Old 10-16-2008, 06:42 PM
badgto's Avatar
badgto badgto is offline
70 GTO
455 .030 11.5 to 1 compression
Induction- E-heads, 320 cfm,
1050 dominator on alcohol
Trans- tubro 400, 9" hughes 5000 convertor
Rear gear- 8 3/4 Chrys w/4.86
Tires- 31x14x15 Hoosiers slicks
Fiberglass front end, doors, trunk and bumpers
Lexan windows
Best ET/MPH 1/8) 6.75@99.75
Best 60' time- 1.42
  #62
Old 10-25-2008, 11:43 PM
XSIVPWR's Avatar
XSIVPWR XSIVPWR is offline
1968 Firebird
474 e-heads victor 1050 Dom
turbo 400
3.89 gear 14x31
3115 w/me in it (not for long)
Best 9.71 @ 138.
  #63
Old 10-26-2008, 09:17 AM
threefidee's Avatar
threefidee threefidee is offline
1968 Firebird 350 HO Convertible. Raced at the Pure Stock Muscle Car Drag Races.
Automatic
3.55 LS
F70/14 Goodyear Polyglass Tires
Log Manifolds
Pypes Exhaust 2 1/2 Mandrel X Transverse system
Dyno: 330 hp and 395 torque in street trim
3,900 pounds with driver.
2.030 60 ft
5.781 330
8.908 1/8th mile
13.93 @ 97.76 quarter mile
ID:	146535   Click image for larger version
ID:	146536   Click image for larger version
ID:	146537   Click image for larger version
Name:	'06 PSMCDR Spectator Photo.jpg
1979 Pontiac Trans Am
- W72 400 - 4speed
- WS6
- Heritage Brown
- Air Conditioning
  #64
Old 10-31-2008, 11:47 PM
badassgoat's Avatar
badassgoat badassgoat is offline
Default 1969 GTO Judge clone
Street legal (and driven) full interior (including console) 69 goat Judge clone in Hugger Orange or as Indian fans call it Carousel Red.
3925 lbs w/driver
13.3:1 540 CID PONTIAC N/A - NO power adders!
IA II block, Forged crank, Forged H-beam rods
SD ported Edelbrock wide ports flowing 370+ (non heart shape chamber)
T&D offset shaft rocker system.
SD massaged Victor intake.
Pro Systems 1050 Dominator.
Ultradyne solid roller custom SD spec .730 lift
Doug's headers Jet Hot coated 1 7/8" primary 3.5" collector (yeah I know they're too small - I'm working on that!)
MSD 6AL w/2 step
Reverse manual TH-350 w/brake.
Moser 12 bolt 3.72 boxed upper arms, SSM slappers, otherwise bone stock
30" x 10.5" Hoosier slicks
Best time to date:
60' - 1.435
330' - 4.118
1/8 - 6.343
MPH - 110.11
1000' - 8.280
1/4 - 9.930
MPH - 137.52
Notes: Left @ 3200 on brake (usual 4800). Had to pedal on that pass - got out of the groove due to violent launch!
Just figured out after 15 passes that this 540 likes to rev to at least 7200. Dave Bisschop told me it would. Tossed the 6500 pill in the garbage! Not even turning 6000 through lights so obviously, I will be swapping the 3.72 gears for 4.10 and possibly even 4.3 and will run with open headers. I fully expect to be posting at least a 9.7X pass by next week.
  #65
Old 11-04-2008, 11:51 AM
geezer1's Avatar
geezer1 geezer1 is offline
Location: Hickory Corners, Michigan - Home Of the Gilmore Car Museum
1987 Firebird, IHRA No box, 1.43 60" 10.25 @133
  #66
Old 11-09-2008, 09:09 PM
Herb Hagan's Avatar
Herb Hagan Herb Hagan is offline
1974 Ventura 3350#
462 CID/#13 heads/4150 HP1000/Victor intake (N/A)
TH400/ATI 4200 stall/3.90 gear
275/60 Drag Radial/Cal Tracs/Split mono leaf
Street/Strip (Tagged/Insured)
3" exhaust
(Today @ Cecil Co.)
10.38 @ 128.89 MPH
1.467 60'
74 Ventura 462/#13 heads/3350#
10.38 @ 128.89 MPH, N/A, Stock suspension, 275/60 Radial, Street legal, Tagged & Insured
  #67
Old 11-14-2008, 05:39 AM
hill461 hill461 is offline
Default FAST
JOHN HILL
1967 FIREBIRD
2900 LB
505 CI ia 2 365 CFM HIGH PORTS
GLIDE 4.30 GEARS
33-10.5 TIRES
5.87 AT 117 1/8 AT KANAWHA VALLEY 1.27 60 FT
9.31 AT 145 1/4 AT PITTSBURG 1.31 60FT
1050 DOM VICTOR
NEXT YEAR
G-RAM 2 850S
LARGER CAM
HOPING HIGH 8S
  #68
Old 11-24-2008, 12:15 AM
bad69bird's Avatar
bad69bird bad69bird is offline
69 Firebird-3465 lbs
Stock suspension (Cal-Tracs)
Turbo-400/ PTC converter
12-bolt 3.73 gears
325/50/15 Mickey Thompson drag radials
477 IAII
Procharger F-2
E-heads
Victor intake
850 CSU carb (Blow-thru)
Best E.T./MPH so far
60': 1.270
1/8-mile: 5.52 @ 127.39
1/4-mile: 8.601 @ 159.83
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs)
  #69
Old 11-27-2008, 10:48 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Phucking weak!
