#41
Quote) And where off.
You beat me to it Jeff. ROLMFAO GT. |
#42
Will the RA V's fit on the 6000?
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk |
#43
Well went to a different track today to see if what I did helped. The track is a SMALL outlaw track in central Indiana (Brown County Dragway) thats a little scary to be honest, narrow lanes, VERY short shutdown, and grass in the middle!
Things I did to the car: I moved my shocks (rear) up on the mounts just to make sure they weren't topping out, all is good there. Lowered launch rpm down to 3300 from 3700. Also pulled 2 degrees timing out of the car. Started with a loose setting on the extension, 4 clicks out of 18 and 6 clicks out of 18 on compression. had a total of 3 time runs and just made minor shock adjustments and each time the car reacted to them. Best part was the car was consistent. Started out with a 6.64, then a 6.62, 6.661 in time runs then ran another 6.61 first round. 2nd round Paul (aka PAULATFAST) tried to wipe up the tranny fluid the car in front of me was leaking since the track guy wouldn't, I staged, I spun, then we loaded up and went home. Taking timing out will kill ET in my car as well as the carb being a little fat for 100+ heat index so even though I wasn't thrilled with ET and 60's both made improvements with shock adjustments.
74 GTO Bracket/Street car and another 74 for the wifey to race with! 70 GTO 400, 4 spd, #'s matching and a little to nice for me to own. Friendship is like peeing your pants..everyone can see it but only you can feel the warmth! |
#44
Thats good Rob, But U changed so many things, not sure which one really helped you the most? Where was the shock setting last time out, least for reference to this?
#45
The track I went to by far is not that great but they at least make an attempt to do something plus, with how narrow it is, you do go straight.
#46
Here's a couple videos from yesterday. Also have a couple more I'll try to get up later.
https://www.youtube.com/watch?v=5mASXx7M-kg https://www.youtube.com/watch?v=CSiWsXYqOBY
#47
Completely Understand Rob, I knew you weren't looking for record ET, just some kind of a baseline So other then the timing, and chip, where were the shocks at last time out when u were having issues? It looks better leaving, not crushing sidewall and gets up on the tire pretty quickly! Same Air pressure too? Next time out if it still hooks, either add timing back or up the chip and see what the car does.
#48
I ended up with just 2 clicks from dead loose on the backs, 3 on the fronts but was adding compression equally. Adding the compression was helping hold the tires longer and not unloading them as fast and probably could have added a little more. This is not a "good" track but it I was able to adjust to it and thats what matters. Running the same 13.5 air pressure. With the MT stiff walls, thats always seemed to be the "sweet spot".
#49
So U started at 4 On EXT and 6 on comp, then u ended up at 2 on Ext on 8 on comp?
That initial setting above, is that where u were at the last track when spinning? That's what Im trying to figure out ,lol... What about the fronts, where was the setting last track outing compared to the 3 u are at now. I know its monday, but man im confused
#50
From the QA1 website:
I'm with grandville, kind of confused on what you actually did?
#51
I'm confused 24/7 anymore!
Correct on where I started and where I ended on the backs. The fronts ended up 3 and 7. My front moves pretty easily and the car will do a decent wheelie if the extension is set to loose so right now, its more about adjusting the compression not to slam the front or allow it to unload but I want the softness in the extension to transfer as much weight as possible. The last track spinfest, I got so out of whack that I honestly don't remember where they exactly were out, but somewhere in the area where they are now with not as much stagger between the 2 settings. But one thing I think I learned is when you take away from one, add to the other, you want that compression to hold the tires down if your soft on the extension. For example: Yesterday my first pass, Paul was watching and said the car carried the front tires about 10-15' about 6-8" before it came down/unloads so made an adjustment. Even though the 60' only improved .02, the car carried around 20' around 6" or less.
#52
See was that so hard ..... Thank you
I'm Trying a brand new set of Phoenix 28.5x9 with my 10" rim and tubes, 91 1/2 Rollout, 15 psi this sunday! Should be interesting.
#53
10"rim with a 9" tire will be interesting!
#54
didn't like the phoenix set I had.
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
#55
I tried them once too. They were ok but I wasn't a big fan either.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion |
#56
Seen this on the web when searching about wider rim/ narrower tire.. The one pic looks tight, but i have a 1" clearance in front and back of tire. "on a heavy car a wider rim works better,a ten inch rim with a 9in tire will be faster and will hook just as good if not better.I used to run a 29.5 10.5 mickey on a 8in rim and hated it went back to a 30x9 on a 10in rim and was much happier car was much faster and stable"
#57
Darby what tire have you been running, 29.5x10.5? |
#58
I run the 29.5x10.5x15 MT on a 10" rim and its super stable on my car. I also ran (and now run them on the wife's car) the same tire but in the 9" width on an 8" rim and that another super stable combo. You could drive both cars one handed down track. I've tried a 10" tire on an 8" rim years ago and didn't like the footprint it put down or how it handled on the big end.
I would think having a 9" tire on a 10" rim would put undue stress on the sidewalls.
#59
I was running the hoosier 29x10 on my 10" rim no tubes, I talked to the hoosier tech too, and he said the 10.5 guys are using 12"-14" rims on those tires, and their more stable on the big end and the sidewall is a tad stiffer.
That above statement is just something i stumbled across, dont take it as gospel Seen this on a site also.. The slightly narrower tire on a wider wheel bites better. The shootout boys that are limited by class rules put 10.5 tires on 12" or 14" rims. Some of those cars go 1.0-1.1 second sixty foot times. Look at what Bob West's big Chevelle does on the 9" slicks.
#60
I know you just did a lot of work on your car and probably checked this, but are you using the OEM front leaf spring mounts? If so are the leaf mount holes round? Between the the bolts that mount the front spring eye and these holes wearing you might have some slop that is making it inconsistent.
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
