#41
In a reprinted interview from the 70s in a 2001 issue of Pontiac enthusiasts mag, Malcolm Mckellar stated that published compression ratio's of 10.75 by the factory where way more like a true 10 to 1!
Only when the HP ratings where switched to net do the compression ratio's reflect true world numbers it would seem.
#42
I would agree to that. My car ends up (using published numbers) at 10.3 where spec. is 10.75.
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. |
#43
Jeff |
#44
So how thick were the factory gaskets in the late 60's??
#45
There may be deviations from this, but most of them were a steel shim gasket of about .015" thick.....compressed.
#46
Which is exactly what I've discovered with some virgin engines I've done lately.
#47
Wish you could still buy them..assuming you can't?
#48
Again, good info and much appreciated here.
My compression ratio is what it is. This is an original '66 WT 389. I just refreshed it with new rings, bearing, seals, valve job, guides, positive seals and so on..but other than that, the pistons, rods and crank are original. Whatever the compression was in 1966 is what it is today. Because of that, I'm paying attention to this whole 'squish' thing. I re-measured the gasket and it's actually .046" but still too thick I think. I'm aiming for the mentioned .040" squish so I figure I need to start at .039" uncompressed, max. Si?
Greg Reid Palmetto, Georgia |
#49
Greg,
I'd be looking to either deck the block to zero and run a Felpro 1016 at .039 crushed thickness or just pony up for a pair of .027" Cometic gaskets if you don't decide to deck the block so you end up at .034" squish. It's also not too big a deal to take a few ccs out of the chambers before you button it up to drop the compression by say a quarter point. Bart
#50
Most everything in our car club with aluminum heads is 10.3 or a tad lower because of the 91 octane gas here. Had one engine that was a little sensitive to mid-range vacuum advance and sometimes full throttle in the middle of summer. Cam was an off-the-shelf Comp XE284H-10 that is a 240/246 @ .050". Heads were Edelbrock 87cc (89 actual) heads ported out to 305cfm by Butler.
It was an older build, and engine ran into some unrelated problems so it came out and apart. Pistons were .010" out of the hole which made compression exactly 10.6:1. With the .039" thick Felpro gaskets, this made for a nice tight .029" quench. Detonation was very mild, and some screwing around with limiting vacuum advance and really slowing it coming in allowed the old engine to function properly at 38° total... but the true 10.6 even with that cam was right on the line. Owner wanted some really docile street manners so a mild Hydraulic roller cam (224/228 on a 112) was designed to grant his wish. We ordered new pistons with a small dish in them to bring the compression down to a true 10.2:1 because of the new smaller cam and previous pinging encounter. Engine is very happy at any ambient temperature now. Side benefit is it idles like a kitten but has a ton more power now in the range he drives in (idle to coming out of passing gear at 4,800 RPM).
#51
Yes they are available. Aftermarket companies make them and are sold through Summit etc...
#52
With that thought process in mind, and using a relatively inexpensive (compared to Cometic gasket) .039 compressed Felpro gasket, will get you into an acceptable quench range that works fine for a street car. This is exactly how I just did my Pontiac engine. Pistons are .004" in the hole. Using this gasket my quench is .043" which is just fine. It's 9.68:1 with a factory iron head and a Melling RAIII cam advanced 6 degrees. It's running absolutely perfectly on our cat pee 91 octane and has shown no detonation with 34 degrees total advance even in our current 105 degree temps. |
#53
other examples I mess with here......
I also run our DZ 302 at 11:1 compression with it's factory iron heads/large dome pistons. It figures to be exactly 11:1 right now, with the piston .005" in the hole. Running the factory DZ cam with 254 @ .050 set 2 degrees advanced. 36 degrees of timing and it too is running beautiful at these high ambient temps with no complaint. But it's a pretty healthy camshaft for a very small engine so I knew from past experience I could get away with it. Actually these types of factory higher HP SBC's with the long duration camshafts that GM ran in them wouldn't run worth a darn without that high compression ratio and become very soggy engines. Aluminum headed engines are much easier to deal with. One of mine is 10.2:1 like Lust4Speed mentioned in one of his builds. I run a 248 @ .050 cam in it and have had timing as high as 38 degrees and it never complains at all in the AZ heat. My fathers 571 pushes this further with 10.84:1 using aluminum heads, made best power on the dyno at 34 degrees so that's where it stays. 260-something @ .050 camshaft and it's been running just fine on 91 octane here. |
#54
To the OP, if you drop the cr to 9.1:1 then i think you will want to reconsider the cam choice. OF is going to need more CR to have a decent idle and street manners. 2¢
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports, 3" pypes, Hooker 1 3/4" headers, hydraulic roller, 10" Continental, 3.42 gears 11.5 @117.5mph 3900lbs ([_|_] ##\|/##[_|_]) |
#55
Well, I'm definitely not going to deck the block. I just finished putting the bottom end completely together. Having the chambers looked at is possible as I was considering doing something I overlooked when I had them jobbed a few years ago. I left the press in studs and I'm kinda re-thinking that now.
I really need to cc them and check the piston height closer as it was just a casual check to get the .007" figure. I'm leaning towards trying the 1016. Steelcity's earlier post tells me that I can expect 5 or 6 tenths crush on the gasket. That would drop me down to about .041" or better of squish. Also, the fuel in GA may be a little more 'potent' than out on the west coast. I have at least one friend here who told me that he's run quite a few original hi compression engines on our 91 octane pump gas with no problems. I don't mind ponying up for premium as I won't be commuting in this car. Imagine...this started 4 or 5 years ago as a plan to pressure wash this 'field' engine, paint it and drop it in. Came out of a junk car but it ran smooth when we poured gas in and even the choke worked on it.
Greg Reid Palmetto, Georgia Last edited by Greg Reid; 06-27-2017 at 10:58 AM. |
#56
If you would, Point me to the brand that is ~0.015", thanks!