12-bolt 3.73 gears
477 IAII
Procharger F-2
E-heads
Victor intake
60': 1.270
First Pontiac powered street car in the 7's
7.940@170.84. 3460#s
  #70
Old 12-09-2008, 04:18 PM
pops65 pops65 is offline
65 gto conv tri power 4 speed 3630lbs 6.929 99.88 8th 10.98 123.79 quarter 4.10 gear10-1motor 440ci bycvms and a fun ride
  #71
Old 12-09-2008, 05:21 PM
ho428's Avatar
ho428 ho428 is offline
Ken,
Just cause I know how to turn left and right you ain't leaving me out...
68 Firebird
366, T-2 w/ holley750
#17 heads
Headman 1.75's
M-20
3.08
26.7 od rear Goodyear Blue Streaks
1:58 Lap time on a 2.6 mile road course.
Around 120+ mph so far on the back stretch, I'll break 140 eventually
A great lap time there should be in the 1:40's
1:58 was my first offical Solo lap time, all I wanted was to break the 2:00 mark.
I'll post times as I improve.
  #72
Old 04-12-2009, 07:46 PM
GOAT490's Avatar
GOAT490 GOAT490 is offline
Thumbs up Update from PONTIAC HEAVEN XI
65GTO 3550lbs
497cid 12.9:1 110octane No Power Adder
Factory - Block/Crank/D-ports
Victor/1050 Dominator
T400/9.5"4200stall/3.91/30"x9"Radial Slick
Footbrake/1470altitude/2800 D.A.
1.41 60ft
6.45@104.97 1/8th
10.25@127.12
PHILLYGOAT
1965 GTO/ OEM Block, Crank & D-ports(all slightly modified of course)/
3550lbs/ Full Exhaust/ Foot Braking
1.41 60ft 6.45@104.97mph 10.25@127.12mph(Pontiac Heaven)
More Details on GOAT http://www.pontiaczone.com/forum/vbpicgallery.php?do=view&g=379
GTO Burnout http://www.youtube.com/watch?v=nZqdcH0Ltc4
  #73
Old 04-18-2009, 08:05 AM
wreckmastr's Avatar
69 GTO-3650 lbs
Ladder bar suspension
Fab 9" 4.29 gears
33x16x15 Hoosier slick
537 IAI
NOS fogger and Big shot plate total 475 hit
E-heads
Victor intake
1250 Carb
60': 1.240
1/4-mile: 8.521 @ 160.65
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
  #74
Old 04-18-2009, 02:25 PM
461-69bird's Avatar
461-69bird 461-69bird is offline
69 Firebird
3480lbs
461
kre 85cc
850 aed dp
th400
10 bolt
3.90
stock suspension
28x10.5 x15 m/t slicks
3" exhaust, x-pipe, Dynomax super turbos
taxed and insured
1.62 60ft
11.27 et
119 mph
Rick Denny
69 Firebird
472, Bullet SFT, KRE 85cc, Victor, 850xp, TH400, TSP 9.5" 4800, 3.90 10 bolt, Viking DA rears, QA1 single fronts, 3558lbs. best to date 11.14@120
  #75
Old 05-16-2009, 04:50 PM
63Banshee's Avatar
63Banshee 63Banshee is offline
Originally Posted by ho428 View Post
Ken,
68 Firebird
#17 heads
Headman 1.75's
M-20
3.08
Dig the pic! What chassis and suspension setup?
  #76
Old 05-18-2009, 01:32 PM
cgeise's Avatar
cgeise cgeise is offline
Ok here goes - 2008 GTO -
60' 1.07
best ET - 6.93
best MPH 201
weight 2500#
525cid with twin 88mm tubos
powerglide
4.70 and 160 mph at the 1/8th
  #77
Old 06-10-2009, 07:34 AM
68birdfreak's Avatar
68birdfreak 68birdfreak is offline
Default best so far
1969 Firebird
3.55 gears
3640 w/me in it
1.87 60 ft.(new best)
12.36 1/4 mile 112mph
5spd TKO...6300 rpm in 3rd gear thru the traps
428 .40 over
R/A II heads
800 holley D/P
mickey thompson E/T streets 20psi
434 CI TKO600RR 1969 Carousel Red RAII Heads...Pump gas 400+hp/450+tq at the wheels...life is good!
  #78
Old 06-11-2009, 07:18 PM
hal101's Avatar
hal101 hal101 is offline
1968 firebird
3.23 gears
3600 # with me
1.99 60 ft
12.62@110.34
turbo 350 2500 stall
417 ci 4.185" by 3.79"
#12 heads flow 280 cfm
hr 230/236 .565/.570
rpm holley 870
hooker 1-5/8
pypes 2-1/2" x pipe crossflow
235/60/15 et streets
  #79
Old 06-22-2009, 10:08 PM
jm455ho's Avatar
jm455ho jm455ho is offline
Finally got some times to post. Quickest run from this past weekend of testing and racing was:
1.413 60 ft.
6.655 1/8
10.588 1/4
125.283 mph
1978 Trans Am. All steel. 3330 lbs race weight. Track only. Pump gas 464 cid with KRE d-ports. 9 inch rear with spool and 3.89 gears. 30 x 9 Hoosier radial slicks on 10" wheels. Only launching at 3400 with trans brake so there are better times to be had. I will need to get some good adjustable rear shocks so I can leave harder without spinning.
www.hobracing.com
  #80
Old 07-09-2009, 11:52 PM
RST's Avatar
RST RST is offline
67 Firebird 1.45 60' 10.47 @ 127 mph Still new at this racing a car with HP Last car was high 12s.
