#61
Were going to cut the mains, then fill the block (1/2 way as I want to run coolant in the heads) and than do the machine work. I bought; A used PSI serviced and setup to your RPM (6,200) A Mallory SM4 (regular output) with a new small cap and rotor a coil, a harness, a bandclamp From Spud
Glenn R. Lever Rochester, New York 14617-2012 Web Site http://www.leverfamilysite.com/ Front Engine Dragsters http://www.frontenginedragsters.org/forum/ |
#62
Ok, it has been awhile since there was an update on the blower engine.
I have ordered for the blower engine, Kauffman Racing High Port heads, 64 CC, 2.200 intake, 1.750 exhaust, titanium retainers, 10 degree locks, h-11 springs, 380 CFM port work, 1200 series Ferrrea valves, five angle valve job. Best of everything except for the valves, I did not get the titanium valves. Both banks of the block have been hard blocked. Once this is fully cured (28 days) we will start the machine work on the block. I have decided against using the Wenzler Tunnel ram and have ordered a BDS blower intake. I will make a setback plate that incorporates a burst panel.
#63
That's great, Glenn!
BTW, how was that alcohol, shake anything off the shelves?
#64
Killed all the bugs in the garage!
#65
Glenn, Are you sure a burst panel is required in the classes you will run in? I've been looking into possibly supercharging my car next year and I can find no mention in the rules for my car if I run 7.50 and slower. Maybe I just missed it. Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
#66
1:10 SUPERCHARGER Nostalgia Top Fuel, Nostalgia Funny Car, A/Fuel, and AA/GS: Refer to individual Class Requirements for supercharged specifications. Roots-type: Maximum size: 14-71, 22 1/4-inch case length, 11 1/4-inch case width, 19-inch rotor length; maximum rotor diameter: 5.840 inches including fixed stripping. Rotors must be driven from the front; both external drive and internal gearing. The case must be one piece with removable front and rear bearing end plates; rotor must be contained within one-piece case. Rotor helix angle may not exceed that of a standard 71-series GM-type rotor (4 degrees per inch). Maximum overdrive see Class Requirements. Aluminum studs (supercharger to manifold) mandatory in Advanced E.T., A/Fuel, Nostalgia Funny Car, and Nostalgia Top Fuel. See Class Requirements for manifold burst panel and restraint specifications. Section 3 Nostalgia Eliminator SUPERCHARGER Permitted on gasoline-, racing-gasoline-, and alcohol-burning cars. Rotors must be driven from the front; both external drive and internal gearing. Supercharger restraint system meeting SFI Spec 14.1 mandatory on supercharger when alcohol is used as fuel or Roots-type 6.71 with nitromethane. Manifold burst panel mandatory.Supercharger restraint straps must be covered with a fire-resistant material. The blower restraint straps and fuel lines must be installed such that when the restraint straps are fully extended no load is placed on any of the fuel lines. Supercharger belt guard that protects all fuel, oil, and water lines required. No composite materials in injector hat and/or scoop allowed. Composite materials include but are not limited to carbon fiber, Kevlar, and weave-graphite fiber. Hat/scoop must be nostalgic in appearance. Internal modifications permitted. Scoops limited to 12.5 inches above throttle body. Air intake limited to 65 square inches. See General Regulations 1:10.
#67
Interesting. What times and speeds will you be running to be competitive in that class?
Jim
#68
This engine was in my Firebird (3,200 pound car) and went 10.6 at 126 in the quarter Using that as a starting point and using the same engine in the FED with a weight of 1700 (with me in it) we are looking for times in the high 8’s, speeds of 150 or so Nostalgia Eliminator 2 is looking at a 8.6 index, if I cannot go that fast I will have to slow the FED down to 9.6 as that is the index for the NE3 class. With the new added punch of Alky I believe NE2 is doable. Section 3 Nostalgia Eliminator DESIGNATION N/E, N/E II, N/E III, preceded by number. CLASSES N/E: 7.60 standard N/E II: 8.60 standard N/E III: 9.60 standard Competition is based on using a four-tenths heads-up Pro Tree. N/E: Reserved for front-engine center-steer cars only (dragsters, altereds, and pre- 1973 Funny Cars). Left-hand- and right-hand-steered roadsters and altereds will be allowed to run in N/E II and N/E III.
#69
I looked at your web page WOW great looking car and all new crazy!
Very very cool! good luck with that thing looks like it will be a blast
Eric CURRENT CARS 68 Firbird 400ci convertible |
#70
Yes, thanks for taking the time to post.
The metal work is amazing......I bet he is not short of work |
#71
He is an artist. You can never have enough work.
#72
Glenn, Your dragster is looking very cool. Here's an option if you don't mind your blower sitting a little higher. I run a Hampton 2 1/2" spacer under my 871. Plenty of room there for a burst panel.
You know it's going to be a good day when you wake up breathing! |
#73
Here's a couple of pics with the spacer on my 64 Gasser build. Going for the cast look on this one and it kinda all blends together so you don't really notice the spacer. Just an option.
#74
#75
What ignition system?
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926} |
#76
Mallory Supermag III (purchased), Mag limiter set at 6,500(purchased), Enderle's 80A1 pump (not purchased yet), driven off the front timing cover with a dual drive (purchased), hanging off a Moon Timing cover (purchased).
#77
Mike Dunn makes offset drives and can provide one for a Pontiac if the blower encroaches the magneto.
#78
Does he have a web site?
#79
Not that I am aware of. He is in Texas and most of the folks in the blown alky ranks are aware of him. He's a small shop and is old school, which is why I guess he never got a website. I have his business card and contact info at home, I'll post it later.
The offset is a "one size fits all" and he makes them to different lengths. It's the shafts that are obviously different depending on engine application. He didn't offer one for a Pontiac until I contacted him. Had him make one to my specs which was tall enough to clear my midplate (which also serves as a firewall) but short enough to clear the blower when mounted on a BDS intake without a spacer.
#80
Dunn Services
1570 Karen Drive P.O. Box 258 Argyle, TX 76226 nodrivin@flash.net 940-240-1603 817-994-9101 cell http://community.webshots.com/album/...NErb?start=168 See pic #67 in link.
