177P 242177P is offline
Originally Posted by GT182 View Post
326s and 327s were basically the same engine and look what they did withthe 327. No reason you can't do the same witha 326.
Sorry, but that's plain wrong. The SBC had a much larger bore and a shorter stroke. The Pontiac has a much smaller bore and a longer stroke. Completely different animals.
The only reason Pontiac had to call theirs a 326 is because they couldn't say the same number for cubic inches as Chevy had.
Let's do the math. Bore X bore X .7854 X stroke X cylinders
Pontiac 326, 3.71875 bore X 3.75 stroke = 325.841291015625
Chevy 327, 4.000 × 3.25 in = 326.7264
Originally Posted by 1967Tempest View Post
Is the TH400 a Pontiac transmission? You can use that no issue, but the driveshaft might need to shortened.
No issue? Not only does the driveshaft need to be shortened, but the crossmember needs to go back six inches. If he had a 67, the frame should have the provision, but he has a 66. E-brake cables are also different lengths.
No issue using two four barrel carbs. BUT if you are going to go that route, you should rebuild the engine.
If the carbs (any carb/carbs) are set up right, the bottom end literally won't know the difference. Can't say that I think a dual quad setup on a 326 makes much sense though. IMO, you're better off spending the money elsewhere.
  #63
Old 08-06-2012, 10:28 PM
1967Tempest's Avatar
1967Tempest 1967Tempest is offline
Send a message via MSN to 1967Tempest
I was looking at a cost analysis... 2 carbs plus manifold, plus new distributor (since he has an HEI in the picture), new wires, new dual carb linkage, most likely new fuel pump all on an unknown lower end.. At that point it is worth rebuilding the engine. Do it once..
Cost more than a used performer and cheap four barrel.
Oh yeah on the TH400 crossmember, forgot about that. BUT that is a free mod if only holes need to be drilled.. Not sure about E-Brake cable. Plus I think one doesnt fit. Long or medium tail maybe..
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!!
1990 Chevy Suburban R2500 Daily Driver
1986 Volvo DL245 Wagon.. Project car!!!
The Burb Files
  #64
Old 08-06-2012, 11:47 PM
i guess i will stick with a holley single 4 barrel carb. should i change out the distributor also?
  #65
Old 08-07-2012, 12:00 AM
The TH400 also takes a different larger yoke, along with shortening the driveshaft.
A TH350 would bolt right in place of the ST-300 2-speed, no driveshaft or crossmember mods needed whatsoever.
  #66
Old 08-07-2012, 09:31 AM
Nope. The one you have is the best you can get. IF you went with that dual 4 bbl or Tri Power intake and carbs, you HAVE to use a points style distributor as it is much smaller and will have clearance. If you go with a single 4bbl, you can use the dizzy you have.
The Burb Files
