Old 02-25-2019, 08:44 AM
455TA's Avatar
455TA 455TA is offline
This 80mm Turbo 6.0 LS engine in a 2nd gen camaro runs 8.90's/152 mph at over 23 psi with the FiTech 1200 PA system, with the stock injectors that comes with the unit.
https://youtu.be/jEvlsJD3suw
1980 Trans Am - Street/Strip 462
Best: 7.08@95 with 1.49 60' in the 1/8th. 11.17@119.8 in the 1/4. N/A, 3700 lbs, 3.42's, Pump Gas.
Admin of Pure Pontiac Powered Outlaws on Facebook.
  #42
Old 02-25-2019, 09:36 AM
TransAm 474's Avatar
TransAm 474 TransAm 474 is offline
Yep, I had forgotten about his car, I've seen him post over on the Fitech Owners Group Facebook page in the past. If I remember correctly, I think there is a white 3rd gen Camaro with a procharger that is running in the 8's as well with a stock 1200 unit.
1978 Trans Am
Pump Gas 461 Stroker
  #43
Old 02-25-2019, 09:50 AM
er455 er455 is offline
I never understood how a carburetor could make more hp than 8 injectors (80lbs) thru jets and sqirters . ... I currently have the fitech 1200 on e85 and they tell me that it’s good for about 850 hp .. my boost is set at 12 # and is probably maxed out ..
  #44
Old 02-25-2019, 10:55 AM
johnta1 johnta1 is online now
I'd say one problem with EFI is that the injector can't open/close quick enough to feed the cyl. without a very expensive setup?
(or more than one per cyl)
MFI works great but usually at full throttle.
If doing idling and cruising the nozzles/main pill would probably not be optimum.
(there are extra setups/circuits that can be added to make it work)
  #45
Old 03-01-2019, 12:49 AM
I have been playing with the Borgwarner Matchbot, switching between different turbo's to see the difference's. I am a complete novice when it comes to reading compressor maps, but after looking at the S475 map, S480 map, and this 14009097010 Supercore 80mm map, it looks like it would be the better turbo for sure to my eyes, at least going by efficiency, not sure about spool difference. All three turbo's I entered with the 96 turbine with the 1.32ar housing. What do you see from looking at the following screen shots, does it look like a great turbo for the street to you? Looks like to me it would be fairly efficient at 8-10 lbs of boost, as well as 15+ if I wanted to crank it up a bit, unless I'm reading it wrong, because like I said earlier, I'm a novice at reading compressor maps. I was originally thinking about the S480, but I believe the Supercore 80mm 14009097010 turbo would be the better choice.
ID:	506872   Click image for larger version
1978 Trans Am
  #46
Old 03-01-2019, 12:59 AM
Just for comparison, here is the S475 Map
1978 Trans Am
  #47
Old 03-01-2019, 01:00 AM
And the S480 Map
1978 Trans Am
  #48
Old 03-04-2019, 02:36 PM
Anyone have any experience with the billet S400SX-E 80mm Supercore 14009097010 turbo I mentioned above?
1978 Trans Am
  #49
Old 12-01-2021, 08:27 AM
Originally Posted by TransAm 474 View Post
Good afternoon, I am thinking of doing a Single turbo on my street 461, and I would like your input. I initially had plans to upgrade the heads to KRE, along with a street Solid Roller and Northwind intake, but I have now changed my mind, and think I can possibly have a street car that is more fun by keeping my ported iron heads, and stick with a solid flat tappet camshaft, along with a single turbo and maybe 8-10 lbs of boost, and maybe cost less.
Here is what I have currently in the vehicle
-1974 Pontiac 400 2-bolt block
-Bottom filled to center freeze plug with Pontiacdudes block fill
-ARP Main Studs
-4.155" Bore
-4.250 Eagle Cast crankshaft
-Eagle 4340 H-Beam 6.700" rods
-Ross Flat Top piston 1.385" Comp. height
-Decked to 10.215" (piston .005" in hole)
-Felpro 1016 .039" Head gaskets
-SD Performance Street hand ported 6X-8 Heads 2.11/1.77 Ferrea valves, heads flow 245@.550 int 182@.550 Exh. and Chamber around 100cc
-Current camshaft is an old custom Ultradyne Solid Flat tappet 288/301 Advertised, 255/267@.050, .540"/ 552" lift with 1.5 Harland Sharps, 106° Intake Centerline, 112° Lobe Separation
-Crower Solid Flat tappet lifters
-Rollmaster billet timing chain
-Romac Aluminum/Steel Damper
-Performer RPM Intake
-Quick Fuel 750 downleg carb
Mallory billet distributor
Mallory Powermaster Coil
Mallory HyFire 685 ignition box w/boost timing retard
-1 3/4 Hedman headers
-Dual 3" Exhaust, Dr Gas Xpipe, Dynomax Ultra Flow mufflers, Pypes 3" tailpipes
-TH400 Transmission, 34 element Sprag
-TCS 2800 stall 11" Torque Converter ordered through Dave at SD Performance for a older RA 4 cammed 455.
