Old 10-22-2003, 06:26 AM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
Nice pipes! I've been considering 3" mufflers and tail pipes for my '76. Not sure about ground clearance with the large mufflers though.
Pittsburgh, Jim and Tom Hand have done some extensive exhaust system testing. Not only have they tested mufflers but they also tested crossovers. Check http://www.boyleworks.com/ta400/psp/exhaust.html for the complete run down. The X is unlike a Y in that the X branches back out into two separate pipes where the Y necks into a single pipe.
  #62
Old 10-22-2003, 07:48 AM
Ccass's Avatar
Ccass Ccass is offline
Administrator
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Rocky Rotella:
<HR></BLOCKQUOTE>
Rocky, I saw several 2nd gen TA's at Norwalk with 3" exhaust and no clearance issues. It's not so much the mufflers as it is the pipes traveling under the floor boards. I did notice that both cars I remember had very good suspensions. Their cars probably sat and inch or 2 higher than stock.
Fool around, Get hurt, don't come crying to me.
  #63
Old 10-22-2003, 08:11 AM
Larry Navarro's Avatar
1973 SD455 T/A
1979 S.E. T/A
http://community.webshots.com/album/16587603rOyvmFCiHs
[This message was edited by Larry Navarro on October 22, 2003 at 11:47 AM.]
  #64
Old 10-22-2003, 08:53 AM
Blackcat's Avatar
Blackcat Blackcat is offline
Bonker's-T-Cat Moderator
Just to let the members know.
Yesterday the 2 1/2 chrome Tips arrived!
they were packaged very well!
Usually I'm found working on my Pontiac. If you want to find me Look for the white picket fence and all the old Pontiacs parked outside. And the half dissembled engine sprawled all over the driveway!
Try calling CRUSHPROOF! 512-386-9889
  #65
Old 10-22-2003, 08:56 AM
Blackcat's Avatar
Here is a view of them.
Nice!
Well done!
  #66
Old 10-22-2003, 09:00 AM
Blackcat's Avatar
Here is the test fitting!
They look even better on the car!
Well done!
  #67
Old 10-22-2003, 09:15 AM
lampoon's Avatar
lampoon lampoon is offline
Which tips should I get to be correct for a 67 2-1/2"?
1965 GTO Convertible, Blue Mist Slate.
1967 GTO Hard Top Coupe, Champagne Gold
2005 G6 Sedan, Electric Blue
  #68
Old 10-22-2003, 09:29 AM
Blackcat's Avatar
If you order the Pypes 2 1/2 kit then the ones I have are the ones you use.
If you have stock exhaust the tips are smaller
Check out the Removed exhaust pix I posted.
