#41
Did you ever get your original H~O headers back? If not, I have an original set of Tri-Y-bal Tubes when they were first being made by Doug's. These are the heavy duty (16 ga?) tubes and flanges, not Ron's later version that he made changes to the tube routing and pipe gauge. Let me know, John
John IG: @crawdaddycustoms YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos |
#42
John, yes I did. Believe it or not, someone in the "Pontiac family" contacted me a couple of years ago who stumbled across them in a shop somewhere(maybe DOUG's), saw my name on them, contacted me and now they are back in my hands.
On another note, I spoke with a hot-rod in my area who is willing to fabricate the tri-y headers for me. Come to find out we both have a mutual friend(my neighbor) and he lives right around the corner from me. My neighbor never mentioned the guy nor his company. It's one of those "small world" type of introductions. Anyway, we plan to discuss materials, costs, building a jig with the headers I'll supply to him for both "D" and "O". I'll bring my T/A to him and make sure they fit properly, then make a decision on whether or not we move forward. As of now, his forecast to get started will be early next year. From what I have seen on my neighbors cars with his headers, his quality is top-notch. Stay tuned.
Home of WFO Hyperformance Shaker induction. |
#43
Good deal!!
#44
Larry, send me a pm if that becomes reality
#45
Larry,having been involved with Tyree for WAY too many years he explained the problem with production headers.I watched him make maybe 20-30 jigs over the years.The problem was the car the custom set was made on to make the jig.A brand new off the showroom car lead to many problems.The suspension was all tight and when headers were made and put on a worn out suspension car there were many problems especially with stick shift cars and even more when you got into big tubes like 2in.Good luck with the project and hope it works out for you and the hobby.Tom
#46
So this overall lowered body to frame, places the engine and installed shaker closer beneath the hood, where clash interference problems arose. Yes, something to consider when developing the headers.
#47
No problem Larry.
Chris, moderators, whomever - please feel free to lock and edit this thread as you deem necessary. My intention was to show performance changes (whether good or bad) from going from a set of stock log manifolds with stock headpipes, to a set of headers, with no other changes than needed adjustment to the AFR. If I had not been worried about ground clearance issues with my current suspension and the headers I bought from Steve Coombes, THOSE would have been the headers used for the test.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
#48
I use 2nd gen firebird headers for my Gp's. have had some fitment issues on the pass. side with A body headers. the foremost tube hitting the frame. I currently have some 4 tube hookers on my '70 and they fit very well, although they hang a little lower than I'd like.
if Larry is able to produce his headers for the 2nd gen firebird, I'm sure they will fit well on the '69-'72 Gp. |
#49
Im not sure if you are talking about me but I do remember contacting you about your Tri-Y’s being at Ron Watt’s shop (Tribal Tubes) and getting them sent back to you. I apologize if Im mistaken. Don
1966 GTO 1966 421-9.3-1 comp-Race Tec 23cc Pistons 1966 Tri-Power 1967 670 Heads Pontiac "Highlift" TriPower Cam by SpeedPro DUR 214 Int 224 Exh @.050 - 107 ICL LIFT .445" Int .465" Exh Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers 1966 Muncie Wide Ratio 4-Speed 1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears |
#50
Yes thank you Don. I knew they had to be in a shop somewhere but couldn't remember where or who it was that contacted me. Hell, these days I have a bad case of CRS so thanks for the refresher.
#51
Don
#52
I believe I earlier stated that the car had 2.25" tailpipes. Well, they are actually 2", and compression bent, so even smaller in several points!
Car is now in the muffler shop. It will be all 3" soon :-D
#53
Wow! Small pipes.
#54
Today I plan to meet with a local fabricator who produces specialty headers for LS type conversions. Looking forward to what he can do, what it's gonna cost to get started and a time frame to do it.
#55
Alright! Can't wait to hear the results, Hope it goes good for ya.
#56
Tube headers on my 62 Cat 389 made no difference in ET over the long branch cast iron manifolds. We are talking about open headers here. The long branches with a foot or so of exhaust pipe on the end.
#57
Had my meeting and............................................... ....no go. Main issue, PRICE. Meaning RETAIL price. Pontiac guys won't spend the kind of money it will cost for the quality of headers he will produce. Chevy LS guys WILL spend the $$$$........... but not "our" guys. I could stop going any further but I will continue to pursue other options. As I recall, the "tribal tubes" sold for around $500 -600 ???? Impossible for me to even get close to that. I'd have much more $$$$ just in manufacturing and that is a very conservative figure. Materials, 304SS, tig weld, etc., labor is not cheap.
Home of WFO Hyperformance Shaker induction. Last edited by Larry Navarro; 12-30-2017 at 01:14 PM. |
#58
That price was for mild steel, I would think SS would definitely be well over 1K.
#59
SS is WELL over 1K. From the discussion I had with fabricator, the cost to have the mild steel headers built, then add in aluminum coating, it would NOT be much more for building SS headers.
Home of WFO Hyperformance Shaker induction. Last edited by Larry Navarro; 12-30-2017 at 04:34 PM. |
#60
The latest $ from T/T was 500 uncoated 800 coated shipped
