#61
Then another fun part,which: head gaskets cam rockers springs carb(would like to use Quadrajet) intake(I have a Torker II,but thats probaly a bad idea) I'm going to cc the 670's in the morning so we have a better idea of what were working with Thank's for your help too.Putting up with me being a pain and beating a dead horse,ha
1967 Tempest raIV 400 th-350 48k miles orig 1967 Tempest wagon 72 400 th-350 10 bolt posi(gone) |
#62
Good luck on head gaskets. When you find a retailer for correct 350 head gaskets, PM me and I will buy all of his/her stock. I have a 326 in my wagon and if I need HG's I wanna have them available.
You might find yourself getting Cometic's or another brand that is expensive, but worth it. Keep us posted on the gaskets. Victor Reinz used to make them, but I haven't seen a set in two years. Cam: Here is the most important question.. Where is this engine going to LIVE IN RPM's? You want torque off the line or rev to 6K? My top 3 cams in order... 1. Isky Supercam 256/262 2. Melling SPC7 (068) 3. Summit 2801 OR, OR Comp cams 256DEH I have had all 4 of these cams. #1 has electric motor torque off of the line. I had it in a 67 Tempest with TH350 with 2K stall and 2.56 one legger. Right rear tire HATED ME! That was in a 400. In a 350 it will be even bigger! It will breathe well to 4800-5K in a 350. But seriously, let me know where you get the head gaskets.
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files |
#63
Yup,I've given up on finding the correct gaskets.Just making sure I use the best close enough gasket,ha.If by some miracle I come up with some,I will keep you in mind.One of theese days I'll dig through my stash.I had my 326 apart a few times back in the day and always bought full gasket sets.I;ll see what I saved As far as rpm's,well,like I said,I don't race.Good street torque is what I'm looking for.I'm really leaning towards the 2801.From what I hear it seems like a good candidate.The car will see a few long haul trips this summer as usual.Going to Summer Nationals,upstate NY,etc.Definitely want to keep it pleasent to drive,but still run pretty mean.Yes I want it all I had an isky cam years ago,in a 78 bird with a 400 and I know what you mean about the electric motor torque,ha
#64
Duration at 050 inch Lift: 202 int./208 exh. Advertised Duration: 256 int./262 exh Factory Rocker Arm Ratio: 0.450 int./0.465 exh Looks closer to the 067 cam specs. I see you placed the 068 above the summit cam. I see your the second person to say they liked it a little better. |
#65
Cometic! Worth the money. You get an excellent gasket, with the thickness at 0.027" you will improve compression and quench. Potentially reusable as well. It is the correct bore size! http://www.ebay.com/itm/COMETIC-GASK...bd9030&vxp=mtr Also, I once bought an old stock Felpro gasket set, for the whole engine. Specific to the 350. It was part number HS 8259 S Look for that online and in ebay from time to time. Like this! Try harder fellas. http://www.ebay.com/itm/Fel-Pro-Head...6ad857&vxp=mtr |
#66
Been avoiding jumping into 350 build recommendations again, but...
My vote is the 670 heads. Always thought they would be the ideal design for a 350. Compression ratio should come right in where you want it using flat tops. And valves are further away than the later chamber design allowing aftermarket cams without worrying about exhaust valve clearance to the cylinder walls. And you have them ready to bolt on. All pluses. Only downside is my experience is that it is very easy to over-cam a 350 especially with big valve heads. A 350 doesn't need much duration to make a lot of power on top, but it comes at the expense of bottom end torque. And you don't want to do that with a 2.73 gear (hence the downside). The Isky cam looks interesting for what you are trying to do. The 2801 will act quite big in a 350 with that gear. Yeah gaskets. I always got away with regular 400 CID Felpros without a problem, though less than ideal.
1969 Lemans vert, matador red, 462 CI, 3.07 12-bolt posi 1974 455 TA, admiralty blue/red interior HPP "cover car" - sold "The best way to show a car is to drive it" |
#67
Max street low end torque I would probably steer clear of the 2801 in a 350, probably better off not exceeding 210 @ 050 on intake and maybe running a 110 LSA cam instead of a 112 , this application would be one of the few times I would deviate from my usual cams. Although a Summit 2800 would be OK 204/214 420 442
63 Catalina coupe 467 cid budget drag car 11's 1/4 , 7.20 1/8th pump gas n/a 66 Star Chief Executive 57k mile 69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4 69 Firebird 400 Burgandy/Black 70 Olds Rallye 350 F85 4 speed 3.91's 70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455 74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8 2020 RAM 1500 SLT 4x4 5.7 A8 Hemi 2007 Hummer H3 3.7 liter turd 2019 Chevy Spark petrol car 38 mpg |
#68
I agree with both the previous posts. The 2801 is good in a 400, but more than you seem to want in a 350. Stick with one of the stock cams that were used in a 350. 068 would be a decent choice. If your compression ends up at 9:1 or so, with decent exhaust, and a 4 barrel carb, you'll have a good reliable vehicle you can drive for 50k miles with plenty of punch.
IF you want a little extra, before you assemble, get the pushrod holes opened up to allow for higher ratio rockers. While using a smaller cam, you add some duration and lift without adding a faster ramp on the cam. Make sure your springs can handle any added lift before doing that, though. |
#69
#70
The reason I liked that cam in an automatic with a 2.56 rear is that the initial torque multiplication launched the car. If you were standing on the side of the car and watched me WOT take off, it would lift the car forward. In a 350 it would be a little more lopey... http://www.youtube.com/watch?v=pPfThh4dKRk
#71
I checked and didn't need to do any clearancing for the 1.65s on the 2800 with stock heads. It was close. You might consider trying it! cheap easy bolt on and easy to change your mind. |
