Old 01-11-2018, 12:36 PM
6567GTO's Avatar
6567GTO 6567GTO is offline
In a straight axle gasser syle car with the original front frame and crossmember replaced by rectangular tubing, along with front to rear braces, is using a steel front and steel mid plate enough? Or do I need a cross member added back in? It also has a 10 point cage.
  #42
Old 01-11-2018, 01:18 PM
RA462's Avatar
RA462 RA462 is offline
Originally Posted by grandville455 View Post
Looks good! That's basically what I'm gonna do with my bird too, even tho its street driven, need room for the diaper etc. where are u gonna mount your brackets for your for and aft bars?
I left them out. Probably should add them one of these days. The car has just been sitting. Too many other things going on the last 2 years.
Todd Sedlmeier
Who ever thought pinewood derby cars would lead to this!
October 2004 HPP Shootout participate
http://www.highperformancepontiac.co...out/index.html
86 Grand Prix
535 High Port 8.93 @ 153
65 GTO
433 High Port 12.04 @ 113
  #43
Old 01-15-2018, 09:14 PM
JSPONT's Avatar
JSPONT JSPONT is offline
Default got it!
Got the mid plate today. 32 inches long, close to where it will mount in my frame rails is 28.5 inches, so there is enough meat to do what you have too. I took the 6 converter spacers out, it did not come green I sanded and put a coat of self etch primer.
Can't wait to get the heads and tranny back so I can start this. I have soooo many projects on the car now!! It's snowballing!
  #44
Old 01-16-2018, 08:24 AM
grandville455's Avatar
grandville455 grandville455 is offline
Nice! So Are you going to use a front plate Also?
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
  #45
Old 01-16-2018, 01:37 PM
janderson's Avatar
janderson janderson is offline
Don’t want to over complicate your project, but something we did on my ‘78 that really works well was to put a locating dowel on each frame bracket for the mid plate. Load the engine/trans, locate mid plate on the dowels, tilt/lower to align front plate bolt holes and done.
Old 01-16-2018, 03:01 PM
JSPONT's Avatar
No I am not going to use a front plate. It is a real street car, I am running the poly mounts from Butler, and I was thinking of putting an isolater in between the mid plate and frame mounts for the mid plate to help with vibration.
  #47
Old 01-16-2018, 03:03 PM
JSPONT's Avatar
Great ideal!! I think I will do the same.
  #48
Old 01-16-2018, 06:06 PM
Robert C.'s Avatar
Robert C. Robert C. is offline
So take the top two engine trans bolt holes and install a long thread stud and lock tight it in . Use these studs to slide the motor in and put nuts on the back side. After you mounted a front plate weld angle iron horizontally under the plate for support and in front of the mount. You drop in the Motor and rest the front plate on the angle iron and just slide it in place. Works great.
Our Front Plate for a 78 T/A fits great and you don't even notice it. You install it with the STD motor mounts in place and the remove the mounts after it is located. See our site for pictures.
Bob C.
Quickest, Fastest, Best selling Pontiac Aftermarket Block IA II and Tiger Heads
Boss Bird Funny Car
Best pass to date 08/06/2016 6.027@231.64
Allpontiac Big Chief Aluminum Engine Block
http://www.AllPontiac.com
  #49
Old 01-16-2018, 08:42 PM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is online now
Ive run these, just welded them up some to adapt pattern to a bop. Probably not as strong since there is a seperate piece each side. But bolts to backside of trans so no spacers or longer dowel pins to deal with.
https://www.speedwaymotors.com/Speed...unts,3278.html
Illinois Outlaw Gassers
6.27@107
9.97@131
  #50
Old 01-16-2018, 08:58 PM
Bob, Does your front plate clear a manual steering box on a 74 bird?
Darby
  #51
Old 01-17-2018, 09:26 AM
Robert C.'s Avatar
Darby,
Contact the office and ask Frank. He would know best. I know for sure it works on a power steering car. We have sold more then I can count of the F body Front Plates.
If it does not fit you may return it if not cut up.
Bob C.
Boss Bird Funny Car
  #52
Old 01-17-2018, 10:06 AM
Darby,
Will Do Bob, Thanks!
Darby
  #53
Old 01-28-2018, 07:09 PM
JSPONT's Avatar
Default progress
Got it cut to fit in between the rails, I trimmed near my oil filter housing to make it easier on me. Waiting for my tranny to come back so I can connect it and mount it, then I can clamp and weld the side brackets and bolt to the mid plate. pretty simple job.
The one photo is my old mid plate lol.
  #54
Old 01-28-2018, 07:10 PM
JSPONT's Avatar
I have no idea why my photos turn when I post to this site!!!
  #55
Old 01-28-2018, 07:55 PM
Does your oil filter tilt back back at all? Mine is the angled one , will it still clear the plate?
Darby
  #56
Old 01-28-2018, 08:39 PM
n2ogpsj462's Avatar
n2ogpsj462 n2ogpsj462 is offline
Looks like it's dual pattern for the trans? Might go this route after seeing your thread and it'll be money if dual pattern. Just weld a nut on the back
71 grand prix SJ 4280# 462 new for 2008 -
8.7:1 , 98cc 6Xs 246/209, 342 12bolt , BW S475 turbo JGS 50mm WG 56mm BOV. 600hp the easy way!
  #57
Old 01-28-2018, 09:32 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
Or ditch stock frame and do one of these.
Btw my stock frame with rack mounts, bop motor plate mounts, mid plate mounts and oil pan cut out will be for sale if anyone needs a nice modified stock frame.
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046 jet
First ultra street/ultimate street NOS car to get into the 4's!
1.079 4.559 153.23.
3100 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
T2TTFMF!
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #58
Old 01-28-2018, 09:41 PM
JSPONT's Avatar
Mine angles in, it clears, I just trimmed the bottom of the plate to make getting the filter wrench on easier.
  #59
JSPONT's Avatar
Not sure what the other pattern is for, but yes there is a dual pattern.
  #60
Old 01-28-2018, 09:44 PM
JSPONT's Avatar
SBP LOL! Nice set up. Not sure it would work for an a body. What are you going to now?
