#41
Both zinc and cadmium plating are silverish in color. The color comes from a chromate that is is applied after the zinc or Cadnium. Most yellow plated stuff prior to 1973-74 is Cadmium. The EPA came down on Cad plating and GM switched to Zinc. So if it’s yellow or silver it could be either one
#42
Thanks Norwood! Maybe I will scrounge up a load to go to my local plater and add this part.
...Steve T. "Resurrection of a 1970 Trans Am" Blog www.455hota.wordpress.com ------------------------------------- 1966 GTO 4 speed Hardtop Alabama car (Marina Turquoise w turquoise interior) 1970 TA 4 speed Canadian car (Lucerne Blue w bright blue interior) |
#43
Pics are interesting. Even the OTC units were always silverish or zinc. This unit was same as the Venturas, Nova, Apollo , and many more probably. Maybe there was more than one supplier for the original assembly, which makes sense. We see this in Bolts on the same car.
#44
This is one the one I Had..nos lense and replated in gold.
Has gasket and ground too. I felt it was correct for 69-73.
Mike/Illinois |
#45
Did you remove the socket and wire for it to be plated? Looks like the socket is plated as well.
1970 Trans Am 1971 Trans Am 1974 Trans Am 1978 Y88 Trans Am W72/auto 1979 10th Anniversary Trans Am 1984 Trans Am 1993 Trans Am 1999 30th Anniversary Trans Am 2001 10th anniversary Firehawk #104 2006 GTO |
#46
Makes sense, it is part of the assembly and the rest added later.
