#61
Brian,admit it,you're not reading all of the posts,are you? I already mentioned the VW spigoted head/barrel arrangement
#62
No, I'm not. Some of you guys go on for long rants and when your grammar is on par with a 1st grader with poor sentence and paragraph structure, along with poor spelling, my attention span goes right in the $h!tter and I stop reading. It's sad, I know, because I may be missing out on learning something, but if you can't structure it properly so it doesn't hurt my eyes to read it, I pass on it. I can't read half of the $h!t Brad Spidel posts because of this, and when he posts late at night after he's been drinking, it's worse.
#63
So what is the cost for a set up to use the optimum seal deal? |
#64
Well, if I ever get this funny car running (and I will), we will see how a Cometic holds up. It's dry decked with no coolant in the block or heads and the studs have been upgraded to 9/16".
#65
FWIW:
Brian, just be careful. I have seen Ford guys do the same thing and end up pulling the deck around the threads (higher toque specs) and loosing seal worse then using a stock diameter stud.
#66
I've got full confidence in my IA-2 block, which I had AllPontiac machine for the 9/16" studs. Those Ford guys have a block as stout? I seriously doubt it.
#67
One way would be to make a fixture (using a cast iron deck plate), as I know that you do not have a cnc bridgeport machine at your shop. You hone the inside diameters of the individual bores of the deck plate to the outside diameters of the cylinder sleeves (after it is attached to the block with alignment dowels). This gives you the Outside Diameter of the receiver groove that needs to be machined in the aluminum heads. You make the cutter the same width as the cylinder liner wall thickness. You cut the groove .040" deep and you leave the cylinder sleeves .045" above the deck. When you install the head you should have a .040" seal into the head and the deck of the head should be tight to the block deck surface. The extra .005" length will compress the sides of the groove by pushing up the top of the groove. You would probably need a tool to "jack" the head evenly off the cylinder liner protrusions otherwise you would screw up the seal receiver groove. All of this can be done with proper thought before hand. No different than removing snug 4 bolt main caps in block registers. Tom Vaught
#68
Brian B., and a bunch of other people who have posted in this thread
That is normaly the time that i make it out of my garauge. I then have to take my prcribed medications(real early in the afternoon say like 8m). They won't give me any good stuff to help me sleep. So i have a little to much corn. And then naturaly as usual i try to to spell, i try to use proper grammer, and i also try to explane my findings, Not my ideas, onely what i have done, what i have wittnessed first hand, and what i thought went wrong. Anyway, by this time i am tired and don't care. But i also can not type for crap or spell wel when i am looking at the keyboard, my fingers get in the way. so anyway, i am BIPOLAR indevidual that has a lot to say and a lot of crap in his headd. hell at one time he went PD for mechanical engineering and had a guy try to get me to work in that feild when i was 17yrs old. se, by know i don't care i am looking at the key baord and trying to type what i am try ing to say without looking at thekeybord. |
#69
#70
that's my problem Brian,
now i feal like myself, like i am the making decisions in my own brain. i can think of so much crap from here till 3;00am and then wake up ready to do something at about them at 9;00am., And all the corn, all the meds, all the tirerdness, and all the B.S. that goes on within this board in the confines of the aplicable threads, makes me laugh. anyway, i have broke more stock pontiac crap than about 99% of the population, but everytime i learnerd something. |
#71
Tom I know this is an older thread but I have alawys thought the same thing with the sleeve sticking up into the head. id love to try it one day just for testing sake
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
#72
Please help us!
Pontiacs have 2 problems with their heads 1st.... is the 2 center exhaust valves that are next to each other (it's a heat thing) and no.2.......10 head bolts or studs (the head will lift). I will be trying a better stud (in the future) keeping the heads stud from stretching and not letting the head to lift. No matter what gasket you use the head WILL lift under enough boost pressure. The 2 or 3 Pontiac aftermarket block/head Companys out there need to get together and add more studs to the blocks and head (standardize it) like the small block Ford, sure would make thing a lot better for us Pontiac racers!
George |
#73
East Coast Mafia TTFMF Making CVWHAT's great again. I guess it took a deplorable ECM member to do it! Quote:
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs) Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs) |
#74
My experience though out the years of seeing blown head gaskets. The problem
as I see it.... is the head moves around. The Cometic MLS with it's layers allows it to move with out breaking it's seal....that's why it works so good. Even better then O'Ring block with copper head gaskets. I think up till now " before Cometic MLS " it was the choice set up. Before I went to the Cometic MLS I ran a copper head gasket with built in O'ring...which blow after a haft doszen runs...you could see that the head was moving and turn the gasket egg shape around the cylinders and unsealing the water holes in the block. There was no signs of detonation what so ever.
The turbo diesel guys run ARP2000 or ARP Custom age 625 head studs they do it for a reason. It's about time we (Pontiac Racers) wake up.
George |
#76
Sooo, when are the better studs going to be available? And can we afford them when they are? Anyone talk to ARP? I know that Steve Barcak goes to 9/16 studs on his 389 fueler blocks, I drilled and tapped his last block. Would they make any difference? Mark L
#77
Coming together!
What I understand after researching the internet the past couple of weeks is a 1/2" arp2000 or ARP custom age 625 will yield more clamping power then a 8740 9/16" stud without the drilling and taping for bigger holes, also they won't stretch as much. Now the bad news.........the price. Any special order part (no matter what it is) will cost more but in this case the more that you order the price comes down drastically, so basically we need the Pontiac High Performance community (KRE, AP, Butler, ETC.) to get on board. There is a demand, specially if the price is right. Just my opinion.
GTO George |
#78
My guess about $300.00 for a set....vs $125.00 - $150.00
What about a group buy? Will Arp commit to one? I would be willing to get a set if they come down some at least. Mark L
