#601
If you worked for an Auto Company in the 1960s you would know that the engine development time "start date" for the components was YEARS ahead of the production year. Tom V.
#602
Over the first 4 years testing and tuning with the original worn out #886 Cam, I broke the sound barrier with this car, kidding, but I wore out the under rated Cooper tires at a rate of one a year reaching 130 mph many times. This car handles well at these speeds and holds to the ground. I would want to make a better front lower valance/spoiler in the future, if I wanted to go any faster and install speed rated tires to my set of fat rims...I have Hurb Adams suspension and Koni shocks on each corner and sub frame connectors. Bell tech. spindles, lowered 2" in the front. Also, the "041" Cam will take this car faster, testing and tuning will give me that answer. Last edited by TRADERMIKE 2012; 11-24-2023 at 04:15 PM. |
#603
P.S. Some of you have pull on the internet, here is the time to help me get this motor fixed to keep the Pontiac Vehicles alive. |
#604
THIS IS A QUESTION, "NOT" A BULL STORY, YOU CAN TELL BY THE QUESTION MARK AT THE END! However, during the 1966 Motor development for the 1967 models, "how many Tripowers were installed on the 1967 upcoming models (400 ci and 428 ci) and are there any factory records of them?" ALSO, IN MY READING, "IF YOU WERE LUCKY TO HAVE RECIEVED A 428 MOTOR, FROM THE FACTORY, IN A PONTIAC TRANS AM OR FIREBIRD OR GTO, YOU WOULD HAVE ONE RARE VEHICLE?", STATED IN SOMETHING THAT I READ, IN THE PAST, IF MY MEMORY SERVES ME. Last edited by TRADERMIKE 2012; 11-24-2023 at 05:06 PM. |
#605
What in the wide wide world of sports is a goin’ on here?
costs too much |
#607
Originally Posted by NeighborsComplaint View Post
I guess you guys aren't up on the regional options available on the 1967 GTO, specifically the " 3 Pot Lightning' " tripower option available only to moonshiners in the Appalachians. Moonshiners were known to love the '67 GTO for its larger trunk capacity and its understated styling which garnered it little or no attention from the revenuers on the backroads of Appalachia. WHERE DO THEY GET THIS STUFF, Tom S? " 3 Pot Lightning' " tripower option available only to moonshiners in the Appalachians." Must be trying to improve his typing skills with 10 times more posts in an hour vs any other member. TV I worked on only THREE FACTORY RA-IV 400 engines (in my whole life).
"Engineers do stuff for reasons" Tom Vaught Despite small distractions, there are those who will go Forward, Learning, Sharing Knowledge, Doing what they can to help others move forward. Last edited by Tom Vaught; 11-24-2023 at 11:41 PM. |
#608
This discussion is all over the map as it is, there's no need for sniping at each other. Keep it cool, guys.
#609
So the problem is that he has reversed his pistons and this will cause all kinds of problems because of the wrist pin offset.
So if the wrist pin offset has to be in the factory direction to not have any problems, then what problems are people having who run after market pistons that have no wrist pin off set? Stan
#610
You crepe up on the canyon ledge. One step away from going over the edge.
(Factory Pistons to zero offset pistons.) Now you reverse the factory offset pistons in the bores and you are over the edge and bad things will happen on a engine. the offset is now more that a neutral position. You get away with ZERO OFFSET, you have issues with NEGATIVE OFFSET. You went too far by installing pistons in a engine that was never designed by the piston manufacturer or the GM Engineer to run with in the Pontiac Block. What MIGHT work in a drag engine does not work in a street driven car or a road race car engine. Somewhat like installing a camshaft one tooth off from a proper setting. It will run but not well or how the engine was designed by the Engine Engineer. Simple Stan. TV
#611
The Heads need testing to see what improvements they make. In short, over the first 4 years we replaced the oil pump first, Splash shields under the valve covers next, rebuilt the Carbs. , bought new Copper tires, already came with the Timing chain and Gears. As we tested at high speeds, for a stock unknown Engine, we had to replace a few of the Push Rods over that time and we discovered as we serviced other problems concurrently, that a nut was cracked on one of the Rocker arm studs, between cyl. # 1-3 and that the cam, in some places, on the lobes, was worn beyond recognition. The Cam as well was wiped out. How I obtained these high speeds is beyond me. These Pontiac Engines must be very tough. After the first four years, going by memory, I am not looking back either, we installed the "041" Cam along with the Johnson Lifters, as a new set to mate them together. Butler Performance had us change the screw in studs to a beefier HD 7/16" version with the new nuts and a washer to lash the Rocker arms. They gave us a procedure to follow and we followed it too the letter. At that time, we also installed HD push rods, but we did not degree in the Cam until recently. We drove and tested and tuned and made many repairs along the way, we went 7000 miles approx. when we went over the root that damaged the Trans. The Vehicle sat for two years or more and we repaired the Trans in that time frame. Then we bought a more adjustable Timing Gear that we did not need, installed that and advanced the Cam and then put it back to zero advance. Then we bought the degree wheel and ended up trying different settings, until we reached the conclusion that no advance is best for this mostly stock Engine. That brings us to today's new issues. This is not the same Motor it was ten years ago. Since we did not install Roller type Rockers, we used the Push Rods that Butler sent for the project, there would "not" be a problem causing us to measure the push rods with