Old 11-11-2021, 01:37 PM
98 SNAKE EATER 98 SNAKE EATER is offline
Originally Posted by Kenth View Post
1967-74 Pontiac Q-jet, except 455S.D., uses 2.745" length pump assembly.
455S.D. uses a 2.556" pump assembly.
1975-79 uses a 2.572" pump assembly w/garter spring.
I contacted QJetparts, gave them the number stamped above the bowl and they said to use this one.....
https://quadrajetparts.com/quadrajet...32-p-2050.html
2.61" w/garter spring
Does it really make much of a difference either way?
  #42
Old 11-11-2021, 04:09 PM
Kenth's Avatar
Kenth Kenth is offline
Not really, but i would contact Cliff Ruggles at Cliff´s High Performance as i understand he has the best acc pump seals available.
https://cliffshighperformance.com/pr...-pump-assembly
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
  #43
Old 11-11-2021, 04:36 PM
Question
Thanks for the info
What exactly do they mean by this?
"We will cut the accelerator pump groove on them by request for the Pontiac Ram Air carburetors, at no additional charge."
Is there an actual difference between RA Q-Jets and standard?
  #44
Old 11-11-2021, 05:51 PM
70TA-RAIII 70TA-RAIII is offline
The RA carbs came with a little rubber boot that covers the exposed area of the pump shaft. The boot fits into a little groove at the top of the shaft.
They'll cut the groove for you if using that boot.
John
The Following User Says Thank You to 70TA-RAIII For This Useful Post:
  #45
Old 11-11-2021, 10:34 PM
Question
John
Were those really limited to the RA carbs?
Over the years I've seen countless QJets with boots (although not always accordion style.....some looked like a solid rubber boot)
This one does have it though
  #46
Old 11-12-2021, 06:53 AM
Kenth's Avatar
ONLY Pontiac Ram-Air Q-jets has the airhorn machined for the rubber boot retainer ring.
You may add the boot to any Q-jet (sans the retainer ring), but ONLY Pontiac Ram-Air Q-jets had these from factory.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
  #47
Old 06-07-2022, 10:42 PM
Originally Posted by 98 SNAKE EATER View Post
So I've been lookin into other electric pumps apart from the Airtex I posted before....
Contacted Facet, who supplies pumps for Holley and they suggested their 60106 POSI-FLO, which is the same thing as Holley's Mighty Mite 12-427
Question
Would I have any issues mounting one of these pumps vertically?
I'd want it to be completely hidden without cutting any of the hardlines, so I was thinking about just extending the rubber lines and mounting it behind the quarter kinda like this (some high quallity rendering, I know)
OK, so a little update on this....
Sorry for the bump, but I only get to see her about every 6 months
Ordered up a Mighty Mite knock off from Amazon (still made by Facet, but cheaper than the Holley branded version at only $25 bucks)
Went with the low pressure 4 psi max version (12-426)
Added a 90* brass elbow and looped a rubber hose to the main line
Left the plugged return line as is
Tucked the pump away as much as I could without touching the tank and wired up a momentary switch to the ignition (hard to tell, but the button is actually countersunk and recessed, so it's completely invisible unless you go snooping under the dash)
Works great
  #48
Old 06-09-2022, 02:13 AM
Formulabruce's Avatar
so your stock pump is sucking through the 1 way valve in this pump when running? Gas isnt too got there?
nice installation !
  #49
Old 06-09-2022, 05:30 PM
nice installation !
Yes, it's a flow-thru pump with very little restriction (feels like you're blowing through a fuel filter).
I just hold the button for about 10 seconds to fill the bowl, then start her up and let the mechanical pump take over.
I used the low pressure version to avoid any possiblity of flooding.
Folks over at Facet said the majority of their pumps are designed to flow through and will work fine for this application.
The Following User Says Thank You to 98 SNAKE EATER For This Useful Post:
  #50
Old 06-10-2022, 03:48 AM
Kenth's Avatar
You need to get the correct PCV fitting to the intake, right under the fuel inlet on carb. were the hole is plugged.
At your picture you have all the crankcase fumes into #1 runner.
Name:	pcv 003 (2017_10_12 10_38_49 UTC).jpg
ID:	592547   Click image for larger version
Name:	pcv 008 (2017_10_12 10_38_49 UTC).jpg
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
  #51
Old 06-10-2022, 08:42 PM
70 Blackbird 70 Blackbird is offline
Thinking that I need a couple of those pumps.. Firebird for after it's long winter slumbers and an old carbed Chevy that vapor locks when it heat soaks.. I didn't have any luck on Amazon finding anything under $60.00.. Snake Eater, could you provide a link for what you purchased?
  #52
Old 06-11-2022, 11:22 AM
Already installed one (see fuel line thread)
https://forums.maxperformanceinc.com...d.php?t=854709
The plug was a PITA to remove
  #53
Old 06-11-2022, 11:26 AM
Looks like the price has gone up to $31 since I placed my order, but I did get it on a Flash Sale
https://www.amazon.com/12-426-Electr...26541192&psc=1
The higher volume/pressure version (12-427) is now $29
https://www.amazon.com/12-427-Electr...15399961&psc=1
  #54
Old 06-11-2022, 04:26 PM
Thanks Snake Eater.... Much appreciated!!
