#741
Thanks Perfect
#742
Mikes Reply: We are putting the Trans. back to the Engine now, I will let you know when we run the Motor. I am not holding my breath though, that this noise has disappeared. Perhaps the noise was always there, I just did not hear it until the Heads were remanufactured, causing new Harmonics resonance within this Engine. The Pistons are backwards except for #2, Why. The racers reversed the Pistons for a reason, we know why. The #6 Rod is backward, and maybe more. Not good. The Pictures in the 1967 Pontiac service Manual are confusing at best. People made mistakes rebuilding these engines over the years and it seems that I have one of them. Let's see what happens when we get the Vehicle running again. I bought the Stethoscope, with the long rod on the end, we can now listen better, to isolate said noise, if it is still there. Mike out, thank you all for your help. Also, to find out that my Pistons are closer to TDC because they are installed backwards, is ironic since I spent all that time with the degree wheel just to find true TDC. Last edited by TRADERMIKE 2012; 12-02-2023 at 09:11 PM. |
#743
I agree to build a motor from the start the correct way, when you can. |
#744
From what I read, they had to raise the oil pressure up to around 60-80 psi on the SD engines, Nunzi had something to do with the repair with the factory reps. Or so have read? |
#745
Thank you for that information, good to know that others have their Pistons in backwards beside me and why. |
#746
Its about stock blocks only being able to take so much power, so much cam even if they are build right. Point is not pushing the limits of a stock block, just buy aftermarket and let it live a long happy life. |
#747
It was questionable that after the remanufactured Heads were installed, this latest noise occurred.
Not to discount that the Piston slap is the answer to this current noise, questionable is why do we all of a sudden hear it. My roommate and I discussed the current noise issue recently and we now think that the Heads, using the new gasket with the metal rings around the Piston area on both sides for sealing purposes, is also causing the noise or allowing us to hear the existing noise. We theorize that adding metal to the gasket, at the Piston surrounding areas, on both sides of the gasket, acts like an Acoustical Coupler, thereby enhancing the existing Piston slap noise so that we can now hear it. It is Kind of like using the Stethoscope with the rod on the end, that we just bought from Harbor freight, that is meant to touch the Block, so one can hear the internal noises of the motor and where they are located? What are your thoughts? We got the car to run, however we need to get rid of an exhaust leak and oil leak, before we can take it down and road test it, this week. |
#748
Before you build a motor up that will produce that high level of power take advantage of what others have found in hindsight, that being set the car up for it first !
#750
I forget what cam lift your running, but now that I see a picture of your heads and the fact that the springs still have the oil splash shields on them that could make for interference.
I need to dig out my notes, but above a certain amount of lift those shields need to not be used and then the tops of the valve guides need to get cut for positive type valve seals.
#751
What would be a realistic- body limit Vs HP range? I have sub-frame connectors, Herb Adams suspension and full roll bar. I do plan on enhancing the trans. and rear end to suit the Motor build. I am also keeping it as a street car. Keep in mind this is just a futuristic goal. Last edited by TRADERMIKE 2012; 12-04-2023 at 06:42 PM. |
#752
This comment of mine from post 750( yikes!!!!!) was in regards to your noise issue, not anything dealing with a future build.
#754
If he keeps it a street car he won’t need a aftermarket block,It would take a solid roller cam and duration of 200 @ 200 lift to need one.IMHO,Tom
#755
#756
"We theorize that adding metal to the gasket, at the Piston surrounding areas, on both sides of the gasket, acts like an Acoustical Coupler, thereby enhancing the existing Piston slap noise so that we can now hear it."
EGADZE! Did I read that correctly? Whatever you and your roomate are smoking I want some of it!
#757
Although I could call it a street-strip car instead! |
#758
Seriously, I want a reason why we can't be affected by the metal on the gaskets, Acoustical coupling amplifying the Piston slap, that you say is in my Engine. ANYBODY, HAVE EXPERIENCE WITH NOISE OCCURING WHEN USING HEAD GASKETS WITH METAL AROUND THE PISTON AREA, THIS IS MY FIRST TIME USING THEM. |
#759
Exactly the comp roller I’ve used in stock blocks is 195 @ 200 lift with total lift of .730 never a issue in stock block’s.
#760
Closed Thread |
