#61
The shop is wanting to set my rod clearances ~.025", and the mains ~.030" for this kit.
Does this sound about right?
'78 T/A W-72 400 w/468" forged stroker kit. '07 Solstice GXP (Turbo) '81 4spd Vette '03 VTX-1800c |
#62
Sorry to hear that but that has been my exper. for years helping others . Mic the housings should be on the high mid or low of tolerance your bearing manuf. gives those sizes be sure they all match crank on the mid all others should be . Then install bearings in housings and torque measure crank and housing diff. is actual clearance NO PLASTIGAGE .0025 -.0028 on rods and .003 -.0035 on mains be sure crank is consistant from pin to pin If not have turned by competent shop [Crankshaft specialties Fairfax Va.] Gary Facmire
#63
where in FFX are they located, and do they work with kenson?
costs too much |
#64
I was having a 455 freshened up,its was an uncut,stock crank,they ordered stock bearing size and when checked,it had only .0017 clearance on the rods.Good thing it was checked!A different brand high per. bearing gave the needed clearance wihout cutting the crank.
#65
Uneasyrider “To find yourself, think for yourself.” ― Socrates “The unexamined life is not worth living.” ― Socrates “Wise men speak because they have something to say; fools because they have to say something.” ― Plato |
#66
After having heard "lifters collapsing in the thurns, I feel it wise to comment:
divide .025" and .030" by 10 |
#67
Yes at kenson Gary rents space there you can get his home # on 411 and deal direct with him.
#68
There is such a thing as having too much oil pressure and/or too much oil
volume. Both can "wash" the babbitt right off of a bearing. It's rare,but it does happen. As for clearances, I've always used .002 on both mains and rods per Ken Crocie. My guess... does the crank have babbitt embedded in the journals? If so, the RA(roughness average) is too high. It should be around 10-15 using a profilometer. I learned another way to check from an old machinist. Take a penny(preferrably one that is all copper,not just copper-plated). Rub it on the journals. If copper is left, the journals are too rough and need to be machined. You could have gotten some bad bearing,also. Good luck on the rebuild!! |
#69
A good rule of thumb to use for bearing clearances for a high performance/high RPM application is .001" clearance for each 1" of journal diameter.
Thus, for a 400 with 2.25" rod journals a .00225 or .0025" clearance would be fine on the rods and with the 3" main, a .003" main clearance would also be fine. This is a little on the loose side, but from what I've seen loose is a little safer than tight, or more forgiving overall. I might try a tight clearance engine if I could trust that all the machine work was 100% spot-on and if I had a clean room to assemble the engine in so that no chance of any contamination getting into the bearings during assembly.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
#70
Uneasyrider “To find yourself, think for yourself.” ― Socrates “The unexamined life is not worth living.” ― Socrates “Wise men speak because they have something to say; fools because they have to say something.” ― Plato Last edited by uneasyrider; 01-11-2007 at 10:02 AM. |
#71
Having the oil system run down the lifter bores first doesn't help.
#72
I also use synthetic oil. |
#75
#76
Ken,
AMEN!! For a little insight, I used to crew a P-51D Mustang with an Unlimited Class engine: 2,500hp@120 inches of manifold pressure. Our builder specified .003 rod journal clearance and .0035-.004 main journal clearance. Guys, we're talking 1,650 cubic inches here. In otherwords, BIG!! |
#77
hurryinhoosier62 - was that a P-51D Mustang?
#78
Will,
You bettya! If I remember the USAAF# correctly it was 414064 Tail #N3751L It was painted to recreate "Pete" Peterson's "Hurry Home Honey". She was a Cavalier conversion(aft fuel tank removed/seat added, step in flap) that some yo-yo flew to Tahiti back in the '60s. It did have some corrosion issues but we got them all repaired. One sweet bird. There's nothing like the sound of a Merlin in high-speed supercharger at low(250 agl)altitude!! It just makes the hair on the back of your neck stand up!! |
#79
