Old 03-24-2021, 09:09 AM
ta man ta man is online now
When my heads were reworked for the OF 2.0 Dave replaced the 99893 springs with Comp 26925 springs.
  #62
Old 03-24-2021, 09:48 AM
Steve C. Steve C. is offline
Comp Valve Spring Chart:
https://www.compcams.com/valve-spring-chart
The 26925 spring is located on page 301
Old information here:
  #63
Old 03-24-2021, 09:58 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Steve, I would imagine Dave used the Crane springs. It was one of if not the first set of KRE heads he did. He didn't use locators on mine, something he added to later versions, if memory serves me correctly.....
  #64
Old 03-24-2021, 06:53 PM
dmac dmac is offline
I have wondered for years about how high you can go with rocker ratio to 'soften' the lobe on the cam. I once had some 1.7 ratio rockers combined with Rhoads lifters on a cam similar to a Summit 2802 and it ran great. It would seem like a 1.8 or 1.9 ratio could use a much lower cam profile and maybe be less likely to bounce. What is the reason for trying to get more lift/duration from the cam lobe instead of the rocker ratio? And are there any parts made with such a high ratio that can be adapted to pontiac use? Is there enough material in the head to remove for the extra pushrod clearance such high ratio rockers would need?
  #65
Old 03-24-2021, 07:28 PM
Lift from Cam vs. Lift from Rocker Arm Ratio
If you Google that subject you will find some good information and opinions. It has been discussed here on PY, but I didn't find the specific thread.
And somewhat related if a solid cam is involved, a change in rocker ratio affects the valve lash. When a catalog suggests or states a specific lash figure that is typically based on a 1.5 rocker arm ratio.
  #66
Old 12-03-2022, 09:01 PM
65sport 65sport is offline
Originally Posted by Cliff R View Post
Interesting? I think I've been recommending adjusting lifters up from bottom out vs down from zero lash for several years now.
For decades I'd been running small block Chevy "stock" and "claimer" 350 circle track engines I've built here by adjusting the plungers bottomed out with a .010" feeler gauge between the valve tip and rocker arm and they spun up to really high RPM's w/o any issues. ..Cliff
I'm getting ready to fire a mild street build with flat tappet hyd. I'm thinking of using the bottom out method to adjust the lifters but I'm curious about the .010" clearance.
I was thinking I needed as much clearance as a solid lifter cam to keep the valves from staying cracked open. I was thinking .020" intake and .025" exhaust. But I see you running .010" clearance with no problems (I expect a lot more spring pressure), I'm only going to run 100lbs seat pressure.
