#41
Be concerned about durations and the centerlines. Even better opening and closing events, at the valve is best. LSA will take care of itself. https://ls1tech.com/forums/generatio...-t-matter.html |
#42
So one guy in the other corner of the universe believes LSA doesn't matter.....really?
How about a link to the last Pontiac 455 he built with "smog" 6X heads on it, including the head flow numbers, dyno numbers, and track results after it was placed in service? If he did those things and made it that far how about the intimate details of the vehicle that it was installed in including race weight with driver....tks............Cliff
#43
I'm not surprised you don't know Chris Straub.. LOL
When you can tell an SS racer with decades of experience to adjust the intake lash a bit this way and then the exhaust lash that way. Then he runs 2 tenths quicker.. Ain't NOTHING special about Pontiac! Thinking this only holds the community back. Or call Mike Jones, Kip Fabre or Bullet Cams and ask them.. LOL |
#44
LSA doesn't matter? Since when ?
#45
Read the first post of what he says, ideally read for a few pages.
Get the valve events correct and LSA falls into place. If you have two cams on 110 LSA, first durations are 215 / 225 the second durations 220 / 220 - just random selections. Running engines will not 'see' the common LSA of 110. Valve open / close events and overlap vary and these are what an engine responds to. Last edited by pastry_chef; 12-30-2017 at 07:08 PM. |
#46
Tell that to every Super Stock racer in the country !
#47
Actually Paul has shown and posted at least a half dozen dyno sheets of Pontiacs he's built over the last couple years that shows how those Voodoo cams have a nice broad flat torque curve despite their tighter LSA. They don't run out of steam early like a typical tight LSA cam.
#48
NOPE,,
Only ask the record holders! Quote:
#49
I will agree that Changing LSA is going to make a huge difference in most cases. But to say LSA will fall into place is kinda silly. Next we are going to say valve lash doesn't matter ! Or it's only 2 jet sizes! It might not make a big difference! But it does make a difference.
#50
[QUOTE=pastry_chef;5827846]NOPE,,
Only ask the record holders Trust me I have . |
#51
You don't understand how correct valve events will dictate LSA?
Please read that link. Maybe not everyone can understand, I'm not sure. My mind is visual mathematician, it lends well to this. And? Last edited by pastry_chef; 12-30-2017 at 07:48 PM. |
#52
[QUOTE=pastry_chef;5827851]You don't understand how correct valve events will dictate LSA?
Please read that link. Maybe not everyone can understand, I'm not sure. My mind is visual mathematician, it lends well to this. Let me ask you this? How many people get the correct valve events for every engine. In a perfect world LSA wouldn't matter. But they just pick a cam from a manufacturer. They don't work with a cam grinder. They don't work with a engine builder. They just pull a cam out of a book or online. |
#53
"I'm not surprised you don't know Chris Straub.. LOL"
Never heard of him, mostly because you won't find me Googling this shi@ to death just to find folks who agree with my line of thinking just to satisfy my ego. Don't have time for it and much prefer to go out and get dirty and learn the old fashioned way. If and when I want advice I'll call someone like Dave at SD Performance and compare notes. Anyhow, take a look at the dyno sheet below and tell me that the cam manufacturer knew how to recommend a cam for a 455 Pontiac engine with 9.3 to 1 compression and 250cfm #96 "D" port heads. Yes, the engine builder called them for cam advice in his first ever 455 engine build, and they told him to use the XR276HR cam in it. Besides not making much power it would NOT manage pump fuel on the dyno with "normal" timing and fuel curves in it, and when they tried to advance the timing to make reasonable power it pounded the rod bearings out of it. I got a call only because EVERYONE from the dyno operator to the janitor was blaming the Q-jet. Instead of talking about the carb, which was fine, I told them to throw that POS cam down over the hill and install one that I recommended instead. I told them to have Comp grind it on a 114LSA and install it at 110ICL. I got a call after the cam swap, engine repairs and new dyno runs. They also noted that it idled better than the smaller cam on tighter LSA that it replaced. Defies the laws of physics IF you buy into the BS we continue to read on these Forums about cam selection. LSA is not only important, long stroke undersquare 455's with heads having not much more runner cross section than an average SBC head are very sensitive to the intake closing point, size of the cam and the lobe positions.....but you'd only know this IF you built a lot of these engines and dyno'd them, then installed them in vehicles to see how they behave on the street, then take them to the track and get real numbers on them. That's what I do here vs googling these topics in vain just to try to find someone who agrees with my line of thinking.......FWIW......Cliff
#54
Many people don't degree their cams either. Most do the same for other engine components, grab something off the shelf. Or worse, fall to bigger is better syndrome. |
#55
Cliff, was the only change between the cams just the LSA ? That's a HUGE difference between the two dyno runs .