the tool for that. We added ZDDP on each oil change and I use Lucas oil treatment in both my Vehicles, Van as well. When we installed the "041" Cam we used MOLY Lube on the Lobes and Cam Bearings. I HOPE THIS BRINGS YOU UP TO DATE. You ask: Thats great you think the bearings were OK visibly, did you measure the clearances of the Cam, Rod, Crank bearings? or just look at them? We saw that the Cam Bearings had the outer surface material and deduced that they could be used again and so we did, The Cam however was not. Yes, we measured the clearances of the Cam, Rod, Crank bearings, the info. is posted in this Thread, look at the attachment area please. I am not talking about "Amsoil VS ATF" and I wish you would drop the query over it. KEEP IN MIND, I NEVER TOLD PEOPLE TO RUN THEIR MOTORS WITH ATF, ONLY THAT A WISE OLD TRANSMISSION MECHANIC, RAN HIS OWN PERSONAL VEHICLE WITH ATF AND GOT 300,000 MILES, WITH REGULAR FLUID CHANGES. I DO NOT ENDORCE WHAT HE DID. FOR ALL I KNOW OTHERS MAY HAVE SEEN THOSE MILES SIMPLY CHANGING THEIR OIL EVERY 3000 MILES? Even if people use Deisel fluid, mixed with Trans. fluid to flush an Engine, is that written in any Service Manual? I am curious, I have not seen it in my research, however, I have listened to other Mechanics that use it. Marvel Mystery oil cleans the top of pistons, cleans Carbs. when mixed in the gas, etc... all from other people, BLA, BLA, BLA ... You said this: "Zinc in oil is a combo of zinc/phosphorus, called ZDDP, it is an anti-wear additive along with many other additives that are only in engine oil, not ATF, & they are VERY important for high wear areas like cam/lifters, even a few minutes without those additives in the oil, will cause major wear between those surfaces... 30 minutes without any engine oil would be terrible for cam/lifter surfaces & other internals... surprised nobody else mentions that. Thats great you think the bearings were OK visibly, did you measure the clearances of the cam, rod, crank bearings? or just look at them?" Mikes reply: Unless you do the test like the Trans. Mechanic, that proved his milage to himself, how could you know if it works or not. I say try it or prove it won't work on your own Vehicle, otherwise this is a mute argument, agree to disagree please, nobody cares, the topic is worn out, let's move on...WE ALL UNDERSTAND YOUR POINT. We have the Oil pan removed and we will be taking pictures of the lower end today while we inspect the Windage Tray and inner dip stick tube for looseness. Meanwhile the parts are on their way like the Flexplate and hardware associated with it. You said: Still waiting for a video of the engine noises so we can actually hear what's going on. Mikes reply: Soon, but I am praying the noise is gone by then, after I install these new parts, OfCourse! If the noise is gone, I will still post a sound audio clip for the forum. Mike out. Last edited by TRADERMIKE 2012; 11-25-2023 at 11:28 AM. |
#612
Bore = 4.12 Stroke = 4.0 Rod Length = 6.625
Wrist Pin Offset = 0.0625 Actual Piston Stroke 4.00019586433 Cylinder Volume 53.329262 CI 873.910023 cc Engine Size 426.634092 CI 6991.280186 cc Crank Angle Piston TDC -0.41519044173 Piston BDC 179.22570914187 Bore = 4.12 Stroke = 4.0 Rod Length = 6.625 Wrist Pin Offset = -0.0625 Actual Piston Stroke 4.00019586433 Cylinder Volume 53.329262 CI 873.910023 cc Engine Size 426.634092 CI 6991.280186 cc Crank Angle Piston TDC 0.41519044173 Piston BDC 180.77429085813 Stan
#613
Mike wants to know? Are these a copy of the other, they are different? Crank Angle Piston TDC -0.41519044173 Piston BDC 179.22570914187 Crank Angle Piston TDC 0.41519044173 Piston BDC 180.77429085813 Mike: After looking carefully, there are two sides of a piston and one side is closer to the top? Last edited by TRADERMIKE 2012; 11-25-2023 at 12:13 PM. |
#614
So then why did the OEM's on their top of the line Hi-Performance engines that they still had a warranty on use non offset pistons? Stan
#615
"You stated and I quoted that you put new Johnson lifters on the old 886 cam, that's all I was trying to clarify.", No Mike never said that.
The Butler people had me find the round part of the Cam and the valve is closed and we could spin the push rod some, with some tension on it, then 3/4 turn to seat the push rod into the lifter. We marked each push rod so we could see it spin, while running. The stud kit came with a Bolt a washer and screw in stud. And when you ask me something, please let me tell the story my way, it is only fair. I read that today's Motor Oil has no ZDDP, that is why I must add it to my old 1967 Pontiac. you said: "Not going back through all the pages, myself & others have lost track of most things posted in this thread. Thats great if you actually removed main/rod caps & properly measured for clearances, hope they were all within spec." No not yet, but we did provide some limited info. as I have stated. If I ever take this Motor down that far, to get those type of measurements, it would be rebuilt as I come back out, for sure. |
#617
This second-hand project came with the Pistons in backward and I, after 10 years, am just now discovering this, because we pulled the Heads off recently to have them reconditioned. |
#618
Sorry for trying to clarify some things that arent very clear or providing facts on some of the statements made, there is no argument on my part, just stating facts in an effort to help, but apparently myths & flawed opinions over rule facts. |
#619
Since this is a Pontiac Site the Pontiac Pistons will do fine, Stan. Tom V. Example TRW supplied Offset RA-IV Pistons as a OEM Supplier. Still have the Specs from Dennis Novotny (a TRW Piston Engineer there) RIP Dennis. Tom V.
#620
I am sure someone will correct me if I have this wrong. The information I have says the 455 SD had pistons with no offset. Stan
Closed Thread |