-Rear Gear is 3.73
-1978 Trans Am 3800 lbs
-Premium Pump Gas Street Car
Ok, now.... I want to put a Single turbo on this and I obviously want to change a few things to work better with the turbo. The camshaft is one of those things, as I figure the current camshaft probably wouldn't work to great with a turbo, so I have contacted both Mark at Bullet and Butler to see what they recommend for another solid flat tappet camshaft that will work well with the turbo, I'm still awaiting their responses.
The second thing I want to change is the Performer RPM intake to maybe a hurricane or Northwind to work better with boost.
I will also be changing the carb for the Fitech 1200 Power Adder EFI system, and I will initially use it to control Fuel only, and control my ignition system seperate.
The third thing is the Torque Converter, I'm thinking either a PTC, or I will get in touch with Cliff and order one through him, or depending on what the cam specs look like, maybe my current converter may work ok, but I almost bet it would be too loose.
Fourth is a Rear Gear change, maybe change it to a 3.23 or 3.42. Current 3.73 is probably a bit to much for a turbo.
Ok, I think that is most of the changes I would like to make to provide a better combination for the turbo. I have been looking and doing alot of research of two turbo's... I have came down to the BorgWarner Cast S480 with a 96 Turbine and 1.32 AR T6, or the VS Racing 80mm billet with a 96 turbine and 1.32 AR T6. Both are close in the same price range, but obviously the VS Racing is an imported turbo. I'm not an expert on turbochargers, so I'm not sure of the street durability of the VS Racing, and I do know that the factory uses Borgwarner turbos on alot of factory turbocharged vehicles, so they are known to be durable I suppose. The VS Racing turbo is appealing, because it is 100 bucks cheaper and has a billet compressor wheel vs the S480 cast wheel. I'm for whichever turbo would be more durable and work best for my application, because the price difference is not much.
From my research so far, it looks like 2 1/4" crossover pipes would work great for the street. For the downpipe, I would keep it 5" for as far as possible out of the turbine, and then reduce it down to 4" and then somehow split it back into my dual 3" exhaust, I havent given that part much thought as of yet, but there is only so much room to work with. I want it to spool as quick as possible, without any lag issue, since this is a street car.
Due to the 9.1 compression, I only want to run just 8 lbs or so of boost, maybe 10 at the most, on pump gas. Maybe increase it 5 lbs at the track along with 110 octane fuel, but it will be mostly street driven on low boost, and needs to have good drivabilty.
With this combination I also want to keep the RPM relatively low, maybe around 5800 max, and maybe make around 750-800 at the crank with room to grow if I want to crank up the boost a little with race fuel. I'm really not sure what it would be capable of, but I know it would be fun.
Any thoughts , input , tips would be appreciated greatly. Thank You
I don’t know how your going to fit a 5” downpipe in your project but if you do I would love to see some pics , I have a 3.5” and it’s tight . I have to change spark plugs by jacking car up and go thru the wheel well
  #50
Old 12-01-2021, 08:51 AM
bankbook's Avatar
bankbook bankbook is offline
Without AC and a clean (no AC) firewall it can fit. But, as you say spark plugs are removed from wheel well.
Curious how this build came along.
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
  #51
Old 12-01-2021, 12:33 PM
ErikW's Avatar
ErikW ErikW is offline
Here's our 78 Camaro 6.0ls 80mm turbo w 5" down pipe to dual 3" exhaust. It fits. It's tight, but it fits
ID:	578920   Click image for larger version
1964 GTO
9.76 @ 137mph
1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112
1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159
2009 G8 GT
  #52
Old 12-02-2021, 06:04 PM
Curtis Slowe Curtis Slowe is offline
I had a 5" downpipe on mine to the rear of the transmission then I necked it down to 4" on out to the bumper. I have no A/C box and built my own filter relocation adapter with the lines angled forward so no oil filter adapter in the stock spot. Had plenty of room and I changed plugs from the top just fine. Now I have a fender exit but probably will put the full exhaust back on. I just want to split the 5" into dual 3.5"s or two 4"s when I do instead of one 4". This is an old picture and the only one that I have I think. I'll post a picture of the adapter I made when later tonight.
ID:	579022   Click image for larger version
  #53
Old 12-02-2021, 10:27 PM
Default Downpipe pics
Thanks guys for the pics I guess it’s possible