#56
How about .335 lobe lift to .380 lobe lift? Then there is the seat timing. Talking about LSA in your example is playing in the field without a ball. The bigger lobes on 110 would have dyno'd BETTER yet. Quote:
Misleading isn't it ? Last edited by pastry_chef; 12-30-2017 at 09:21 PM. |
#57
Well, for my purposes if overlap will be my enemy for good emissions the 703 will definitely have more because it is going the wrong direction in two ways. Both the longer duration and the tighter LSA will increase overlap. I feel like people are talking past each other here. Of course LSA, overlap, duration and all these things matter. But if, for example, you are simply changing the LSA on a cam with the same lobes then you can use LSA as a proxy for overlap. We all do things like this when talking about complex subjects. I have no doubt that the 703 would perform well. I also have seen nice broad dyno charts. But I do doubt it would pass emissions unless someone has experience to tell me otherwise
-- Sam Agnew Where you come from is gone; where you thought you were going to, weren't never there; and where you are ain't no good unless you can get away from it. Ministry - Jesus Built My Hotrod |
#58
"Talking about LSA in your example is playing in the field without a ball.
The bigger lobes on 110 would have dyno'd BETTER yet." That statement just proved to me that you have absolutely ZERO experience with these things, and I'm going to have to stay up another half our or so because I'm LMAO! My example shows what happens when you install the wrong cam in a 455 build and how much power you leave on the table, plus it pinged on pump fuel and it idled like crap. The WORST cam you will ever put in your 455 street engine will be a relatively small cam on a tight LSA with an early intake closing event. My example isn't misleading anyone, you just have the need to down-play the EXCELLENT results instead of noting that the new cam outran the first one in every single category, and it was on a 114LSA, which you continue to disregard. So let's talk about your completely useless and meaningless post earlier about LSA doesn't matter. Let's take my cam recommendation in the example above and put it on a 110LSA and install it at 106ICL. Now you have a complete TURD for a 455, worse than the Comp XR276HR cam because is has WAY too much overlap, doesn't idle for shi@, sluggish off idle, no real power in the "normal" driving range, etc etc. You'd have to raise the static compression ratio at least full point before it would ever start to even act like it was going to work, or, as I did move it out on a 114LSA and enjoy a real pump gas 455 engine with decent idle quality, great street manners, pump gas friendly, AND it made nearly 90 MORE HP than the camshaft Comp recommended for it in the first place........Cliff
#59
Your thinking on the subject is spot on Sam. Folks have recommended the 703 and even given you examples, but don't forget the basic rule of thumb with these things. If the 703 is a "home-run" in a 455 build at 9.5 to 1 compression, for example, it is NOT going to be the same deal in your much lower compression 455. For every full point of compression lost you need to loose 10 degrees of seat timing to have it act the same way at idle, off idle, and low rpm's. EVERYTHING would suffer in terms of vacuum made at idle speed, idle quality, throttle response right off idle, and efficiency in the lower rpm range. That's where those who are seriously lacking in direct experience with these things continue to make very poor recommendations for camshafts here........FWIW........Cliff
#60
If it makes you feel better, Paul stated you can order that 703 on a 112 if you wish. As far as emissions is concerned, if you want to really push the envelope with cam choice it's probably going to be trial and error on your part because you are treading into an area that 99% of us don't have to deal with on our classic cars over here in the states. |
Closed Thread |
